Old 04-04-2003, 07:55 PM   #1
DamnedButDetermined
DamnedButDetermined's Avatar
DamnedButDetermined is an unknown quantity at this point
Does a S14 brake booster fit a S13?
I need to replace mine and have found someone willing to sell theirs from an S14.
-DbD-
DamnedButDetermined is offline   Reply With Quote
Old 04-04-2003, 09:45 PM   #2
AKADriver
AKADriver's Avatar
yes.
ABS and non-ABS aren't compatible, though, so make sure you get the right part.
Old 04-05-2003, 01:42 PM   #3
sykikchimp
WOW addicted
sykikchimp's Avatar
sykikchimp has a spectacular aura aboutsykikchimp has a spectacular aura aboutsykikchimp has a spectacular aura aboutsykikchimp has a spectacular aura aboutsykikchimp has a spectacular aura aboutsykikchimp has a spectacular aura about
Send a message via AIM to sykikchimp
weird.. I thought the only difference was that there were a couple extra holes that you could plug up?
sykikchimp is offline   Reply With Quote
Old 04-05-2003, 06:32 PM   #4
AKADriver
AKADriver's Avatar
Well, yeah.
ABS master cylinders have one less open port. Non-ABS have three ports (left front, right front, both rear). ABS have two (both front, both rear).
Old 04-05-2003, 06:49 PM   #5
andrave
andrave's Avatar
andrave is an unknown quantity at this point
Send a message via AIM to andrave
really?
i thought the abs one had 3 also, because the s13 abs used both rears on the same "channel"???
andrave is offline   Reply With Quote
Old 04-05-2003, 06:55 PM   #6
AKADriver
AKADriver's Avatar
Well, exactly. The S13/S14 ABS system is three-channel.
The ABS-equpped cars' master cylinder has two ports; one for front, one for rear. The ABS unit splits the fluid flow for the front internally and does the two front channels. It treats the rear fluid flow as one channel.
The non-ABS cars' master cylinder does the split for the front wheels itself, so it has three ports.
ch' ch' check it out:
This is basically straight out of my 1990 FSM.
Old 04-05-2003, 07:38 PM   #7
andrave
andrave's Avatar
I did not realize that, thank you for clearing that up.
I'm very confused now.
I was at a junkyard in florida and came across a 240 with a different arrangement than mine had (mine is non abs) and I assumed it was ABS, it had I believe 3 outputs, but it was obviously a lot different than mine is.
do dohc cars and sohc use different master cylinders?
Old 04-05-2003, 10:35 PM   #8
AKADriver
AKADriver's Avatar
DOHC and SOHC use the same m/c.
Old 04-06-2003, 12:27 AM   #9
sykikchimp
WOW addicted
sykikchimp's Avatar
So the ABS-NC has only 2 ports? or does it have 3 ports, and one is closed from the factory?
I seem to remember seeing a 300zx ABS MC that came from the factory with one plugged port, and 2 open... I assumed that they used the same MC to save in production caosts?
Old 04-06-2003, 01:35 AM   #10
AKADriver
AKADriver's Avatar
Hmmm... yeah, that might be true.
The hard part is getting that fitting for the plugged port. IIRC people ended up having to destroy their old M/C to get the fitting out.
Old 04-07-2003, 12:37 PM   #11
d240t2
d240t2 is an unknown quantity at this point
Send a message via AIM to d240t2
But isn't the original question about brake boosters, not MCs?
For boosters...the vacuum port is on opposite sides. Other than that, it is interchangeable, as far as I know. You'd need to redo the vacuum hose to reach, or get the S14 hose to match the booster. Seems easier to just swap the right one.
As for MCs, it is silly to swap S14/S13 MCs. Internally, they are roughly the same (neither is an upgrade for the other), but the line placement is completely different. You'd waste at least half an hour rebending the lines, when you should have just gotten the right MC, or done an upgrade that warrants bending of the lines).
Dennis
d240t2 is offline   Reply With Quote
