Old 05-27-2009, 11:23 PM   #1
ttLOVEjh s13
ttLOVEjh s13's Avatar
ttLOVEjh s13 is an unknown quantity at this point
Send a message via AIM to ttLOVEjh s13
5 bolt vlsd axel in a 6 bolt welded diff ok??
so i got a new welded diff to go into my s13 and it has a 6 bolt pattern. i lifted my car and found that the vlsd i had has a 5 bolt pattern.. if i pull out the 5 bolt axle thing and put it into the new welded diff would it still work??
GamerTag:JHLOVETT
ABS?? We dont need ABS where we'er going
ttLOVEjh s13 is offline   Reply With Quote
Old 05-27-2009, 11:52 PM   #2
essforteen
essforteen's Avatar
Trader Rating: (50)
essforteen has a brilliant futureessforteen has a brilliant futureessforteen has a brilliant futureessforteen has a brilliant futureessforteen has a brilliant futureessforteen has a brilliant futureessforteen has a brilliant futureessforteen has a brilliant futureessforteen has a brilliant futureessforteen has a brilliant futureessforteen has a brilliant future
Feedback Score: 50 reviews
No If its a VLSD then the half shaffts from the vlsd will not match the welded
You need open diff half shafts
essforteen is offline   Reply With Quote
Old 05-27-2009, 11:53 PM   #3
R@ddy
Trader Rating: (32)
R@ddy is not welcome here anymoreR@ddy is not welcome here anymoreR@ddy is not welcome here anymoreR@ddy is not welcome here anymoreR@ddy is not welcome here anymoreR@ddy is not welcome here anymoreR@ddy is not welcome here anymoreR@ddy is not welcome here anymoreR@ddy is not welcome here anymoreR@ddy is not welcome here anymore
Feedback Score: 32 reviews
okay. so you have 5 bolt axles and you're trying to put in a diff that has 6 bolt flange? not gonna happen buddy. give me your vlsd and axles and I'll give you my 6 bolt axles
R@ddy is offline   Reply With Quote
Old 05-27-2009, 11:57 PM   #4
Dousan_PG
Dousan_PG's Avatar
pull both out (the 6 and the 5 bolt)
check lengths
if length is same, should be fine i believe
doesnt work? go j30 axles ( 5 bolt)
Aaron
Pink GodziRa
Old 05-28-2009, 12:24 AM   #5
johngriff
johngriff's Avatar
check lengths
No, he has 5 bolt axles.
You need to go back to 6 bolt axles. Common 240sx fare
[email protected]
Old 05-28-2009, 01:06 AM   #6
ttLOVEjh s13
problem solved im just gona buy some used s13 half shaft.... so anyone have a pair..?
GamerTag:JHLOVETT
Old 05-28-2009, 01:57 PM   #7
mazersx
Banned from the Marketplace
Trader Rating: (32)
mazersx is an unknown quantity at this point
Send a message via AIM to mazersx
i got a s14 pair you can have..
and yes i actually have the 6 bolt axles but its on the car
mazersx is offline   Reply With Quote
Old 05-28-2009, 10:54 PM   #8
waynehead05
waynehead05 has a spectacular aura aboutwaynehead05 has a spectacular aura aboutwaynehead05 has a spectacular aura aboutwaynehead05 has a spectacular aura aboutwaynehead05 has a spectacular aura aboutwaynehead05 has a spectacular aura aboutwaynehead05 has a spectacular aura about
Send a message via AIM to waynehead05
I have some 6 bolt. If you can't find any locally I'll ship them out to you. Just pm me cause I doubt I'll check this thread again.
Who in their right mind would want to lead this nation of Me-First Right-Now Do Nothings??
waynehead05 is offline   Reply With Quote
