Old 03-31-2003, 02:04 PM   #1
A Dying Devotion
A Dying Devotion is an unknown quantity at this point
Send a message via AIM to A Dying Devotion
Compression
I just did a compression test on my 89 with 201,000 miles here are the results of my test:
Cylinder 1: 152
Cylinder 2: 155
Cylinder 3: 152
Cylinder 4: 152
Engine runs really strong but im not sure if those #'s are good or not could anyone give me some factory #'s so I can compare. Thanks.
Your my blessing in disquise, you make me realize, just where I want to be years from now.
A Dying Devotion is offline   Reply With Quote
Old 03-31-2003, 02:12 PM   #2
kandyflip445
kandyflip445's Avatar
They are fine. The slightly lower compression ratio is due to wear. An interesting thing i heard of one time is that compression being lower across all cylinders COULD also be cause by VERY SMALL timing problems.....I don't really wanna get in to it right now but I'm sure someone could figure out what I'm talking about.
Old 03-31-2003, 05:07 PM   #3
A Dying Devotion
So im pretty much in the average range of compression? Is their anything I could do to bring those #s up. Also what type of spark plug wires do you guys recommend. I bought some NGK plugs today but still need the wires, thanks a bunch.
Old 03-31-2003, 07:24 PM   #4
Kreator
Kreator's Avatar
Kreator will become famous soon enoughKreator will become famous soon enoughKreator will become famous soon enough
umm those are quite low. 140 is a factory rebuild time.
There is nothing u can really do about it, but it's fine, and i'd really not get into rebuilding it. Drive it while it lives, swap it out when it dies.
кто болеет за Зенит, у того всегда стоит!
Kreator is offline   Reply With Quote
Old 03-31-2003, 07:26 PM   #5
Tuck&Poke
Tuck&Poke is an unknown quantity at this point
Send a message via AIM to Tuck&Poke Send a message via Yahoo to Tuck&Poke
what are the factory compression numbers for a ka24de, im looking at one for sale and i wanna check the compression cause its got kinda high miles (103K) for a 96'. im gonna see it this weekend or friday.
Tuck&Poke is offline   Reply With Quote
Old 03-31-2003, 07:43 PM   #6
Fibercus
Fibercus is on a distinguished road
Send a message via AIM to Fibercus
Anyone know the factory compression? on a brand new KA24DE
Fibercus is offline   Reply With Quote
Old 03-31-2003, 07:56 PM   #7
Tuck&Poke
could be that timing is advanced or retarded and a valve is slightly open at the top of the stroke....? i dunno im speculating w/ somewhat limited knowledge of engines....
Old 03-31-2003, 09:13 PM   #8
kandyflip445
Yes it has to do with the timing being slightly retarded(what a pun....). The intake valve would be opened a little later then it should be and the exhaust would be open later also......but this is still a "theory" to me....I haven't tested it out yet. I'm supposed to in my automotive class. My teacher heard it from another technician and he's the one that told me about it. I'll let you guys know what we find though when we get around to it.
Old 04-01-2003, 10:28 AM   #9
Tuck&Poke
no ones got the numbers?
Old 04-01-2003, 11:15 AM   #10
Kreator
Kreator's Avatar
180psi
another thing to kill the compression is use low octance gas. In a long run it'll wear the piston rings down
Old 04-01-2003, 11:22 AM   #11
kalieaire
kalieaire's Avatar
kalieaire is an unknown quantity at this point
Send a message via ICQ to kalieaire
151 psi is min.
179 is max.
(why the heck does zilvia not let me post??)
put oil in the cylinder the next time you do a compression test, and make sure your efi fuse is disconnected, and floor it when you turn over your engine.
if the capfull of oil brings the compression up, your rings are worn, if not, it's the valves.
'93 240sx coupe
'93 taurus wagon
-kalieaire (maybe grinder too on special occasions)
kalieaire is offline   Reply With Quote
