Old 07-28-2009, 12:30 AM   #1
CoreyS13
CoreyS13 is on the path to ruinCoreyS13 is on the path to ruinCoreyS13 is on the path to ruin
Ground Diagram
I was unable to find a complete ground diagram for S13 coupe(rpm needle will drop odd time and no speedo readings)
Thanks!
CoreyS13 is offline   Reply With Quote
Old 07-28-2009, 01:01 AM   #2
S-Nation S13
S-Nation S13's Avatar
Trader Rating: (92)
S-Nation S13 is making his/her stupidity well-knownS-Nation S13 is making his/her stupidity well-knownS-Nation S13 is making his/her stupidity well-knownS-Nation S13 is making his/her stupidity well-known
Feedback Score: 92 reviews
www.240edge.com << there you will find the complete fsm of your car hope that helps
S-Nation S13 is offline   Reply With Quote
Old 07-28-2009, 01:22 AM   #3
yukon
yukon is an unknown quantity at this point
why not point him to the local library?????
yukon is offline   Reply With Quote
Old 07-28-2009, 01:26 AM   #4
yukon
Thanks!
why do you want a ground diagram??? they dont exist , btw. check the general ground with a ohm meter. if you want a wiring diagram and know how to read a wiring diagram message me. the one in the fsm is useless.
suspect you know nothing about electrical by what you said so far.
Old 07-28-2009, 10:01 AM   #5
punxva
punxva's Avatar
Trader Rating: (31)
Feedback Score: 31 reviews
actually they do exist in the fsm in the wiring diagram they show every ground location throughout the car. look in the electrical section of a fsm...
Slip Gypsies Blog
not sure if you realize this
