Old 04-27-2009, 11:08 PM   #1
chato de shamrock
chato de shamrock's Avatar
chato de shamrock is an unknown quantity at this point
high beams turn on when i turn signal light on
Last night I noticed my high beams turn on when i signaled for a right turn lane change while i was on the freeway. Just a few minutes ago as I was driving home I noticed it did it again a few more times. While i was driving up my driveway i was messing around with the lights. I signaled for a left turn and everything was fine. I signaled right and the high beams kept turning on each time. Does anyone have any idea what might be happening?
On the first weekend of this month I installed a quick release on my car and about a week or so ago I noticed that, while my lights are on, when I switch from low to high beams there is no little click in between. For example, when you want to quickly hit the high beams at someone in front of you to speed up or get out of your way you would pull the stick about half way and then let go so the high beams turn on and then pop back to low beams. I cant do that on my car. What causes the stick to pop back to low beams, that click you feel on the stick, doesnt seem to work. I thought maybe something was moved when I installed the quick release. Anyone? I've been driving like this for a week or so but just yesterday night i noticed the high beams turn on each time i turn on my right turn signal.
Does anyone know what might be the problem or where i can start the troubleshooting? Thanks for taking the time to stop by and read my thread.
chato de shamrock is offline   Reply With Quote
Old 04-28-2009, 01:20 AM   #2
carcrossy
carcrossy is an unknown quantity at this point
what is a quick release. ordinarily, i would say to take your switch apart and clean the contacts etc. pm me if you want information on how to do it.
carcrossy is offline   Reply With Quote
Old 04-28-2009, 04:20 AM   #3
chato de shamrock
I changed the stock steering wheel with a Momo steering wheel and added a short hub and quick release device to pull the steering wheel off. I'm thinking this change might have caused something to loosen up, but on the other hand I didnt mess with the turn signal/lights stick.
Old 04-29-2009, 06:54 PM   #4
chato de shamrock
Bump. Actually last night I noticed it was just the left side's high beams that turn on each time i turn the right hand signal. I had to pull the stick back to turn the high beams on and then turn them off. Somtimes it wouldnt turn the high beams until a few tries. Anyone have an idea whats going on?
Old 04-29-2009, 06:56 PM   #5
kris
kris's Avatar
kris is an unknown quantity at this point
like carcrossy said the contacts. Over time the connectors inside the switch become dirty from the arching, clean them, problem should be solved.
kris is offline   Reply With Quote
