Old 03-26-2003, 03:53 PM   #1
Jeff240sx
I hate you too...
Jeff240sx's Avatar
Jeff240sx has a reputation beyond reputeJeff240sx has a reputation beyond reputeJeff240sx has a reputation beyond reputeJeff240sx has a reputation beyond reputeJeff240sx has a reputation beyond reputeJeff240sx has a reputation beyond reputeJeff240sx has a reputation beyond reputeJeff240sx has a reputation beyond reputeJeff240sx has a reputation beyond reputeJeff240sx has a reputation beyond reputeJeff240sx has a reputation beyond repute
Post pictures of mad negative camber!
I think I have found the winner before the contest even started though!
Dousan... too much camber up front yet?
-Jeff
Whatup?
Jeff240sx is offline   Reply With Quote
Old 03-26-2003, 04:07 PM   #2
Dousan_PG
Dousan_PG's Avatar
no not yet. haha..another few degrees would be better. hahaha..
my car. i hope it qualifies in this contest.
-3.5 front
-4 rear
oh here's VRTs:
(his car is on left)
-4 rear
maybe -2 front?
Aaron
Pink GodziRa
Old 03-26-2003, 04:15 PM   #3
uiuc240
uiuc240's Avatar
uiuc240 is an unknown quantity at this point
Send a message via AIM to uiuc240
Re: Post pictures of mad negative camber!
-Jeff
That **** looks broken, dude
Eric
2002 Mazda Protege5
1989 S13 w/SR20DET (sold)
uiuc240 is offline   Reply With Quote
Old 03-26-2003, 04:20 PM   #4
AceInHole
Autox Technician
AceInHole's Avatar
AceInHole is close to perfectionAceInHole is close to perfectionAceInHole is close to perfectionAceInHole is close to perfectionAceInHole is close to perfectionAceInHole is close to perfectionAceInHole is close to perfectionAceInHole is close to perfectionAceInHole is close to perfectionAceInHole is close to perfectionAceInHole is close to perfection
lol... i remember people arguing if the first pic was photochopped or not
AceInHole is offline   Reply With Quote
Old 03-26-2003, 04:20 PM   #5
LoCo
LoCo is an unknown quantity at this point
Send a message via AIM to LoCo Send a message via Yahoo to LoCo
-Jeff
LoL I saw that picture before... I know it came off a site selling body kits but I forgot wich one. Damn talk about negative camber!
Lenny
1993 S13
ACT Street Clutch, Lightened Flywheel, OBX Short-throw Shifter, Magnecor 8.5" Competion Spark Plug Wires, Front Strut-Tower bar waiting to do my rear lol, AEM Ram Air Intake, APEXi N1 Catback w/ Silencer (finally... sick of getting pulled over)
What next? ...Brakes, suspension, or something else?
UPDATE: going to re-build front end (bumper, fenders, hood, headlights) due to accident!!
LoCo is offline   Reply With Quote
Old 03-26-2003, 04:21 PM   #6
Dousan_PG
Dousan_PG's Avatar
if i had adjustable lower control arms i would try that (just to take a pic, not to drive around on) with my car. hmmm
looks like a fun way to waste a afternoon
loco: the body kit is "Target"
Aaron
Pink GodziRa
Old 03-26-2003, 04:56 PM   #7
240racer
240racer's Avatar
240racer is an unknown quantity at this point
dousan, why do you have so much camber for drifting, what does it do for you?
Adam
'89 coupe KA24DE+T
14.1 @ 104 MPH
'88 Celica All-Trac turbo
stock, but no more ecu codes!!
240racer is offline   Reply With Quote
Old 03-26-2003, 04:59 PM   #8
Dousan_PG
Dousan_PG's Avatar
KA is completely stock (ka24de)
tires are FM901 all around
the camber makes drifts more stable and grip well, espeically at higher speeds. i like how it feels a lot. others might not but for me i love it car is so easy to control at higher speeds. solid. rock solid and reponds how i like.
as far as tire wear, after a day drifting on FM901s the inside (about 3/4 of tire) is wore inside. so i just flip it for the next time and bring another set of tires and im fine FM901s take a beating.
Aaron
Pink GodziRa
Old 03-26-2003, 05:00 PM   #9
DoriftoSlut
DoriftoSlut's Avatar
DoriftoSlut is a splendid one to beholdDoriftoSlut is a splendid one to beholdDoriftoSlut is a splendid one to beholdDoriftoSlut is a splendid one to beholdDoriftoSlut is a splendid one to beholdDoriftoSlut is a splendid one to beholdDoriftoSlut is a splendid one to beholdDoriftoSlut is a splendid one to beholdDoriftoSlut is a splendid one to beholdDoriftoSlut is a splendid one to beholdDoriftoSlut is a splendid one to behold
Send a message via AIM to DoriftoSlut
Camber in rear allows for smaller contact patch (if set up properly with tire choice...) and in front it allows for you to get FULL contact patch when the car is under load (outside tire). Its all about controlling the car as it gets to the limit!
Death Before Dishonor.
www.pinkgodzira.com
www.driftalliance.com
DoriftoSlut is offline   Reply With Quote
Old 03-26-2003, 05:02 PM   #10
240racer
240racer's Avatar
I was wondering if you tried more or less and found a spot you like or whatever. my experience in racing, we always used a tire pyrometer to measure temps and tried to keep them the same across the tread. Would you say that your temps are pretty constant too? also, I saw that you like to run pretty narrow tires on wider wheels, is that so you get less flex from the tires. I have noticed that when sideways on dry pavement, as the car goes through center there's a little jerk, is this reduced by narrow tires and/or camber
thanks
Adam
'89 coupe KA24DE+T
14.1 @ 104 MPH
Old 03-26-2003, 05:04 PM   #11
240racer
240racer's Avatar
Or beyond the limit, I consider drifting to be beyond the limit, which is why it's so much fun. The rear tires are sliding now, kinetic friction instead of static friction.
If you are always out of control, you never get caught off gaurd
Adam
'89 coupe KA24DE+T
14.1 @ 104 MPH
Old 03-26-2003, 05:16 PM   #12
DoriftoSlut
Thats one way to consider it. I prefer to think that it is all about control. You are controlling a slide, not sliding out of control. Believe it or not, drifting is all about grip. You need MORE lateral inertia than you tire's forward grip to keep the slide, but hte less grip you have, the more you rotate. The more grip you have the faster you go. In the front, you always want to have grip to spare, so you can dictate when, if anytime, you can forego that front grip on purpose (ie locking up the fronts at or before an apex). Blah blah blah, i could go on for days. [Dorifto, shut up already, they don't care]
www.pinkgodzira.com
Old 03-26-2003, 05:36 PM   #13
Dousan_PG
Dousan_PG's Avatar
ah leave it to dorifto to explain all that
my expirience, i've tried crappy tires and little to no camber. tried more camber and fooled around
basically im a lazy guy. haha..
so i went all out and went -4. i am going -3 next time and try that. but for my skill level (beginner) i set my car up like this. i enjoy
as far as temperature, ive never really fooled with it. i go to the track, drift balls out (or as best i can) and learn from there. im still new at all this car stuff so learnig a lot. heh...
i just found this setup works best for me. when i start going faster (sooon-3rd gear drifts) then ill have to change setups again. same goes if i get more power...constant change. anyways, works for me and ive never been more pleased with my car then i am right now
oh for the jerking stuff, nah my car doesnt jerk. im able to keep it SMOOOOOOTH (everyone tells me they are smooth-jspec, dorifto, ny_jee, etc) but i am not CRAZY enough (must start...earlier! ) so my drifts are smooth, no jerking. oh i always drift on dry pavement. i dont fool around in the rain/wet surfaces. i like the screaming tires.
as far as stretching, i guess im "slightly" stretched. 205/55/15 on a 7.5 inch wheel width. not super stretched but sidewall is SLIGHTLY (very slightly) pulled.
edit: I always use DUnlop FM901s on all 4 wheels. feels bset for my level and my car's setup.
Aaron
Pink GodziRa
