Old 07-20-2009, 07:34 PM   #1
bl3ujay07
bl3ujay07's Avatar
bl3ujay07 is an unknown quantity at this point
CA Leaking WATER(???) from front main seal?? NO START!! HELP
Hey guys, long story short, i let my brother drive my car, 89 hatch with sr swap from Stockton (norcal) to LA, (camarillo to be exact) with his gf and her sister.
First, on their way, before they hit the grapevines, my brother said that he heard a loud sound under the car. He pulled over and found that the bottom radiator hose that connects to block cam off because the clamp (old ones) was loose and lost all the coolant. I had screw drivers and everything in my car so he re connected and poured water a 1 gallon bottle water (i assume just water because thats all i saw him bring). Then i didnt hear from him for a while. (i told him to buy new clamps and fill it up with antifreeze and water and check everything before he comes back down. No answer so i dont know if he did or did not.
So, he called me about 2 hours ago. 45-an hour from camrillo towards grapevine, he calls me and tells me my car is dead!!! He tells me he heard some clinking in engine bay, pulled over and checked it out. See some water leaking. Then tries to start the car, cranks but wont start. He says that there is WATER leaking UNDER and BY the crank pulley. He calls me and says "water is leaking from your crank shaft". I dont think so and don beleive so because how the hell can he tell, but what do you think?
Do you guys (and or gals) think the problem is? He says its leaking under and near the crankshat pulley. It cranks but doesnt start. Would a dead/laking water pump or blown front main seal cause this?
Would a blown front main seal leak water??? I am hoping it didnt overheat!!!! HELP ME OUT!!
bl3ujay07 is offline   Reply With Quote
Old 07-20-2009, 07:37 PM   #2
Bigsyke
Bigsyke's Avatar
Bigsyke is an unknown quantity at this point
You cant just refill and drive. I blew a hose once, and just filling up the radiator only filled it up maybe 50%, since there were airpockets that were trapped.
You probably blew it....it def over heated if you just fill and drive.
Bigsyke is offline   Reply With Quote
Old 07-20-2009, 07:38 PM   #3
Sileighty_85
Sileighty_85's Avatar
Its from the water pump, there is a "weep hole" on the bottom of the water pump so when the water pump seal goes out water will "weep" out of it, since the W/P is right above the C/S its probably giving the apperance of water comming from the Crank
as far as the car not starting not sure why that would happen,
if it over heated the H/G more than likely blew, tell him to check the oil's color, if it looks like chocolate milk then the head gasket is blown
後輪駆動車1番
1989 Built SR GT2871R -363whp
1986 SR86 - 200ish
1990 R32 GTR - 320hp
Old 07-20-2009, 07:39 PM   #4
Bigsyke
Bigsyke's Avatar
^^^possibly because the tstat didnt open due to air pocket, and the head warped extremely?
Old 07-20-2009, 07:40 PM   #5
bl3ujay07
bl3ujay07's Avatar
^^^He says that there is still coolant in the radiator and doesnt seem like any kind of mixing between oil coolant.
Im thinking HE blew the engine, but just want to know for sure before i make a damn 10 hour mission getting the damn car back to stockton.
Old 07-20-2009, 07:42 PM   #6
bl3ujay07
bl3ujay07's Avatar
Just recently, new nismo thermostat, 2" aluminum radiator, s14 e-fan, and new coolant to make sure my shit dont over heat. It had a cheap metal cometic hg btw.
Old 07-20-2009, 07:45 PM   #7
Bigsyke
Bigsyke's Avatar
ouch! usually that doesnt help at all, unless you have a swirl tank, even still you need to bleed it if you ever have an opening in the coolant system.
Bro radiator could be full, but if the thermostat doesnt open up the air gets trapped in the front cover- it would seem the radiator is full, but you will never know untill the lower hose and cover gets HOT. Even still unless the radiator cap is off, its only a matter of time the air pockets collect and block the tsat
Old 07-20-2009, 08:15 PM   #8
bl3ujay07
bl3ujay07's Avatar
^^^Im affraid he either didnt bleed it or worst, didnt even put coolant but just water in it. Damn. Right when someone called to by the damn car too!!! So much for getting my g20.
Old 07-20-2009, 08:33 PM   #9
Sileighty_85
yeah if not bled properly it will over heat, Stock temp gauge is worthless you need a aftermarket one,
Why get a G20? its FWD and a SRDE?
後輪駆動車1番
1986 SR86 - 200ish
Old 07-20-2009, 08:48 PM   #10
bl3ujay07
bl3ujay07's Avatar
^^^I know its FWD and srde. Spend too much time on the car. Getting me off track and distracting me from school and work. Need something with a/c, automatic, and a bit more "luxurious" at a cheap price.
well my brother just called and said it starts, but it seems like waterpump is out and possibly the steel braided turbo coolant hose???
Old 07-20-2009, 08:57 PM   #11
importdude
importdude's Avatar
importdude has a reputation beyond reputeimportdude has a reputation beyond reputeimportdude has a reputation beyond reputeimportdude has a reputation beyond reputeimportdude has a reputation beyond reputeimportdude has a reputation beyond reputeimportdude has a reputation beyond reputeimportdude has a reputation beyond reputeimportdude has a reputation beyond reputeimportdude has a reputation beyond reputeimportdude has a reputation beyond repute
Send a message via AIM to importdude
if he did not bleed it and ADDed Cold Coolant to a HOT engine
and proceeded to drive on it
Chances are he overheated it
adding all water is no problem
Cold coolant/water +hot engine= Air bubbles
Might also be a bad broken waterpump
built ka-t
importdude is offline   Reply With Quote
