Old 07-15-2009, 08:36 PM   #1
roel03
roel03 is making a name for him/her selfroel03 is making a name for him/her self
Overboosting to 20psi!!!!
I just installed my boost gauge yesterday and when doing a pull boost seems to top out at 20PSI. I have a t25 setup with stock wastegate on my ka connected to my intake manifold. Turbo does not smoke but pulls hard, and engine runs awesome. The car is Enthalpy tuned. Sunday I ran it at a full AutoX without a hiccup, but just noticed how high the boost pressure is.
Shouldnt it be only 7psi? How can I get it back down? MBC? I dont really want to use that much money on an EBC as a couple track days are coming up. Any links to a good MBC? This is for reduction, not to increase
roel03 is offline   Reply With Quote
Old 07-15-2009, 08:40 PM   #2
zorak
zorak's Avatar
zorak is an unknown quantity at this point
Send a message via AIM to zorak
make your own manual boost controller. there should be a write-up around here.
zorak is offline   Reply With Quote
Old 07-15-2009, 08:42 PM   #3
roel03
Will that bring it down to my desired amount?
Old 07-15-2009, 08:49 PM   #4
khilgers
khilgers has a reputation beyond reputekhilgers has a reputation beyond reputekhilgers has a reputation beyond reputekhilgers has a reputation beyond reputekhilgers has a reputation beyond reputekhilgers has a reputation beyond reputekhilgers has a reputation beyond reputekhilgers has a reputation beyond reputekhilgers has a reputation beyond reputekhilgers has a reputation beyond reputekhilgers has a reputation beyond repute
I would check your wastegate actuator first. On my T28, untuned, no boost controller it never went past 15lbs.
khilgers is offline   Reply With Quote
Old 07-16-2009, 12:22 AM   #5
codunc
codunc's Avatar
codunc is making a name for him/her selfcodunc is making a name for him/her self
You can't lower the boost pressure with a controller, only raise it. check the actuator, and the line going to it. it should just go from the compressor housing anyway, not the intake manifold.
codunc is offline   Reply With Quote
Old 07-16-2009, 12:32 AM   #6
SidewayZ-s14
SidewayZ-s14 will become famous soon enoughSidewayZ-s14 will become famous soon enoughSidewayZ-s14 will become famous soon enoughSidewayZ-s14 will become famous soon enough
Make sure you have your vacuum lines hooked up correctly. Sounds like you have them hooked up wrong.
SidewayZ-s14 is offline   Reply With Quote
Old 07-16-2009, 12:51 AM   #7
roel03
Will check it in the morning.
