Old 05-01-2009, 07:14 PM   #1
GuardianLlama
GuardianLlama's Avatar
GuardianLlama is close to perfectionGuardianLlama is close to perfectionGuardianLlama is close to perfectionGuardianLlama is close to perfectionGuardianLlama is close to perfectionGuardianLlama is close to perfectionGuardianLlama is close to perfectionGuardianLlama is close to perfectionGuardianLlama is close to perfectionGuardianLlama is close to perfectionGuardianLlama is close to perfection
E-Brake light wont go out.
ok so the brake light won't go out on the dash of my 1990 hatch. fluid is to the top and the light goes on and off as i apply the ebrake when the car is not running. but as soon as i start the car the light goes on. battery light also lights up dim. turbo timer reads 13.7v constantly
z32 front calipers, booster and BMC
some ideas?
GuardianLlama is offline   Reply With Quote
Old 05-01-2009, 07:20 PM   #2
kevmeistah21
kevmeistah21's Avatar
Trader Rating: (68)
kevmeistah21 is an unknown quantity at this point
Feedback Score: 68 reviews
Send a message via AIM to kevmeistah21
on your ebrake hand theres a switch towards the end, remove your center console to get a better point of view. The switch is towards the bottom of the ebrake and when you put the ebrake down it causes the switch to deactivate turning off the light and when you pull the ebrake up it causes the switch to activate turning on the light.
kevmeistah21 is offline   Reply With Quote
Old 05-01-2009, 07:22 PM   #3
GuardianLlama
as i said above the light functions perfectly while the car is not running. not really sure how this could solve my problem
Old 05-01-2009, 07:24 PM   #4
kevmeistah21
Trader Rating: (68)
ohh lol i misread the first post. sorry idk whats going on then.
Old 05-01-2009, 07:32 PM   #5
BoostedCoupe
BoostedCoupe's Avatar
BoostedCoupe can only hope to improve
check the brake fluid. the light stays on when it is low.
92 vert converted 5speed and other little things
BoostedCoupe is offline   Reply With Quote
Old 05-01-2009, 08:43 PM   #6
rexify
rexify is an unknown quantity at this point
Its your charging system. With both those lights on it means the alternator isnt charging correctly. Have the alt checked out.
rexify is offline   Reply With Quote
Old 05-01-2009, 09:21 PM   #7
GuardianLlama
BMC is full.... also as stated above.
damn even if my turbo timer is reading 13.7v???
Old 05-02-2009, 09:09 AM   #8
rexify
Yeah. my SAFC II was reading normal voltage too. My alternator belt was loose and wasnt charging that well. Once I tightened the belt everything was good again. See if your belt is tight first.
Old 05-02-2009, 09:50 AM   #9
ixfxi
Guest
Posts: n/a
alternator has nothing to do with the brake warning light circuit.
alternator charge light has its own circuit.
the brake light works with ether the ebrake switch OR the bmc reservoir level switch.
Old 05-02-2009, 09:56 AM   #10
rexify
The brake and battery light combo is a code nissan uses for telling you battery isnt charging correctly. ITs been covered.
Old 05-05-2009, 01:42 PM   #11
slothonaleash
slothonaleash has a reputation beyond reputeslothonaleash has a reputation beyond reputeslothonaleash has a reputation beyond reputeslothonaleash has a reputation beyond reputeslothonaleash has a reputation beyond reputeslothonaleash has a reputation beyond reputeslothonaleash has a reputation beyond reputeslothonaleash has a reputation beyond reputeslothonaleash has a reputation beyond reputeslothonaleash has a reputation beyond reputeslothonaleash has a reputation beyond repute
Is there any update on this?
My brake light comes on randomly while I'm driving then goes out. My BMC's full, and my alternator/battery are only a month or two old.
slothonaleash is offline   Reply With Quote
Old 05-07-2009, 03:29 AM   #12
Odysseus
Odysseus is an unknown quantity at this point
^Ditto...Its annoying to see my light come and go.
Odysseus is offline   Reply With Quote
Old 05-07-2009, 10:08 AM   #13
ANVIL
ANVIL's Avatar
ANVIL can only hope to improve
mine is on also. i tried quickly to address it but havent given it much thought until i finish my q45 calliper upgrade.
but what i did notice is.... if i pull up the ebrake the brake light gets brighter, and put it down it gets dimmer but still on. if i unplug the sensor on the bmc the light goes out, and if i use the ebrake, it lights on and off normally. the float isnt stuck and i drained/flushed out the bmc and it was still on. when i do my brake work (Q45 calipers/pads/rotors and ss lines up front, rebuilt s13 calipers in the R w ss lines) i will be doing a full flush and then going from there to address the light.
if anyone knows what could be up with mine id appreciate some suggestions
ANVIL is offline   Reply With Quote
Old 05-07-2009, 10:19 AM   #14
ixfxi
Guest
Posts: n/a
Bullshit.
Those circuits dont even go into the ECU. The alternator (battery charge) light signal comes straight from the alternator, the low brake fluid/ebrake signal goes directly to the hand brake and the BMC.
What else, Chun Li throws her bracelets too right?
Old 05-07-2009, 11:55 AM   #15
s14driver
s14driver is an unknown quantity at this point
Alternator. I had the same issue
s14driver is offline   Reply With Quote
Old 05-07-2009, 12:18 PM   #16
ANVIL
ANVIL's Avatar
my alternator has less than 2k miles on it, freshly rebuilt
Old 05-07-2009, 12:50 PM   #17
clark
clark's Avatar
clark is close to perfectionclark is close to perfectionclark is close to perfectionclark is close to perfectionclark is close to perfectionclark is close to perfectionclark is close to perfectionclark is close to perfectionclark is close to perfectionclark is close to perfectionclark is close to perfection
you have a weak ass connection to your alternator.
you sure you have a plastic or other non metal washer separating the positive source to the alternator?
do you have a buzzing noise coming from the fuse panel near your left leg?
clark is offline   Reply With Quote
Old 05-07-2009, 12:54 PM   #18
DreamN
DreamN's Avatar
Trader Rating: (54)
Feedback Score: 54 reviews
Bullshit.
Mike, it's actually true. Search the subject, it's been talked about and confirmed. Hell, I even experienced it when I first bought my S13. Had an incredibly worn belt and once the car was on both the brake light and the battery light would come on simultaneously. Changed the alternator belt and all was perfect in the world.
- Jimmy
Wanted:
TBD
For Sale:
TBD
Old 05-18-2009, 07:52 PM   #19
janders211
janders211 is an unknown quantity at this point
What else could cause this brake light + Battery light Combo?
I had it on my alternator when it was dying (<12.5). I replaced the alternator and it was fine (~13.3v)- and it worked for a while.
I left the car out in a hard rain and now I'm getting high overvoltage (15v, that sometimes drops to 13v) and I get both lights. It is overcharging- outside of the alternator what could do this...i.e. where else is there voltage regulation?
janders211 is offline   Reply With Quote
Old 05-18-2009, 11:53 PM   #20
ixfxi
Guest
Posts: n/a
considering that ive taken apart the ENTIRE wiring harness of my 1990 S13 240SX and my 1998 S13 180SX, i will say that 100% there is no fucking combo code.
i took apart and traced each and every wire, and i can specifically tell you that the brake light circuit is completely separate from the alternator charge circuit, and none of them go through an ecu or anthing advanced enough to throw a combo code.
there is only ONE person on this forum that i would even remotely consider listening to when it comes to wiring, and that would be russ. he is the only one who truly knows the car as inside and out as i do when it comes to wiring and such.
so no, there is no combo code.
Old 05-19-2009, 10:05 AM   #21
janders211
When I unplug the power wire (the one that switches it on) to the alternator it pops on the brake light. There has to be some sort of connection for this to happen-although I'm not saying it is ECU controlled. Also, too low, and too high voltage coming from the alternator pop on the brake light...not sure why- but it happens.
Old 05-19-2009, 10:54 AM   #22
Ragnarok043
Ragnarok043 is making a name for him/her selfRagnarok043 is making a name for him/her self
ditto it has happened to me before too, the brake light turned on when my alternator went bad.
Ragnarok043 is offline   Reply With Quote
Old 05-19-2009, 11:13 AM   #23
DreamN
DreamN's Avatar
Trader Rating: (54)
You never bothered to look at the FSM?
91-94 FSM EL-46 Last portion of it you see the connection, bulb check relay.
- Jimmy
Wanted:
TBD
For Sale:
TBD
Old 05-19-2009, 09:54 PM   #24
rokmplutonium
rokmplutonium's Avatar
rokmplutonium is a jewel in the roughrokmplutonium is a jewel in the roughrokmplutonium is a jewel in the roughrokmplutonium is a jewel in the roughrokmplutonium is a jewel in the roughrokmplutonium is a jewel in the roughrokmplutonium is a jewel in the roughrokmplutonium is a jewel in the rough
I had the same symptoms, turns out my alt. was going bad.
It took several months for my alternator to finally die. After my alt. was changed out, the lights turned off.
rokmplutonium is offline   Reply With Quote
Old 05-20-2009, 02:44 PM   #25
GuardianLlama
crazy. while the car is running with a voltmeter on the battery its reading 14v wouldnt that show the it isn't my alt. going bad?
Old 05-20-2009, 02:47 PM   #26
clark
clark's Avatar
did you check my previous post?
i had the same problem, i had a loose alternator connection and the posi terminal was grounding out as well.
get a plastic washer, clean the alternator connections.
Old 05-20-2009, 02:51 PM   #27
blackej7
blackej7's Avatar
blackej7 is just really niceblackej7 is just really niceblackej7 is just really niceblackej7 is just really niceblackej7 is just really niceblackej7 is just really niceblackej7 is just really niceblackej7 is just really niceblackej7 is just really nice
crazy nissan. (this is for 89')
blackej7 is offline   Reply With Quote
Old 05-20-2009, 03:09 PM   #28
Solidus311
Solidus311's Avatar
Solidus311 is making a name for him/her selfSolidus311 is making a name for him/her self
Oh wow, I guess that explains why my light stayed on all the time. I had a leak in one of my calipers and constantly had to replace the brake fluid before finally replacing the caliper itself. I thought my ebrake sensor was faulty.
cardomain.com/ride/3113705
Solidus311 is offline   Reply With Quote
Old 05-21-2009, 01:38 AM   #29
GuardianLlama
no buzzing noise and alt connection was cleaned
alt connection checked. and i don't think posi is grounding out.
plastic washer? where? positive source on the alt?
Old 06-14-2009, 11:26 PM   #30
240Zfunahollic
240Zfunahollic is an unknown quantity at this point
i know this is old... but check the 10 amp eng cont fuse next to the battery... That causes the combo light ive blown that a few times...
http://zilvia.net/f/image.php?type=sigpic&userid=15347&dateline=123195  6786
Visit My Trader rating page
http://zilvia.net/f/traderratings.html?u=15347
240Zfunahollic is offline   Reply With Quote
