Old 03-24-2003, 12:10 AM   #1
JasonNagra
JasonNagra is an unknown quantity at this point
Send a message via AIM to JasonNagra
Question Synthetic, for me???
Okay I did a search on a few forums about this question before I posted. Anyway, my 91 S13 has about 128K miles on it. The car has always been a daily driver and has never seen synthetic oil, just regular old GTX 10W-30. Well now that i am the owner of the car I track the car about once a month, and Im pretty sure i push the car harder than the previous owner considering she was an older woman. Anyway what I was wondering was, would it be wise to switch to a full synthetic oil (same weight 10W-30) on an engine with this high milage? The engine is in great condition, and the compression is excellent on all four. I was just wondering if it would hurt anything, because I had been told that an engine that has been saturated in conventional oil its whole life, can hurt the engine if switched to synthetic. This is what I heard and I do not know if its true or not. Sorry about the long post but thanks in advance. Thanks, Jason.
http://www.imagestation.com/picture/...f/f9dc7664.jpg
Edit: check your link.
JasonNagra is offline   Reply With Quote
Old 03-24-2003, 12:33 AM   #2
DuffMan
DuffMan's Avatar
DuffMan is an unknown quantity at this point
Send a message via Yahoo to DuffMan
My car had similar milage and started consuming oil when I put synthetic in, and it never had before.
Now I use very heavy synthetic oil and it doesnt consume as much, but its probably better not to switch to synth.
DuffMan is offline   Reply With Quote
Old 03-24-2003, 01:49 PM   #3
JasonNagra
Anyone else have any experience??
Old 03-24-2003, 02:38 PM   #4
JasonNagra
Also, if i do switch to synthetic, should I start by going with the blend first and then going full synhthetic??
Old 03-24-2003, 03:20 PM   #5
syco3d
syco3d's Avatar
syco3d is an unknown quantity at this point
Send a message via AIM to syco3d Send a message via Yahoo to syco3d
The previous owners of my car ran Castrol -20w 50 I believe...I change oil as soon as I picked it up and switched to Castrol's full synthetic (Syntec) 5w50. And actually it doesn't consume as much oil as the previos owners stated it did. Maybe because of the different oil...but who knows.
Btw..I bought the car at 164k in late oct. Now at 176k
Gimme a "A"!
Gimme a "P"!
Gimme a "C"!
What does that spell?
CRAP!
syco3d is offline   Reply With Quote
Old 03-24-2003, 05:39 PM   #6
JasonNagra
So basically if I do decide to switch to synthetic then I should only switch to a higher viscosity??
Old 03-24-2003, 06:39 PM   #7
logo20
logo20 is an unknown quantity at this point
i just switched to 10w-30 synthetic, i have 115k and today I noticed there was a tapping in the valves, and it went away after driving it. a few months ago after I flushed the engine, it did the same thing once, so I might have compression problem. You should be ok with 10w-30, try it, it won't hurt nothing.
logo20 is offline   Reply With Quote
Old 03-24-2003, 06:50 PM   #8
240Driver39
240Driver39 is making a name for him/her self240Driver39 is making a name for him/her self
Send a message via AIM to 240Driver39
i switched the car to mobi 1 10w30 at about 108k, doesnt consume oil or nething, no problems
1990 240sx 5spd fastback
240Driver39 is offline   Reply With Quote
Old 03-24-2003, 06:55 PM   #9
JasonNagra
Okay thaks guys for the input.
I was also wondering what is the best (or considered) conventional oil??? Mobil 1, valvline race, quaker state etc??? Thanks guys.
Old 03-24-2003, 06:57 PM   #10
96SEChick
96SEChick's Avatar
96SEChick is an unknown quantity at this point
Just a little tidbit though--if you change to synthetic, you may find an oil leak or two. My car had 63k when I bought it--not a single noticable leak. About 3 weeks after I bought the car, I changed my oil and put in synthetic. I found 3 oil leaks a week later. Synthetic oil is much "smoother" than conventional oil and can find itself into cracks, crevices, and holes much easier than conventional oil. So, if you do change, don't be surprised if your car starts to leak a bit (or in my case--a lot )
Lauren
'91 300ZX TT Ultra Red 5-speed - JWT POPCharger, JUN flywheel, ACT clutch, Energy Suspension Bushings, Tokico Blues - dyno'ed 295hp/306tq
'94 300ZX TT Black Emerald Pearl 5-speed - JWT POPCharger, JWT ECU w/ Stillen chip, Stillen exhaust, Tokico Blues, Eibach ProKits, 18" Enkei RP-01 wheels - dyno'ed 333hp/385tq
'00 WS6 Trans Am Bright Red 6-speedFOR SALE - only 29k miles, stock, fully loaded, only $23,999 (NADA $26300)
Green Country Motorsports
Northeastern Oklahoma SCCA
96SEChick is offline   Reply With Quote
Old 03-24-2003, 07:29 PM   #11
JasonNagra
Yea I don't think that the benefits of changing to synthetic are great enough even though the car is driven aggresively to switch. But I still want to know what conventional oil do you guys think is the best???
Old 03-24-2003, 07:44 PM   #12
andrave
andrave's Avatar
andrave is an unknown quantity at this point
Send a message via AIM to andrave
I read that high mileage cars lose more oil with synthetic. The idea is that its good if you use it from a low mileage, but not good for higher mileage cars, because its slippery and can slide through cracks and seals that regular oil won't. I know with my old escort, I tried synthetic once and lost quite a bit more oil than normal.
I have found the quaker state high mileage 10w30 to be a good winter oil, and in the summer or higher temps I run a little thicker so I don't lose as much.
andrave is offline   Reply With Quote
Old 03-24-2003, 08:06 PM   #13
syco3d
syco3d's Avatar
Why is everyone so afraid of losing alittle oil??? As long as your not adding a quart less then every 1000mi. what's the big deal? If your having to add oil periodically then you're actually keeping the oil cleaner by replacing the 'dirty' oil with clean.
I drive my 240 hard enough that I'm not going to trust conventional oil to keep my HIGH mileage engine from breaking down. If that means I have to add an extra quart or 2 between oil changes then so be it.
Gimme a "A"!
Gimme a "P"!
Gimme a "C"!
CRAP!
Old 03-24-2003, 08:06 PM   #14
drift freaq
R.I.P. Aya, always love
drift freaq's Avatar
Trader Rating: (215)
Feedback Score: 215 reviews
there has been much debate here in the past over whats better.
Some old school stick in the muds would tell you there is no benefit to synthetic.
I am an old school stick in the mud that feels there are.
It does have much better viscosity than conventional oil. It also withstands higher engine temps because of this.
I would only recommend a few synthetics though.
1 Amsoil
2 Motul
3 Mobil 1
4 Redline
If you wonder why I put Amsoil at the top its because its the one the is API rated for extended drain intervals. They also sell some of the best oil filters on the market that filter down to less than 1 micron.
Motul is a highly rated Formula 1 and Motorcycle synthetic. Not widely seen here in the states but availible.
Mobil 1 is the brand that of the easy to finds ones is the standout. It comes in right behind Amsoil and Motul.
Redline is not API rated. though it may be now? they have a great trans oil that is synthetic and is real good.
these 4 companies have been around a long time longer than any of the other major oil companies who jumped on the bandwagon due to competition from the 4 above synthetic manufactures.
Yes synthetic may cause oil leaks on higher mileage engines due to what has been stated above. though if you do use it will cut down on engine wear due to superior lubrication qualities.
New Video
Buy my mounts!
Old 03-24-2003, 08:37 PM   #15
JasonNagra
Dave,
What do you think are the top conventional oils?
Old 03-24-2003, 08:59 PM   #16
96SEChick
96SEChick's Avatar
Originally posted by JasonNagra
Dave,
I have heard (that means it's not a proven fact) that Valvoline is a good conventional oil, due to the lack of additives (compared to Pennzoil--which is the 100% worst oil to use on your car--I've been told this by many, many mechanics and quite a few friends) so it doesn't gum-up anywhere. I've also been told that Valvoline helps reduce lifter knock/tick.
Lauren
Old 03-24-2003, 09:04 PM   #17
kandyflip445
kandyflip445's Avatar
Um, I was just thinking a little bit and I'd have to do more research on it but I'm pretty sure synthetics have better/more aggressive additives in them. I've read of people that switch from a conventional oil to a synthetic and had thier oil analyzed. They found that the ppm of aluminum and other such materials found in the engine went up. But, after a few changes it dropped back down to a lower level than the conventional oils had. So from that it seems like it was cleaning/removing things that the conventional oil could not contain untill the recommended change interval. This is where I read about it before. They were refering to Redline oil I believe. So try a search on that. That forum has a LOT of good information on oil/filters and such. Check it out.
Old 03-24-2003, 09:16 PM   #18
whateverjames
whateverjames's Avatar
whateverjames has a little shameless behavior in the past
Send a message via AIM to whateverjames
I was losing oil when I switched to synthetic at 130,000 miles. I started using 10w30 and I still had to add oil, but not as much. I didn't like buying a case of Mobil 1 in between oil changes, so I switched to the Valvoline conventional oil (easier on the wallet and you get twice as many quarts, plus the car has 194,000 miles now). I use Mobil 1 in my Blazer (9,000 miles) and I'm getting no leaks, so I'll keep using synthetic in that.
02 Blazer X - 90 240SX w/SR
oh noes
whateverjames is offline   Reply With Quote
Old 03-24-2003, 09:40 PM   #19
Red
Red's Avatar
Red is an unknown quantity at this point
I will only use synthetic oil.. 5W30 at 106,000
You do find a lot of leaks tho... Mine was a gusher for a while... All fixd!
http://www.cardomain.com/memberpage/509537
http://www.imagestation.com/album/?id=4287415487
http://www.zilvia.net/f/showthread.php?t=21036
Red is offline   Reply With Quote
Old 03-24-2003, 10:01 PM   #20
JasonNagra
What do you guys think about the valvoline higher milage engine oil? It seems like it has a lot of additives in it, which most of you guys look down upon. I geuss in terms of conventional oil that using just regular valvonline is the best, right??
Old 03-25-2003, 01:24 AM   #21
Hubie
Hubie is an unknown quantity at this point
Send a message via AIM to Hubie
Stay away from Quaker State and Penzoil. They are both parafin based oil which can leave a waxy sustance behind if the oil itself is overheating. Granted most nissans run pretty cool I'd still stay away from them. I think if you don't drive the crap out of your car, any conventional oil will do, as long as it is changed often.
I recently switched from the normal Mobil to Mobil1 and haven't experienced any ill effects from my 104k engine. I did notice a lot quieter engine. My lifters used to tick and it has stopped after the Mobil1.
However, I did the change on my old VW which also had about 105k but soon after it sprung leaks from all sorts of places. And switching back to regular does nothing, as the damage(cleaning) has already been done.
Hubie is offline   Reply With Quote
Old 03-25-2003, 09:51 AM   #22
burgy240
burgy240's Avatar
burgy240 is a name known to allburgy240 is a name known to allburgy240 is a name known to allburgy240 is a name known to allburgy240 is a name known to allburgy240 is a name known to allburgy240 is a name known to allburgy240 is a name known to allburgy240 is a name known to allburgy240 is a name known to allburgy240 is a name known to all
Send a message via AIM to burgy240 Send a message via Yahoo to burgy240
I only use sythetics or synthetic blends. I 'm a fan of Mobil 1. Of course it is what you see the most and it is marketed the best but It works well on my cars so far. It does also come in a lot of highend and exotic cars from the factory too. porsche/Benz/etc
burgy240 is offline   Reply With Quote
Old 03-25-2003, 11:36 AM   #23
kandyflip445
Additives aren't bad they are good. When you see little metal stuff coming out when you change the oil(exageration) you know that the oil is doing it's job of keeping the harmful comtaminates suspended in the oil thereby letting you get rid of them by changing your oil, and this is only one type of additive. The higher milage would probably be good for your car because it most likely has some cleaning agents and some conditioning additives in it.
Old 03-25-2003, 07:50 PM   #24
andrave
andrave's Avatar
metal shavings in your oil are bad, sign the engine is going poop.
Old 03-27-2003, 01:22 AM   #25
JasonNagra
In terms of just CONVENTIONAL oil, would you guys say that valvoline or mobil is better? Thanks, Jason.
PS ~ keep in mnd this car is taken to the track about once a month and oil is changed along with original Nissan filter every 2500 miles.
Old 03-27-2003, 01:52 AM   #26
Hubie
Don't know what this means, but when I used Castrol GTX I noticed that it got dark faster than when I used regular Mobil. It was the same when I tried out both of their synthetic lines. I think it has something to do with being able to suspend more contaminants and or for a longer period of time. I've never tried Valvoline but imagine it would be one of better conventional oils out there.
This may be silly but do you guys go around sniffing the new oils that they get to compare with another brand. I've noticed that some smell more like burning oil while other just don't really have a smell. I just remembered...I live in Houston and was driving past an oil/gas refinery and it smelled exactly like the bottle of Shell oil that I used in my sister's car. Hahaha.... I think this oficially makes me a car nut. Literally...
Old 03-27-2003, 11:12 AM   #27
JasonNagra
Anyone else??
Old 03-27-2003, 12:44 PM   #28
logo20
I still think you should try synthetic oil. if you encounter any problem-which I strongly doubt-just go with any conventional oil(they all pretty much the same) or valvoline high mileage.
edit: with synthetic you'll have to change it every 5-6000 miles, or even more. you'll just love it.
Old 03-27-2003, 04:31 PM   #29
JasonNagra
Well if i do switch, what weight should I use, the same old 10W-30??
Old 03-27-2003, 09:18 PM   #30
logo20
well it depend on the brand you get. I'm using 10w-30 mobil 1 because it's one of the most popular and you can get it anywhere, walmart has the best prices. redline has 10w-40, it's really your choice.
I'm gonna get redline mt-90 transmission fluid. you might consider that too.
