Old 07-16-2009, 02:40 PM   #1
Tantwoforty
Tantwoforty's Avatar
Tantwoforty is an unknown quantity at this point
1500 Idle ecu related?
I installed another ecu and harness into my s13 ka, and before i swapped the ecu and harness the car idled at like 600-700. after the swap i lost slot of power in the high end and i have a 1500rpm idle. could the ecu be causing this or should i look into other options. i also have a cel i didnt have before. any posative input would be great
Tantwoforty is offline   Reply With Quote
Old 07-16-2009, 10:32 PM   #2
aNskY
aNskY is close to perfectionaNskY is close to perfectionaNskY is close to perfectionaNskY is close to perfectionaNskY is close to perfectionaNskY is close to perfectionaNskY is close to perfectionaNskY is close to perfectionaNskY is close to perfectionaNskY is close to perfectionaNskY is close to perfection
Send a message via AIM to aNskY
did you do anything else beside change the harness and ecu?
aNskY is offline   Reply With Quote
Old 07-17-2009, 01:28 AM   #3
Tantwoforty
nope. maybe the ecu needs to be reset... idk
Old 07-17-2009, 01:32 AM   #4
superJoy
superJoy is a glorious beacon of lightsuperJoy is a glorious beacon of lightsuperJoy is a glorious beacon of lightsuperJoy is a glorious beacon of lightsuperJoy is a glorious beacon of lightsuperJoy is a glorious beacon of lightsuperJoy is a glorious beacon of lightsuperJoy is a glorious beacon of lightsuperJoy is a glorious beacon of lightsuperJoy is a glorious beacon of lightsuperJoy is a glorious beacon of light
I had a high idle, around 1600 rpm.
Turned out to be a bad TPS. (throttle position sensor)
May not be what's going on in your case. But if you have a spare like I did you could just throw it on and see what happens.
superJoy is offline   Reply With Quote
Old 07-17-2009, 02:00 AM   #5
Tantwoforty
oh that could be it, maybe i failed at soldering and a wire popped off, since i switched the tps to this harness, would a bad or missing tps throw a cel?
Old 07-17-2009, 02:07 AM   #6
superJoy
No idea on the CEL thing, I've never had to mess with that on my car.
I think the FSM outlines a test for the TPS where you use an ohmmeter or voltmeter or something like that. Test if it's reading right.
In any case. Could be worth looking into.
Old 07-17-2009, 02:15 AM   #7
Tantwoforty
yea i was already thinking about that, i unplugged the tps and started the car and it did the same exact thing as when it was plugged in
Old 07-17-2009, 09:43 AM   #8
slider2828
slider2828's Avatar
Its the mechanical warm up.... fast idle thing that sticks out... It happened to my friends car... Just look for fast idle in the manual. Its a piece of wax that coolant goes throgh in the TB so that when the wax melts, the idle doesn't push the throttle open. Is your throttle touching the stopper on your intake manifold.?
Turn and Burn!
