Old 04-26-2009, 01:36 PM   #1
akira2_03
akira2_03 is an unknown quantity at this point
KA HELP car not running right!
well after replacing everything with my harness and all the car runs at idle as long as no maf is plugged in. if plug in maf it dies. and again this is the maf from my dd 240sx. but it will run with no maf but if accelerate it it back fires like its running rich and hesitation. so...... went to the fuel next
k well as the return line had no fuel coming out. (disconnected it up front beside the fuel filter) i took out my fpr and fuel came running out at the end of the rail. so figured i found the problem. replaced the fpr and put all back together and started the car. same thing no fuel coming out of the return line. car dies if maf is plugged in but idles with no maf but STILL no fuel out my return line!!! soooo is there a huge clog or something in my lines you think???? after the fpr???
heres a vid of how it runs. and i cant plug maf in or it dies. and it is a good maf as it is from my dd 240sx
akira2_03 is offline   Reply With Quote
Old 05-19-2009, 02:28 PM   #2
akira2_03
so been tinkering more and still have no fuel coming out from my fpr. lines are clear blew air threw them no prob. fuel pump is running but after it idels for a while or you try to give it gas and it hesitates sometimes revs up and when let off the gas it almost dies but idles back up. mind you this is all with no maf plugged in. im thinking it starving for fuel? maybe pump is not pumping enough?? the sock looks blackish grey on the pump. so im thinking i can try to change it if i can find another. anything else?????? suggestions? cant find any vac leaks.
Old 05-19-2009, 07:59 PM   #3
s142jzkillav10
s142jzkillav10's Avatar
s142jzkillav10 is an unknown quantity at this point
Send a message via MSN to s142jzkillav10
have you checked your timeing ??
s142jzkillav10 is offline   Reply With Quote
Old 05-19-2009, 10:51 PM   #4
akira2_03
yes timing is set dead on with new dizzy
Old 05-22-2009, 01:37 PM   #5
jspeedm
jspeedm's Avatar
Trader Rating: (26)
jspeedm is on the path to ruinjspeedm is on the path to ruin
Feedback Score: 26 reviews
fuel filter?
http://i404.photobucket.com/albums/pp128/jspeedm/Picture097.jpg
jspeedm is offline   Reply With Quote
Old 05-26-2009, 05:57 PM   #6
Shadowhunter
Shadowhunter's Avatar
Shadowhunter is an unknown quantity at this point
Are you sure the fuel pressure regulator settings are correct? If not you may not be spitting the required fuel pressure to keep your engine running.
Shadowhunter is offline   Reply With Quote
