Old 06-16-2009, 10:33 PM   #1
MrMcgarrett
MrMcgarrett's Avatar
Trader Rating: (313)
MrMcgarrett is close to perfectionMrMcgarrett is close to perfectionMrMcgarrett is close to perfectionMrMcgarrett is close to perfectionMrMcgarrett is close to perfectionMrMcgarrett is close to perfectionMrMcgarrett is close to perfectionMrMcgarrett is close to perfectionMrMcgarrett is close to perfectionMrMcgarrett is close to perfectionMrMcgarrett is close to perfection
Feedback Score: 313 reviews
Send a message via AIM to MrMcgarrett
T3 turbo
Bought this a while ago for a budget KA-T setup but I figure a T2 setup would be easier for me.
It is from a Ford Thunderbird Turbo Coupe.
Turbo has some shaft play and will need a rebuild. Rebuild kits are cheap on Ebay.
It will need new gaskets for the intake pipe and oil drain(needs a mounting bolt too).
Here are some specs I found on the turbo:
* Garrett model number: TB0322 (T3 series turbo)
* Compressor Trim: 60
* Compressor housing A/R: .60
* Turbine housing A/R: .63
* Horsepower Capabilities: ~325hp
* Internal Wastegate: Yes
* Wastegate setting: 7 psi
The wastegate flap thing is built into the outlet which I do not have so an external setup would be needed and I'm guessing that's what most people would use anyway.
$80/$100 shipped
MrMcgarrett is offline
