Old 08-05-2009, 09:20 PM   #1
Kaizen.
Kaizen. is not welcome here anymoreKaizen. is not welcome here anymoreKaizen. is not welcome here anymoreKaizen. is not welcome here anymoreKaizen. is not welcome here anymoreKaizen. is not welcome here anymoreKaizen. is not welcome here anymoreKaizen. is not welcome here anymoreKaizen. is not welcome here anymoreKaizen. is not welcome here anymoreKaizen. is not welcome here anymore
Arrow KA24DET Problem Help!!!!!!!
Alright heres the problem.
- Runs like shit
- Bogs at full throttle
- Won't pass 3500 rpm in gear 2-3-4-5
- Won't read boost, when boost kicks in, motor just won't take it and bogs out like crazy
When I disconnected the charge pipe it ran fine, nice n smooth.
Things changed since the setup. (trying to make it run)
- Spark plugs (3times) NGK Iridium step7 gapped .28 + wires changed
- Changed TPS
- Checked MAF x30 + cleaned
- Checked for burn marks in ECU
Mod List:
Motor:
-T-25 turbo
-Turbo manifold
-Downpipe
-Straight pipe
-Dart Izumi
-jgs oil line kit + oil pan with bung
-z32 maf/with pigtail
-370cc injectors
-Walbro fuel pump
-Emance tuned ecu
-Greddy bov
-Intercooler
-Buddy club battery
-z32 fuel filter
-Nismo motor + tranny mount
Drivetrain:
-ACT clutch
-XTD 11lb. flywheel
-Amsoil fluids
HELP!
thanks.
-BMOK
Kaizen. is offline   Reply With Quote
Old 08-05-2009, 09:44 PM   #2
sunnys14
sunnys14's Avatar
sunnys14 is just really nicesunnys14 is just really nicesunnys14 is just really nicesunnys14 is just really nicesunnys14 is just really nicesunnys14 is just really nicesunnys14 is just really nicesunnys14 is just really nicesunnys14 is just really nicesunnys14 is just really nice
What are your AFR's?
Did you test for boost leaks?
sunnys14 is offline   Reply With Quote
Old 08-06-2009, 08:39 AM   #3
koukikrisp
koukikrisp is an unknown quantity at this point
i have an sr20 running stock and mine does the same exact thing. under wot its sounds like a misfire, bog, etc. light throttle/idle it does ok. it isnt a boost leak b/c all my couplers are tight and there's no black smoke/spark plugs(i had a boost leak before). checking my plugs it looked like they were burnt (aka:lean). i checked my fuel pressure w/ a gauge, 35 psi@idle (supposed to be around 40), under load the pressure dropped(not good). i turn the car off the needle is down to 0 before i walk around to the engine=fuel pump. i noticed in ur mod list u dont have an upgrade yet. im currently having a walbro shipped now. i'll post up the results when i get back in a week.
koukikrisp is offline   Reply With Quote
Old 08-06-2009, 02:19 PM   #4
Addicted2Kouki
Addicted2Kouki's Avatar
Addicted2Kouki is close to perfectionAddicted2Kouki is close to perfectionAddicted2Kouki is close to perfectionAddicted2Kouki is close to perfectionAddicted2Kouki is close to perfectionAddicted2Kouki is close to perfectionAddicted2Kouki is close to perfectionAddicted2Kouki is close to perfectionAddicted2Kouki is close to perfectionAddicted2Kouki is close to perfectionAddicted2Kouki is close to perfection
maf wired up wrong.
Originally Posted by coreansurfer View Post
zenki's are for poors and lames
with the exception of norm who is big ballin
FS:CUSCO,GREDDY,KA-Tparts
Addicted2Kouki is offline   Reply With Quote
Old 08-06-2009, 02:33 PM   #5
let5l1de
let5l1de's Avatar
Trader Rating: (30)
let5l1de is close to perfectionlet5l1de is close to perfectionlet5l1de is close to perfectionlet5l1de is close to perfectionlet5l1de is close to perfectionlet5l1de is close to perfectionlet5l1de is close to perfectionlet5l1de is close to perfectionlet5l1de is close to perfectionlet5l1de is close to perfectionlet5l1de is close to perfection
Feedback Score: 30 reviews
Send a message via AIM to let5l1de Send a message via Yahoo to let5l1de
check maf wiring again... proper voltage and continuity (signal wire must be shielded)
change maf with a known good one
be sure your ecu tune was properly done or replace with stock ecu for testing purposes
check fuel pressure & reg
make sure injectors are all operating
check the coil (internal s14 external s13) and replace with a know good one.
**GR Performance facebook** Pics & More! Comments! http://www.facebook.com/pages/GR-Performance/120477531339202
Read My Sales Review
626 Friday Nights San Gabriel
let5l1de is offline   Reply With Quote
Old 08-06-2009, 02:54 PM   #6
voodoo_child
voodoo_child's Avatar
voodoo_child is an unknown quantity at this point
i dont see an upgrade on you fuel pump buddy? i have the same problem on my SR2ODET. i just replaced my fuel pump to WALBRO and it ran smooth.
voodoo_child is offline   Reply With Quote
Old 08-06-2009, 07:38 PM   #7
Kaizen.
Thanks for the info guys.
Warlbro is installed, just forgot to lsit
Old 08-08-2009, 04:41 PM   #8
Kaizen.
Maf is installed right. I think it just went to shit, since I still didnt make a catch can for the hose on the valve cover and its shooting stuff all over the place. The maf is probably trenched in oil. Im going to try and swap for a another one and see how that goes.
Old 08-08-2009, 04:42 PM   #9
importdude
importdude's Avatar
importdude has a reputation beyond reputeimportdude has a reputation beyond reputeimportdude has a reputation beyond reputeimportdude has a reputation beyond reputeimportdude has a reputation beyond reputeimportdude has a reputation beyond reputeimportdude has a reputation beyond reputeimportdude has a reputation beyond reputeimportdude has a reputation beyond reputeimportdude has a reputation beyond reputeimportdude has a reputation beyond repute
Send a message via AIM to importdude
if the valvecover hose is spitting oil out
u have a problem with blow by buddy
built ka-t
importdude is offline   Reply With Quote
Old 08-13-2009, 11:46 AM   #10
nosajton
nosajton is on a distinguished road
KA24DEvelopment.com :: ECU Diagnostics
what codes is your ecu throwing? if its storing a cam sensor/maf code it will run like shit until it's cleared
nosajton is offline   Reply With Quote
