07-30-2009, 09:21 PM | #1 |
17x9 front wheels RUB?
Do 17x9 Front wheels rub even with tien coilovers? I heard they his the top perch and I would need 15mm Spacers. Has anybody done this, and not need spacers?
07-30-2009, 11:34 PM | #5 |
With a positive offset like 35 or so you may need a 10-15mm spacer. If your running like +20 or less you should be good.
REPPIN' NORCAL HARDER THAN HERSHEY'S TURTLE SHELL CHOCOLATE SHIZ!!! |
08-03-2009, 02:07 PM | #7 | |
If you have an s13 you will need a 8mm spacer, no extended lugs needed. How do I know this? Because I have the sprt MAX 962 rims on my s13, and s14.
08-03-2009, 02:18 PM | #8 | |
Most come with extended studs and screws for your original studs. Like above. And to top it off, you'll probably regret not getting 25mm if you buy 15mm because most people end up wanting a bit more "poke" |
08-03-2009, 04:00 PM | #9 |
around +20 will be fine
this is my 18X9.5+20 with NO spacers on an S13
08-03-2009, 04:39 PM | #10 |
17x9+22 dont rub on an S14 with Eibach Sportlines on KYB GR-2s, since you have coilovers you will have more inside clearance so id say a +35 shouldnt rub but theres only 1 way to be 100% sure
RIP: 95 "Slamry" | Welcome: "Blurple" 96 240SX SE |
08-03-2009, 06:13 PM | #11 | |
Super Moderator
Trader Rating: (73)
Feedback Score: 73 reviews
The lowest offset you can go on an s chassis with coils and 9" wheels is a 17x9 +25-22. That's getting lucky, it also depends on how you have your preload set up.
08-03-2009, 06:41 PM | #13 | |
Super Moderator
Trader Rating: (73)
I find that hard to believe since I had an S13 with 17x9 +12 (5mm spacer) with a 215/45/17 and it rubbed when turning. See the tire on the fender? You can see smoke from the tire rubbing.
08-03-2009, 11:57 PM | #14 |
Nice viper. Thanks, I actually have the sportmazz 962's. Also I have the Rota Grid +15 offset 16x8. I have some volks te37's but they dont look great. Thanks guys. I will try the 8mm studs first. The rear I am putting a widebody on, So I will need some spacers back there. Thanks.
08-04-2009, 02:23 AM | #15 | |
erghhhhhhhhhhhhh and im pretty sure Grids are +10mm not 15mm
91' 240sx Fastback LE |
08-04-2009, 10:24 AM | #16 |
on my s13. stock fenders. front wheel - 17x9.5 +14 and also 17x9 +4 or something.
on my S14. stock fenders. front wheel - 17x9 +-0 I rubbed some tire on the fender here and there, but then again, the cars were low.
http://bhworld.wordpress.com/ |
08-04-2009, 10:41 AM | #17 |
thats a noble not a viper.
i rock 17x9 +22 with a 10mm spacer and i have no rubbing issues. |
08-04-2009, 11:09 AM | #18 |
im using those,i still rubbed but that was the inner linear,also rolled my fenders.17x9 +35 all around
08-06-2009, 08:48 PM | #19 |
Grids are +15, Custom for my AE86, but I am selling my AE86 soon. I just decided to widebody, and convert the front to s15. Since I sold my MK4 supra I am kinda depressed. That gives me the excuse to work on one of my cars.
11-27-2009, 04:07 AM | #23 |
if you have megan coilovers, they have extended lower brackets,
http://www.meganracing.com/demo/prod...=588&catid=105 |
11-28-2009, 08:47 PM | #24 |
12-24-2009, 07:00 PM | #27 |
I have tein hrs and sportmaxx 962 17x9s as well.
25mm spacers, 25mm overfenders, and i dont rub (front coils all the way down). I did need 15mm spacers to clear the coils, but opted to go 25 so i wouldnt have to change my studs. Heres a pic: |
12-24-2009, 08:07 PM | #28 |
Um, so whats the offset on the whees?
12-24-2009, 08:24 PM | #29 |
right now im running 17x9 spaced out to +4 with -3 camber with just a roll and i rub but not that bad only on full lock is when i rub. its flush on the fender oh and my coils are maxed out low with two collars on each side on the fronts. when i had them at 17x9 et 24 i didnt have any clearance issue with my coils.
