Old 06-16-2009, 06:35 PM   #1
Eastside DriFto
Eastside DriFto is an unknown quantity at this point
s13 Z32 maf problem
So I just installed a z32 maf,and the car starts to break up around 4-5 grand.I have a gt2871r .64a/r,running 7psi on the STOCK 370cc injectors(sti injectors at the end of the week).Oyea and I'm running nistune.
Any suggestions?Bad maf?
Eastside DriFto is offline   Reply With Quote
Old 06-17-2009, 07:48 AM   #2
0wn3r
0wn3r's Avatar
0wn3r has much to be proud of0wn3r has much to be proud of0wn3r has much to be proud of0wn3r has much to be proud of0wn3r has much to be proud of0wn3r has much to be proud of0wn3r has much to be proud of0wn3r has much to be proud of0wn3r has much to be proud of0wn3r has much to be proud of0wn3r has much to be proud of
did u clean the MAF before you put it in?
97 240sx se
0wn3r is offline   Reply With Quote
Old 06-17-2009, 08:51 AM   #3
Eastside DriFto
Now that is somthing I mite need to go do..That could diffinitly be the problem..Thanks ,I didn't think of that..Ill let you know,Im about to work on it in an hour.. Thanks again for the suggestion.
Old 06-17-2009, 08:56 AM   #4
clark
clark's Avatar
clark is close to perfectionclark is close to perfectionclark is close to perfectionclark is close to perfectionclark is close to perfectionclark is close to perfectionclark is close to perfectionclark is close to perfectionclark is close to perfectionclark is close to perfectionclark is close to perfection
do you have an AFC to control the z32 maf? i believe you need one of those to compensate for the difference from the stock MAF.
nvm, nice ninja edit on the last sentence stating you're running nistune. but the question still stands. did you update the rom for the new maf?
clark is offline   Reply With Quote
Old 06-17-2009, 09:24 AM   #5
Eastside DriFto
^^^^No need from an update.My Nistune is real time.Yea we changed it,and compensated for the difference..I am going to go and clean it and see if that helps.
