Old 05-11-2009, 06:42 PM   #1
miklos
miklos's Avatar
miklos has made poor choicesmiklos has made poor choicesmiklos has made poor choicesmiklos has made poor choicesmiklos has made poor choicesmiklos has made poor choicesmiklos has made poor choices
S13 1990 2 Switches at Clutch Pedal?
I have one switch with a button and when you depress the clutch pedal there is a hole in the bar which doesn't press the button.
There are "??" where the hole is.
What is this switch and why the hole?
Then there is another switch higher up.
What is this switch for?
miklos is offline   Reply With Quote
Old 05-11-2009, 08:52 PM   #2
Norty
Norty is an unknown quantity at this point
The first switch is the interlock switch. Clutch has to be pressed to start car. The second is for the cruise controll, if you touch the clutch pedal it disengauges the cruise controll. The hole is supposed to have a little stopper in it. They are bad about falling out.
Norty is offline   Reply With Quote
Old 05-11-2009, 09:00 PM   #3
hOngsterr
Bandwagon.
hOngsterr's Avatar
Trader Rating: (73)
hOngsterr is an unknown quantity at this point
Feedback Score: 73 reviews
yeah what he said,
i guess its a safety feature,
so you have to have your foot depressed
to start the car.
- Hong
OCD isn't so bad just means you'll spend more money then most people, but you'll have a quality car not a POS put together with POS parts.
Old 05-11-2009, 09:44 PM   #4
miklos
miklos's Avatar
Switch
So this is the clutch interlock switch? The one higher up.
And My cruise control stopped working--would the missing stopper cause it to not work?
Old 05-13-2009, 01:00 AM   #5
Norty
The switch that is closest to the firewall is the interlock switch. It requires the little plug thing. The one closest to you (or the seat) is for the cruise control. It actually doesn't use the same stopper so I can't say why your cruise control isn't working.
Old 05-13-2009, 08:14 AM   #6
projectRDM
projectRDM's Avatar
The switch with two green wires is the cruise cancel. Interlock switch will have a black wire on it.
FORMERLY R240NA
