Old 03-27-2003, 05:58 AM   #1
DMC
DMC's Avatar
DMC is an unknown quantity at this point
Head Gasket?
I was cleaning my engine the other day and saw that where the head meeets the block there is a string/rubber like material that hangs down in many places. This means I need a new head gasket? also in my spark plug holes it is black almost to the top, does this have anything to do with the head gasket, if not any ideas waht it could be? How often does needing a new head gasket happen? Should i replace it soon? thanks alot
DMC is offline   Reply With Quote
Old 03-27-2003, 06:33 AM   #2
HaLo
from Canada, eh!
HaLo's Avatar
HaLo is close to perfectionHaLo is close to perfectionHaLo is close to perfectionHaLo is close to perfectionHaLo is close to perfectionHaLo is close to perfectionHaLo is close to perfectionHaLo is close to perfectionHaLo is close to perfectionHaLo is close to perfectionHaLo is close to perfection
Send a message via ICQ to HaLo Send a message via AIM to HaLo Send a message via MSN to HaLo
Did you feel any performance loss? If your head gasket is blow, you would lose compression on at least one piston.
As for the sparkplug, change it and look if it gets dark to the top again. You might be running extra rich.
-> HaLo
Race Car: '98 E36 BMW M3
Daily Drivers: '23 Audi Q4 e-tron & '13 VW Touareg
SOLD: 01 GPW Honda S2000
PARTED: 93 Pearl White 240SX LE Fastback w/SR20DET
SOLD: 93 Super White 240SX SE Convertible w/Silvia Front
HaLo is offline   Reply With Quote
Old 03-27-2003, 10:20 AM   #3
DMC
DMC's Avatar
how do i replace it? no i havent felt loss
Old 03-27-2003, 10:31 AM   #4
AceInHole
Autox Technician
AceInHole's Avatar
AceInHole is close to perfectionAceInHole is close to perfectionAceInHole is close to perfectionAceInHole is close to perfectionAceInHole is close to perfectionAceInHole is close to perfectionAceInHole is close to perfectionAceInHole is close to perfectionAceInHole is close to perfectionAceInHole is close to perfectionAceInHole is close to perfection
replacing the headgasket is a long arduous process. before you start doing that... where exactly on the block was the string stuff hanging?? front timing chain cover?? below the exhaust manifold??
as for the spark plug holes.... seems like there might be a valve cover leak, or your spark plugs aren't seating correctly. clean out the spark plug holes with carb cleaner or brake cleaner, and blow out all debris before removing the plugs, then blow out all debris before installing plugs. this is very important!! debris on the plug seat or threads could lead to damage! if you don't have an air compressor, you could always use a can of compressed air, or remove the plugs and unplug the injectors and crank the engine to blow everything out.
AceInHole is offline   Reply With Quote
