Old 06-08-2009, 12:41 PM   #1
mauris13
mauris13 is an unknown quantity at this point
i need help.. my sr dont start. pleaseee
well 3 weeks ago i was just trying to drift in my 240 and then the car just turn off and didn't start anymore. the fuel pump was working and i had spark. then i buy the cas because a mechanic told me that was the problem. but wen i put the new cas same thing didn't start but now the fuel pump was not working and i had no spark. my ignitor chip its working so i don't know what the problem is. pleeaseeee HEELLPP!!
one more thing... i check my ecu and it's not getting power. my fuel pump fuse its working but the next one its the eccs fuse its no getting power when i turn the kkey on. help
mauris13 is offline   Reply With Quote
Old 06-08-2009, 02:49 PM   #2
reelyfast
reelyfast is an unknown quantity at this point
check for compression, correctly timed spark, etc.
if your ecu isnt getting power, then look in to why it isnt. because i *think* that's a pretty vital piece to your car running.
good luck
reelyfast is offline   Reply With Quote
Old 06-08-2009, 02:56 PM   #3
slider2828
slider2828's Avatar
ECCS is the FLT ATL are the two ones that can blow your ecu. Check the fuse for continuity. If there is, then ECU might be friend. Sounds like you shorted something.
Turn and Burn!
Old 06-08-2009, 05:28 PM   #4
mauris13
i check the eccs relay located next to the battery and its no getting power. with the key off it shows ground but with the key on it doesn't show power stills ground... you don't think can be the harness wiring?
Old 06-08-2009, 05:39 PM   #5
JohnnyDrfiter22
JohnnyDrfiter22's Avatar
JohnnyDrfiter22 has a spectacular aura aboutJohnnyDrfiter22 has a spectacular aura aboutJohnnyDrfiter22 has a spectacular aura aboutJohnnyDrfiter22 has a spectacular aura aboutJohnnyDrfiter22 has a spectacular aura aboutJohnnyDrfiter22 has a spectacular aura about
crack open the ECU and check to see if its fried
JohnnyDrfiter22 is offline   Reply With Quote
Old 06-08-2009, 05:45 PM   #6
mauris13
how can i tell if its fried or not? or is it just obvious
Old 06-08-2009, 06:31 PM   #7
flip3d
flip3d's Avatar
flip3d has a reputation beyond reputeflip3d has a reputation beyond reputeflip3d has a reputation beyond reputeflip3d has a reputation beyond reputeflip3d has a reputation beyond reputeflip3d has a reputation beyond reputeflip3d has a reputation beyond reputeflip3d has a reputation beyond reputeflip3d has a reputation beyond reputeflip3d has a reputation beyond reputeflip3d has a reputation beyond repute
Send a message via AIM to flip3d
Smell it. See if anything is burnt.
flip3d is offline   Reply With Quote
Old 06-08-2009, 07:16 PM   #8
slider2828
slider2828's Avatar
Opening it doesn't always tell you.... Wait its a relay and you get 0 power to any of those relays? Then also you when you key on, you don't hear any clicking on those blue relays either for the ecu? If S13 relays are at the front of the passenger side, if S14, relays are inside next to the ecu.
Turn and Burn!
Old 06-08-2009, 09:05 PM   #9
mauris13
only the relay that is not working is the eccs. its the relay that is next to the batery. and the others are working good. so i don't know why is just the one of eccs the one its not working.
Old 06-09-2009, 12:08 AM   #10
slider2828
slider2828's Avatar
Maybe the relay went out, replace it with one of the same color ones and try it....
Turn and Burn!
Old 06-11-2009, 10:50 AM   #11
mauris13
already did that.. and same thing.. don't start.
Old 06-11-2009, 11:26 AM   #12
slider2828
slider2828's Avatar
Get another ECU and try it.....
Turn and Burn!
Old 06-11-2009, 11:41 AM   #13
Projectenzo
Projectenzo is an unknown quantity at this point
Check that your battery has 12 volts on it. your car won't start if it doesn't, if it doesn't crank then check your clutch interlock switch located under you clutch pedal.
Projectenzo is offline   Reply With Quote
Old 06-11-2009, 11:57 AM   #14
mauris13
what does the clutch interlock switch does? do you think thats why the fuel pump and the skpark dont work?
Old 06-11-2009, 12:32 PM   #15
slider2828
slider2828's Avatar
Nope clutch interlock will stop it from starting, but DOES NOT stop fuel pump priming when ignition is in the on position.....
Turn and Burn!
Old 06-11-2009, 12:45 PM   #16
mauris13
ohh ok thanks.. now i don't know what else i can try to see if my sr start. i have one month that the car don't start.
Old 06-11-2009, 02:37 PM   #17
slider2828
slider2828's Avatar
try another ecu definitely....
Turn and Burn!
Old 06-11-2009, 02:53 PM   #18
mauris13
do you mean to buy a new ecu? mm.. i'm going to try take all the harness out and chek if its all conected right. and if its right i think i will buy a new ecu. or can i put one of my friends sr's and then chek if its that the problem..
Old 06-11-2009, 03:00 PM   #19
sc ka24e
sc ka24e's Avatar
sc ka24e has a spectacular aura aboutsc ka24e has a spectacular aura aboutsc ka24e has a spectacular aura aboutsc ka24e has a spectacular aura aboutsc ka24e has a spectacular aura aboutsc ka24e has a spectacular aura about
just make sure its the same # on ecu
sc ka24e is offline   Reply With Quote
Old 06-22-2009, 11:51 AM   #20
mauris13
hey thanks everybody finally my car its working.. the problem was a burnt circuit on the ecu.. i really appreciate your help..
