Old 06-04-2009, 12:33 AM   #1
slider2828
slider2828's Avatar
Unhappy S14sr into S13 Won't Start
Hey Guys,
I am having trouble with my friends swap. I basically did the wiring myself and pretty sure everything is plugged up correctly. Spark OK, Fuel Pump Turns On and smell fuel OK, ECU Blue Relays Click on and Off....
I haven't checked timing or compression, because the motor was freshly rebuilt and the CAS was stabbed in by the builder. I mean he rebuilt my engine and it turned over first time no problems.
Just a couple of questions, the check engine light is on when I put it in the on position, from what I hear this means the ecu has power correct?
Is there anyway to pull codes from the "WC" ecu? This motor and ecu came out of a clip so I am pretty sure the ecu is correct.
I removed all the stock turbo recirculation electronics and boost solenoid electronics, will this affect startup?
Thanks a million everyone for your help.
-Ken
Turn and Burn!
Old 06-05-2009, 11:05 AM   #2
slider2828
slider2828's Avatar
Fixed.... Stupid friend who put in the motor, took out the F....ing CAS and stabbed it back in not caring what position.... Retards....
Turn and Burn!
