Old 04-17-2003, 11:18 AM   #1
ChillyWilly3
ChillyWilly3's Avatar
ChillyWilly3 is an unknown quantity at this point
Adjusting Steering Wheel
A while back I dropped the front suspension down slightly to get access to the oil pan on my 96 240SX. This required disconnecting the steering column knuckle from the lower rack-and-pinion steering section (it's the section right next to the power steering line). Unfortunately, I forgot to mark the two sections to get the correct alignment when I placed everything back again.
Now, when my wheels are totally straight, my steering wheel is pointing 30 degrees off to the right. Rather than going through that painful process of dropping the suspension again, is there anyway I can re-align the steering wheel just by adjusting something on the steering column.
Thanks.
ChillyWilly3 is offline   Reply With Quote
