Old 04-21-2003, 02:34 PM   #1
Cattalbus
Cattalbus's Avatar
Cattalbus is an unknown quantity at this point
Question suspension question.
I am going to a strait drag car. and I ahve a question does HKS make a drag setup for the 240? I have seen it for sale on one site but not on their own. i would have to be the guy who didn't do his homework first and got screwed.
so anyone heard of this? HKS Hipermax Coilover DRAG for S13/S14 1989-98 240SX
I found it on phase2motorsports.com and I hear they are a reliable source for parts.
PS sorry to ca18guy for the misunderstandig earlier.
Cattalbus is offline   Reply With Quote
Old 04-21-2003, 02:37 PM   #2
Dousan_PG
Dousan_PG's Avatar
yes, HKS makes on for the 240sx
im sure its listed onthe USA HKS site i know it has it on the japan one iirc.
phase2 is probably THE most reliable business you can buy from. definately one of the most at least! also the owner is a drag racer himself so he can give you some help as well im sure!
hes building as13 drag car i believe too, last time i spoke w/ him
Aaron
Pink GodziRa
Old 04-21-2003, 02:41 PM   #3
Cattalbus
Cattalbus's Avatar
thanks for the quick reply, iguess my only question is howcome I cannot find them anywhere else on the web? not much for a one price part. at least it doesn't sound too bad.
Old 04-21-2003, 02:49 PM   #4
sykikchimp
WOW addicted
sykikchimp's Avatar
sykikchimp has a spectacular aura aboutsykikchimp has a spectacular aura aboutsykikchimp has a spectacular aura aboutsykikchimp has a spectacular aura aboutsykikchimp has a spectacular aura aboutsykikchimp has a spectacular aura about
Send a message via AIM to sykikchimp
Greaser on FA said the drag coilovers actually HURT his times over the stock suspension b/c they didn't let the car squat enough.
Probably depends on your setup though.
sykikchimp is offline   Reply With Quote
Old 04-21-2003, 03:38 PM   #5
Cattalbus
Cattalbus's Avatar
thanks for the great inside info. would you recomend any aftermarket setup for dragging? or is this somehint I should dial in to as i make runs? I mean shouldn't all 240's react the same off the line? with weight shift and all.
Old 04-21-2003, 04:12 PM   #6
ca18guy
ca18guy's Avatar
ca18guy is close to perfectionca18guy is close to perfectionca18guy is close to perfectionca18guy is close to perfectionca18guy is close to perfectionca18guy is close to perfectionca18guy is close to perfectionca18guy is close to perfectionca18guy is close to perfectionca18guy is close to perfectionca18guy is close to perfection
Re: suspension question.
No need to apologize, Mr.Mephistopheles gave you pretty much the jist of the reason I locked that.
ca18guy is offline   Reply With Quote
Old 04-21-2003, 04:38 PM   #7
ruf
ruf's Avatar
ruf is an unknown quantity at this point
No. The car will squat differently depending on hp and traction.
HKS drag coilovers are good for medium traction (drag radials), but they have too soft a spring rate for slicks on a grippy track. Stock suspension is best in loose conditions such as bad tires or slick track. You basically want the car to squat as much as possible without bottoming out. Low hp, low traction => soft susp. High hp, high traction => hard susp.
ruf is offline   Reply With Quote
