Old 07-14-2009, 06:51 PM   #1
basicmods
basicmods is an unknown quantity at this point
Pilot Bearing pulling tool question
Hello.
This weekend I am going doing a manual tranny swap, and went to the parts store to rent (loan for free) a slide hammer and pilot bearing pulling tool. However, the pilot bearing pulling tool that I have is too large to fit into the replacement pilot bushing. I know that I won't be using this with this bushing, but was checking it out as a guide to see what the difference would be with the bearing and bushing.
I guess my question is this - do i need to worry about the fact that the bearing pulling tool won't slide into the new pilot bushing or will I need a different bearing pulling tool? The only way this tool will work is if the bearing has a larger inner diameter than the bushing, which I find unlikely. Any help would be appreicated.
'91 240SX hatch complete with super rare sunroof insert and bag!
basicmods is offline   Reply With Quote
Old 07-14-2009, 09:03 PM   #2
fliprayzin240sx
Man w/ CTSV & a Car Seat
fliprayzin240sx's Avatar
Usually, I just drill the automatic bearing on 2 opposite side and collapse it on its own. Just be careful not to drill too deep and damage the crank. Grease up the pilot bearing tap it in gently with an extension and rubber mallet.
CLICK HERE!!!
Old 07-14-2009, 10:29 PM   #3
ManoNegra
ManoNegra's Avatar
Trader Rating: (48)
Feedback Score: 48 reviews
Have used pullers with little success in the past
packing the hole with grease and pressing a smaller
OD rod has been the best method by far
Old 07-14-2009, 10:35 PM   #4
wangan_cruiser
kouki man
wangan_cruiser's Avatar
Trader Rating: (36)
Feedback Score: 36 reviews
yea i heard that hydraulic press like
fill in with a lot of grease and keep tapping it with 11mm socket i think
i never had success with this i guess i just dont know how to do it but most mechanic told me that it can be done.
good luck
Old 07-14-2009, 10:45 PM   #5
CoreyS13
CoreyS13 is on the path to ruinCoreyS13 is on the path to ruinCoreyS13 is on the path to ruin
I took mine to local transmission shop and they had it done in 5 minutes and did it for free.
CoreyS13 is offline   Reply With Quote
Old 07-15-2009, 06:26 AM   #6
HYPNOTIK
HYPNOTIK's Avatar
HYPNOTIK is an unknown quantity at this point
Send a message via Yahoo to HYPNOTIK
I use a pipe wrench, just start turning on it and it'll work it's way out in less than 5 minutes.
HYPNOTIK is offline   Reply With Quote
Old 07-15-2009, 06:32 AM   #7
tinys s14
tinys s14's Avatar
tinys s14 is making his/her stupidity well-knowntinys s14 is making his/her stupidity well-knowntinys s14 is making his/her stupidity well-knowntinys s14 is making his/her stupidity well-knowntinys s14 is making his/her stupidity well-known
I took a hammper and chizzile and knocked that shyt out when I did my swap since I broke the pilot remover tool
tinys s14 is offline   Reply With Quote
Old 07-15-2009, 03:36 PM   #8
basicmods
thanks for the pointers everyone. I will try the bearing tool, and if it doesn't work than i may just break out the drill/hammer/vice-grips/cutting torch or whatever else it takes to get it out. I like the idea of packing it with grease then pushing through the middle to push it out, seems like it would work pretty well.
Thanks again.
Old 07-15-2009, 11:36 PM   #9
carnagexxxx
carnagexxxx's Avatar
Trader Rating: (-1)
carnagexxxx is a splendid one to beholdcarnagexxxx is a splendid one to beholdcarnagexxxx is a splendid one to beholdcarnagexxxx is a splendid one to beholdcarnagexxxx is a splendid one to beholdcarnagexxxx is a splendid one to beholdcarnagexxxx is a splendid one to beholdcarnagexxxx is a splendid one to beholdcarnagexxxx is a splendid one to beholdcarnagexxxx is a splendid one to beholdcarnagexxxx is a splendid one to behold
Feedback Score: -1 reviews
buy this:
- Harbor Freight Tools - Quality Tools at the Lowest Prices
If you need advice on what part to use, let me know. Best $20 I spent.
carnagexxxx is offline   Reply With Quote
Old 07-15-2009, 11:51 PM   #10
4sfed180
4sfed180's Avatar
4sfed180 can only hope to improve
Send a message via AIM to 4sfed180
here is the process:
step 1. buy some wonder bread
step 2. insert wonder bread in hole
step 3. put in a socket or metal rod that just fits in
step4. repeat step 2 until the bearing comes out.
this way the clean up is easier and faster then grease. all you need to do is pick the piece of compressed wonder bread out of the crank
PS... you can use any white bread. doesnt have to be a name brand "wonder bread"
I build air pumps!
4sfed180 is offline   Reply With Quote
Old 07-16-2009, 12:09 AM   #11
FREDDYS13
FREDDYS13's Avatar
FREDDYS13 is on a distinguished road
go to auto zone and get ur self a blind hole puller ill take you about a min to take it off ive done it couple times works good ,dont waist ur time with the pilot bearing puller or anything else save your self a lot of trouble
FREDDYS13 is offline   Reply With Quote
Old 07-16-2009, 12:22 AM   #12
roboticnissan
roboticnissan's Avatar
roboticnissan is making a name for him/her selfroboticnissan is making a name for him/her selfroboticnissan is making a name for him/her self
wow man just hit up autozone tell them what car you have and they need to give you the right puller. i just did this this past weekend and it took one pull of the slide hammer and it came right out fuck drilling that bitch out
roboticnissan is offline   Reply With Quote
Old 07-16-2009, 06:40 AM   #13
basicmods
thats basically what i did, told them i was needing the puller to pull the bearing out and they gave me this -
along with a slide hammer.
Problem is, on the bushing at least, the teeth are just a bit too wide to fit. I'm hoping I don't have the same problem with the bearing.
Old 07-16-2009, 11:22 PM   #14
4sfed180
4sfed180's Avatar
that shit doesnt work. my boss has that one for doing VW engines and it works.
doesnt fit a nissan though.
I build air pumps!
Old 07-17-2009, 11:24 PM   #15
96Turbo
96Turbo's Avatar
96Turbo has a reputation beyond repute96Turbo has a reputation beyond repute96Turbo has a reputation beyond repute96Turbo has a reputation beyond repute96Turbo has a reputation beyond repute96Turbo has a reputation beyond repute96Turbo has a reputation beyond repute96Turbo has a reputation beyond repute96Turbo has a reputation beyond repute96Turbo has a reputation beyond repute96Turbo has a reputation beyond repute
grease method ftw. seriously.... took me like 5 min. and grease is practically free if you've already got some
96Turbo is offline   Reply With Quote
Old 07-18-2009, 06:32 AM   #16
basicmods
ok, so tried the grease method - didn't work. Tried the puller - broke it. Ended up drilling it out and then taking a hammer and chisel. Surprisingly, had I tried this way first, it would have taken much much less time. I tried the grease method for an over and hour, and used everything from a 8 lb sledge to an impact hammer to try and get it out. The pullers broke after a dozen attempts. The drill/chisel method took maybe 15 mins.
Old 07-18-2009, 02:15 PM   #17
dongoesby
dongoesby's Avatar
dongoesby is a glorious beacon of lightdongoesby is a glorious beacon of lightdongoesby is a glorious beacon of lightdongoesby is a glorious beacon of lightdongoesby is a glorious beacon of lightdongoesby is a glorious beacon of lightdongoesby is a glorious beacon of lightdongoesby is a glorious beacon of lightdongoesby is a glorious beacon of lightdongoesby is a glorious beacon of lightdongoesby is a glorious beacon of light
I just took mine out with this. Same puller i rent from autozone.
Yes, it doesn't fit in nissan's pilot bushing perfectly. It it is like 2mm or less to fit in the diameter, but I managed to fit it in no problem with a hammer. Then just pull with your favorite method. It took me 10 mins to take mine out.
Hope it helps.
dongoesby is offline   Reply With Quote
Old 07-18-2009, 05:40 PM   #18
flip3d
flip3d's Avatar
flip3d has a reputation beyond reputeflip3d has a reputation beyond reputeflip3d has a reputation beyond reputeflip3d has a reputation beyond reputeflip3d has a reputation beyond reputeflip3d has a reputation beyond reputeflip3d has a reputation beyond reputeflip3d has a reputation beyond reputeflip3d has a reputation beyond reputeflip3d has a reputation beyond reputeflip3d has a reputation beyond repute
Send a message via AIM to flip3d
grease method worked perfect for me a couple times.
had to dremel one out once.
flip3d is offline   Reply With Quote
Old 07-18-2009, 07:34 PM   #19
89_240jdm
89_240jdm's Avatar
Trader Rating: (183)
89_240jdm is on the path to ruin89_240jdm is on the path to ruin89_240jdm is on the path to ruin
Feedback Score: 183 reviews
Talking
Hope it helps.
I just took mine out with this. Same puller i rent from autozone. it took me 5 mins to take mine out ,,,,,^^^^^and 3 mins to put in the bronze ring...
89_240jdm is offline   Reply With Quote
Old 07-18-2009, 07:53 PM   #20
wangan_cruiser
kouki man
Trader Rating: (36)
borrowed a puller set from my friend mechanic.
1 hit and it came out. LOL
Old 07-19-2009, 01:41 AM   #21
nep
nep's Avatar
nep is a jewel in the roughnep is a jewel in the roughnep is a jewel in the roughnep is a jewel in the roughnep is a jewel in the roughnep is a jewel in the roughnep is a jewel in the rough
Easily the shittiest part of the entire swap for me. Broke the autozone bearing puller and grease method didn't work out. Ended up dremel/screwdriver/hammering that bitch out
nep is offline   Reply With Quote
Old 07-19-2009, 02:03 AM   #22
FRpilot
FRpilot's Avatar
grease method is messy and has never worked for me.
same with all the pullers i have tried. always slipped.
the only method that worked was getting a dremel with a tungsten carbide bit piece.
(it cost $20 and the guy at OSH told me tungsten carbide is the 2nd strongest thing next to diamond and would cut through anything except a diamond)
Proceeded with dremeling one side/wall of the pilot bearing till it got weak enough that i could break it apart with a flathead and chiesel. then i forced the pilot bearing to collapse on itself and got it out. only drawback to this method is that it takes a while and little metal shards get all over your shirt making you itchy as fuck.
FRpilot is offline   Reply With Quote
Old 07-19-2009, 02:08 AM   #23
s13drob
s13drob's Avatar
Trader Rating: (29)
s13drob is not welcome here anymores13drob is not welcome here anymores13drob is not welcome here anymores13drob is not welcome here anymores13drob is not welcome here anymores13drob is not welcome here anymores13drob is not welcome here anymores13drob is not welcome here anymores13drob is not welcome here anymore
Feedback Score: 29 reviews
use the slide hammer itself. put the threaded side in and hold it at an angle. then slide hammer it out using the threads to grip the bearing. dont tell autozone how you used the loaner tool haha
s13drob is offline   Reply With Quote
Old 07-19-2009, 02:44 AM   #24
bardabe
bardabe's Avatar
I weld a nut to it, and use a slide hammer works every time, takes about 5 minutes lol
Review Thread
bardabe is offline   Reply With Quote
Old 07-19-2009, 08:26 AM   #25
sac
sac's Avatar
sac is not welcome here anymoresac is not welcome here anymoresac is not welcome here anymoresac is not welcome here anymoresac is not welcome here anymoresac is not welcome here anymoresac is not welcome here anymoresac is not welcome here anymoresac is not welcome here anymoresac is not welcome here anymoresac is not welcome here anymore
Blind Hole puller from Autozone works..
I have used the grease and bread method, I say fuck those methods. Get the blind hole puller from A.Z. It is fucking free.. You go.. buy the tool, use it for MAYBE a minute, take it back, and get your money back. Cant go wrong..
part number there is 27128 i believe.. Its like $106 deposit ya gotta leave with them.
99rs coupe
Currently Collecting parts for STi swap
sac is offline   Reply With Quote
Old 07-19-2009, 09:06 AM   #26
Katsumbhong
Katsumbhong's Avatar
Katsumbhong is making a name for him/her selfKatsumbhong is making a name for him/her selfKatsumbhong is making a name for him/her self
My japanese buddies said that they use a grease gun with a fat tip and shove it over the front of the pilot bearing and start pumping and the pressure/vacuum exerted pushes the bearing out.
Katsumbhong is offline   Reply With Quote
