Old 04-20-2003, 03:00 PM   #1
RiceEata
RiceEata is a splendid one to beholdRiceEata is a splendid one to beholdRiceEata is a splendid one to beholdRiceEata is a splendid one to beholdRiceEata is a splendid one to beholdRiceEata is a splendid one to beholdRiceEata is a splendid one to beholdRiceEata is a splendid one to beholdRiceEata is a splendid one to beholdRiceEata is a splendid one to beholdRiceEata is a splendid one to behold
SR SR vaccum hoses , wastegate , bov
Which port do i use for a wastegate and BOV?
RiceEata is offline   Reply With Quote
Old 04-20-2003, 03:07 PM   #2
RiceEata
Better pic
Old 04-20-2003, 03:56 PM   #3
PAnut240
PAnut240 is an unknown quantity at this point
Send a message via AIM to PAnut240 Send a message via Yahoo to PAnut240
SR
I have a ? for ya. Thats a s14 engine right? Regardless, if the vaccuum lines are set up like the redtop the large one of the 3 should go to your BOV. Now, one normally goes to your canister, and the other to your boost gauge or port for boost controller. Now, most of the time you tap into your IC pipeing for the wastgate. Hope that helps, check HeavyThrottle.com they may explain it better. Good luck
jim
'89 Fastback  SR20det; Greddy Profec B II boost controller. HKS 262 CAMS. Greddy Radiator,pulleys,oilfilter relocation kit,boost gauge, rockerarm stoppers,intake manifold. Nismo Fuel Press Reg. Ferra duel Valvesprings, ti retainers. East Bear headlight conversion. Type X tail lights. Tien Suspension, Tanabe race exhaust.  GT 16" rims, Walbro high Pressure fuel Pump,  7pt rollcage. HKS BOV. Mandril Exhaust Man. GTR FMIC. BeeR Valve cover. JE Pistons and Eagle Rods.
PAnut240 is offline   Reply With Quote
