Old 05-04-2009, 08:59 AM   #1
DDDsquad_s13panda
DDDsquad_s13panda is making a name for him/her selfDDDsquad_s13panda is making a name for him/her self
N/A SR sputtering when flooring it @ 3500???
Oright well since i got my car up and running due to faulty fuel pump, i had yet came across another problem, but never really thought anything of it.
Problem:
Everytime i floor it, no matter what gear im in, it will sputter as if its choking after 3500 rpm and it will keep goin until i get to rev limit which is 7300.
but when i drive fine and slowly increase my RPM, it would do just fine, but not as much of a sputter.
Im really leaning on to doing a full tune-up such as new spark plugs. plug wires, rotor and cap..
But i just want another opinion before i convert everything from OEM to MSD/NGK.
am i on the right track or i should check something else out first?
Is there anywhere else this problem is coming from? besides the sparks thats it... ?
Thanks in advance,
-john
EDIT: my mods if it helps
short ram intake
APexi power filter
370cc injectors
DET manifold
walbro 255 fuel pump
Z TT fuel filter
DDDsquad_s13panda is offline   Reply With Quote
Old 05-04-2009, 09:01 AM   #2
SidewayZ-s14
SidewayZ-s14 will become famous soon enoughSidewayZ-s14 will become famous soon enoughSidewayZ-s14 will become famous soon enoughSidewayZ-s14 will become famous soon enough
Do everything that you said you were going to do, and then purchase yourself a new fuel filter.
SidewayZ-s14 is offline   Reply With Quote
Old 05-04-2009, 10:50 AM   #3
ixfxi
Guest
Posts: n/a
check your ignition to sparkplug connections, could have water in there
Old 05-04-2009, 03:53 PM   #4
DDDsquad_s13panda
WOW really no more inputs besides these two?..
well thanks sidewayZ and ixfxi. ill go ahead and check those two.
Old 05-04-2009, 04:09 PM   #5
johngriff
johngriff's Avatar
tps voltage check?
[email protected]
Old 05-05-2009, 07:27 AM   #6
s14unimog
s14unimog's Avatar
Trader Rating: (22)
s14unimog has a reputation beyond reputes14unimog has a reputation beyond reputes14unimog has a reputation beyond reputes14unimog has a reputation beyond reputes14unimog has a reputation beyond reputes14unimog has a reputation beyond reputes14unimog has a reputation beyond reputes14unimog has a reputation beyond reputes14unimog has a reputation beyond reputes14unimog has a reputation beyond reputes14unimog has a reputation beyond repute
Feedback Score: 22 reviews
Send a message via AIM to s14unimog
$20 says its a bad coil pack...
nvm its an N/A model....
check to see if your MAFS is responding correctly. You can watch the signal voltage with a multimeter and blow through the MAFS its self. Also verify that base voltage is correct and there is continuity to the frame.
GL
Fu*king ginger bread man stole my wallet...
SHIFTlock_slide to side
d3m3rs0n: if i have a baby im naming it Brandons Fault Emerson
s14unimog is offline   Reply With Quote
Old 05-05-2009, 07:49 AM   #7
fliprayzin240sx
Man w/ CTSV & a Car Seat
fliprayzin240sx's Avatar
Water temp sensor or o2 sensor...
CLICK HERE!!!
Old 11-27-2009, 04:45 PM   #8
jaebo
jaebo is an unknown quantity at this point
my car was doing that same exact thing..n it only got worse as i replaced everything that wasnt bad, come to find out it was my fuel tank that was rusting out n clogging up everything. fuel tank strainer filter n injectors etc. take off ur fuel filter n bang out everything in it. if rusty gas comes out or it sounds like sand is in there then you got the same prob
jaebo is offline   Reply With Quote
