![]() ![]() (i know the timing is different during warm up) or an air fuel ratio issue? my mods are a stock air box with lower half removed and a k&n stock replacement filter. i have cleaned the MAF with carb cleaner, and the throttle body. i have no cat... on a stock exhaust. (including pre muffler. could it be clogged?) any in put would be appreciated.
1995 black on black leather SE powder coated black stock 5lugz homeade intake sweet cb antenna(for those road trips) |
![]() Join Date: Sep 2002
could be something w/ the cold start system. something like the engine temp sensor getting stuck and making the ecm think the engine is cold even though it's warm and that would make it run really rich(see cold engine). could try that. do you have a CEL on? If you do, have you checked the codes?
![]() Join Date: May 2002
Put the cat back on.
Seriously, it could be the problem. S14s are OBD2, meaning they have a second O2 sensor after the cat. When the engine's warm, the ECU will expect the cat to be working. When it sees the same O2 sensor reading before and after it may very well cut power. And if it's not the problem, then you'll have done the responsible thing anyway. THERE IS NO REASON TO REMOVE A CATALYST FROM A STREET DRIVEN CAR. Beyond that, check the condition of your coolant temperature sensor and its wiring to the ECU, though I don't think that's the problem if your temp gauge still works. |
#6 |
aka...you reminded me of something... i went out side to check.
on the exhaust pipe... there is what looks like a ground strap disconeccted after the cat x==={=cat=}^=====premuffler======muffler "^" is where the strap is... x is ??? an 02 sensor? ( plugged in to a harness) |
#7 |
ok.... the cat im referring to like a dumbass is the dummy cat
(dumbass dumb cat heehee) ![]() which makes me ask.. should i just go ahead and replace the o2 sensor. ( this weekend im doing a plug,fuelfilter,wires tuneup) thanx again for any response. |
#8 |
![]() Join Date: Feb 2002
I have the same year car. also an (se) if you find out what this is I would like to know..
I just did emmisions.. out goes the cat. ![]()
http://www.cardomain.com/memberpage/509537 http://www.imagestation.com/album/?id=4287415487 http://www.zilvia.net/f/showthread.php?t=21036 |
#9 |
i posted on 240.org too.. ill let you know. btw good improvement after you lost your cat/premuffler? any problems?
and... how do you like your popcharger?
#11 |
The POP-Charger is nice adds some deep intake noise after and a good kick after 4000rpm.. I wish I would have got one with the full pipe to the intake tho.
The Cat will be off very soon. I have 3 options 1. Have my bro weld me one 2. Order it friday from Enjuku 3. Buy this neat maxima pipe with sound killin stuff in it and cut and refit it. I will decide by Friday and once I get it in and on i'll let you know!
#12 |
