Old 03-24-2003, 02:20 PM   #1
FastBack 240
FastBack 240's Avatar
FastBack 240 is not welcome here anymoreFastBack 240 is not welcome here anymoreFastBack 240 is not welcome here anymoreFastBack 240 is not welcome here anymoreFastBack 240 is not welcome here anymoreFastBack 240 is not welcome here anymoreFastBack 240 is not welcome here anymoreFastBack 240 is not welcome here anymoreFastBack 240 is not welcome here anymoreFastBack 240 is not welcome here anymoreFastBack 240 is not welcome here anymore
Belt tightener romoval.
How do you romove the tensioner, the big one in the center of the engine so i can get the alt off. I know there is one big bolt in the middle and some little ones surrounding but i still cant get it off because it only loosens the first one. Kinda confusing. Any help would be apreciated.
FastBack 240 is offline   Reply With Quote
Old 03-24-2003, 02:22 PM   #2
Dousan_PG
Dousan_PG's Avatar
i think there was one in middle, one on side (facing passenger side fender) and you can loosen the alternator (has its own bolt it can pivot on) too and push it down to add more slack. i forget, its been awhile since the last belt change.
ediT: i assume this is for KA?
Aaron
Pink GodziRa
Old 03-24-2003, 02:36 PM   #3
FastBack 240
yea...92 stock ka. I looked at my other engine which is a 95 ka that is a hell of alot cleaner and i kinda have an idea of how to do it....i already got the alt bolt out of it but it wont budge because the belts so tight.
Old 03-24-2003, 02:37 PM   #4
Stee Flo
Endless Knights
Stee Flo's Avatar
Stee Flo is an unknown quantity at this point
yeah i just changed my belts this weekend. There is an alternator mounting bolt right below the alt. Loosen that some so that you can move the alternator down some to slacken the belt. Also loosen the tensioner bolt for the alt belt that is to the left of the alternator. Go to this site to get an idea on how to change the belts. Its for a pulley install, but it shows the steps for taking off the belts. Make sure to loosen the tensioner lock bolt before loosening the tensioner bolt.
Stee Flo is offline   Reply With Quote
