Old 09-04-2009, 08:19 PM   #1
lbsam
lbsam's Avatar
lbsam is making a name for him/her selflbsam is making a name for him/her selflbsam is making a name for him/her self
S13 KA24DE Heat/Gas smell in cabin problem
Yes I have searched, just looking for opinions or someone that has had a similar issue and successfully fixed it.
Problem: Excessive heat coming from underneath my cd player and by my gas pedal, same goes with passenger side. Also un-burnt gas smell inside cabin. This only happens while im on the highway. My car does not over heat. My only thought is Heater Core? Yes my car is running rich, Im still looking for what the reason is also..
Specs: Stock KA24DE, Headers, straight pipe 2.5 inch, intake.
If anybody can contribute to this thread with ideas it would be much appreciated.
lbsam is offline   Reply With Quote
Old 09-04-2009, 09:19 PM   #2
hOngsterr
Bandwagon.
hOngsterr's Avatar
Trader Rating: (73)
hOngsterr is an unknown quantity at this point
Feedback Score: 73 reviews
id like to hear also,
i have similar problems,
no to thread jack
- Hong
OCD isn't so bad just means you'll spend more money then most people, but you'll have a quality car not a POS put together with POS parts.
Old 09-04-2009, 09:23 PM   #3
I LUV MY S13
I LUV MY S13's Avatar
inside of my car smelled like gas wen i would punch it...i have a fuel injector leak so im guessin thats my issue...idk if helps u but gl
-Jorge
I LUV MY S13 is offline   Reply With Quote
Old 09-04-2009, 09:32 PM   #4
Charlie
Charlie is on the path to ruinCharlie is on the path to ruin
The gas smell can mean a fuel leak somewhere, in my case it was the old fuel pump hoses crapping out on me. I not to sure about the heat though I thought it was just because of our old cars but my sisters 09 civic gets pretty hot around the gas peddle area as well even though the heat and stuff is not on.
Charlie is offline   Reply With Quote
Old 09-04-2009, 10:23 PM   #5
lbsam
lbsam's Avatar
good point, it happens mostly when im getting on the highway and flooring the gas, it slowly goes away after Im driving for a while on the highway but it goes in and out?. The heat is consistent, it gets annoying when driving long distances. Temp is set at cold.
I will check injectors/ fuel pump hoses. Thanks I will let u guys know if I find the problem. As far as heat.. the only thing i can think of is heater core is messed up.. all i know is that its not normal; but thanks for the input guys.
Old 09-04-2009, 10:35 PM   #6
Renelovesnike
Renelovesnike's Avatar
Trader Rating: (30)
Renelovesnike is an unknown quantity at this point
Feedback Score: 30 reviews
do u have the shifter boot/rubber covers?? i know without them you get alot of fumes/heat/GAS SMELL in your cabin!!
Renelovesnike is offline   Reply With Quote
Old 09-04-2009, 10:50 PM   #7
I LUV MY S13
yea man wen im driving somtimes (windows dwn i dont have ac) i get a wiff of hot air..idk where comes frm seems like my vents but the heater is obviously off
-Jorge
Old 09-04-2009, 11:09 PM   #8
Rogue240sx
Rogue240sx's Avatar
Rogue240sx has much to be proud ofRogue240sx has much to be proud ofRogue240sx has much to be proud ofRogue240sx has much to be proud ofRogue240sx has much to be proud ofRogue240sx has much to be proud ofRogue240sx has much to be proud ofRogue240sx has much to be proud ofRogue240sx has much to be proud ofRogue240sx has much to be proud ofRogue240sx has much to be proud of
Send a message via AIM to Rogue240sx
does your tranny have all of it's gear lube in it? That thing can get pretty hot after driving on the highway for a while.
There's not enough hours in the day.
Rogue240sx is offline   Reply With Quote
Old 09-04-2009, 11:13 PM   #9
Rabboni
Rabboni is an unknown quantity at this point
If you are getting fumes in your cabbin you better check for an exhaust leak, and fuel smelling exhaust means running rich. Running rich will produce excessive carbon monoxide, the odorless, colorless, gas that is extremely deadly. If your driving and get a headache open the windows and pull over immediately. That is something you need to check out as soon as possible.
Rabboni is offline   Reply With Quote
Old 09-05-2009, 12:44 PM   #10
lbsam
lbsam's Avatar
yes, same here No A/C. Most of the hot air is coming from under my cd player.. and by the gas pedal.. you can feel air coming through.. its not just heat u know? its almost like my heater is blasting on hot.. but its on cold.
I have replaced all my gaskets and checked for exhaust leaks.. Nothing.. and yes sometimes i get headaches from the rich gas smell.. i have to roll with all my windows down sun roof open.. Im going to have to park it until i figure everything out..
and yes i have the shifter boot with all the covers. That was the first thing i checked. I will check the tranny fluids just to make sure. Thanks
Old 09-07-2009, 01:02 AM   #11
SilviaSR20DET
SilviaSR20DET's Avatar
SilviaSR20DET is making a name for him/her selfSilviaSR20DET is making a name for him/her selfSilviaSR20DET is making a name for him/her self
if you have gas smell in cabin, most likely its an exhaust leak coming from your header or something. I had the same problem when i was N/A and when i replaced the gasket for my ka-t manfold no gas smell ever again. Id check it out
SilviaSR20DET is offline   Reply With Quote
Old 09-07-2009, 01:32 AM   #12
DALAZ_68
not giving a fuck
DALAZ_68's Avatar
Trader Rating: (104)
Feedback Score: 104 reviews
i say,
heat:
ex mani leak
ur straight pipe
ex mani gasket
both dealing with shitty welding
gas smell
might wanna check the O-ring that seals around ur fuel pump, and the hoses
inject O-ring
i could go on but those are the first that come to mind
PSN
& XBL GT : Wh0pp3r68
CLUB LEXUS : Wh0pp3r
Old 09-07-2009, 01:41 AM   #13
zenki.life
zenki.life's Avatar
zenki.life is an unknown quantity at this point
Send a message via AIM to zenki.life
you have a leak.
Originally Posted by super240s14 View Post
man you all are ass holes...... and that is rude to talk like that on zilvia im reporting all you...... ZILVIA ADMINISTRATION PLEASE BANNED ALL THREE OF THESE DUDES
^^another person learns the perils of "stupid posting" on zilvia, too bad none will care.
zenki.life is offline   Reply With Quote
