Old 09-05-2009, 02:37 AM   #1
miggsfiggs
miggsfiggs's Avatar
miggsfiggs is an unknown quantity at this point
KA crank position Dilema
converting my s14 auto to a 5 speed.i belive i have a s13 transmission .problem is that the s13 doesnt have the slot or the insert for the crank position sensor.i dont know what to do.plz help
miggsfiggs is offline   Reply With Quote
Old 09-05-2009, 03:21 AM   #2
devnull
devnull is not welcome here anymoredevnull is not welcome here anymoredevnull is not welcome here anymoredevnull is not welcome here anymoredevnull is not welcome here anymoredevnull is not welcome here anymoredevnull is not welcome here anymoredevnull is not welcome here anymoredevnull is not welcome here anymoredevnull is not welcome here anymoredevnull is not welcome here anymore
Drill a hole for the CPS and drill/tap a hole for the bolt that secures it
Get an S14 M/T
Get an S14 M/T bellhousing
If you're in a place that doesn't care about CELs then run without the CPS
devnull is offline   Reply With Quote
Old 09-05-2009, 09:29 AM   #3
miggsfiggs
miggsfiggs's Avatar
what are CELs?and if i drill hole,it would b straight through the bellhousing,and what bout the magnet on the bottom of sensor it wouldnt touch anything.doesnt it need to sit on something?like the metal part of the bellhousing. there is a high chance i would fuck it up.
Old 09-05-2009, 11:10 AM   #4
miggsfiggs
miggsfiggs's Avatar
how much will s14 5 speed transmission set me back.and can i use s13 transmission?
Old 09-05-2009, 12:19 PM   #5
projectRDM
projectRDM's Avatar
We have discussed this for over a decade. Quit assuming you're the first person to ever ask this question and research it.
I know for certain I've replied to these very questions a few times this year alone on here, not to mention numerous other forums. There comes a time when you when you have to decide if you want to be a lazy piece of shit for the rest of your life or not. Nows your chance.
FORMERLY R240NA
Old 09-06-2009, 12:18 AM   #6
miggsfiggs
miggsfiggs's Avatar
well thanks for taking your time to waste it cuz you aint helping.just bcuz you have not done ne thing else but repeat yourself.it is ovious that you havent answered the question,so plz dont waste my time.
Old 09-06-2009, 08:40 AM   #7
projectRDM
projectRDM's Avatar
How is it obvious? Did you find a post of mine where I discussed your questions but didn't answer them besides this one? Show me then, I'm game to see you make an ass out of yourself.
Anyone at your age (25, as it says) should be above needing your ass wiped. You should also be able to type common English, but you've proven both of those wrong, so I'm assuming you're either not 25 (maybe 15), or you're a mental case with some sort of serious learning problem. In that case, you don't need to be working on a car, you'll hurt yourself.
Now if I'm wrong and you really are a 25 year old person who isn't a fucking retard, maybe you can understand this:
CEL = check engine light. Found on the very search on google. Fucking amazing.
If you're assuming the CPS won't touch anything once mounted, you're right. Good guess. The flywheel is right below the bellhousing, would you want the CPS to touch it anyway, and sheer off the first time you started the car? The CPS is magnetic (good guess again), it measures the flywheel as it spins by a constant magnetic pulse which signals the ECU. Drilling the hole is critical as to location, and if you've searched for those threads I asked about above (you haven't, we know), you'll see both descriptions and pictures of the bellhousing and location of the CPS. From there you can decide if you're capable of drilling (you aren't, you're an idiot) or if you want to buy an S14 bellhousing, entire transmission (which we can't tell you what it will cost, used parts prices vary) or just use what you already have as it works just the same but triggers the CEL, which won't matter unless it's a '96+ and requires a scan for emissions.
There, better? Is the sand in your vagina still stinging?
FORMERLY R240NA
Old 09-06-2009, 09:54 AM   #8
cotbu
cotbu's Avatar
Fucking Catalina Wine Mixer!!!
Old 09-06-2009, 03:38 PM   #9
miggsfiggs
miggsfiggs's Avatar
First off,youre not wiping my ass.Second,I can speak it n write it.Been here all my life,but there is no need for rudeness here,we got to stick together while we still have each other man,and third,some of us havent had it so easy,I've had to work for everything I own,and I've lost it all,and had to get back up n continue the race.I now feel blessed bcuz I have a garage were I can do a swap,I could of converted it to anything else but i decided to have a project for the summer,now it has taken a little longer that is why i may be frustrated.Fourth n last,Thank you,was that so hard?
Old 09-06-2009, 05:04 PM   #10
zugoi
zugoi is a splendid one to beholdzugoi is a splendid one to beholdzugoi is a splendid one to beholdzugoi is a splendid one to beholdzugoi is a splendid one to beholdzugoi is a splendid one to beholdzugoi is a splendid one to beholdzugoi is a splendid one to beholdzugoi is a splendid one to beholdzugoi is a splendid one to beholdzugoi is a splendid one to behold
Your contradicting yourself. You say you can speak it n write it. Why not actually type out the two extra letters a & d. You've been on zilvia all your life? Says you joined this year and if you really know this site you should know who projectrdm is and not underestimate him and just do what he suggests.
Drunk posting FTW!
zugoi is offline   Reply With Quote
Old 09-06-2009, 07:10 PM   #11
projectRDM
projectRDM's Avatar
Space bar. It's the big key at the bottom of the keyboard with nothing on it. Next item is the apostrophe, it's used to denote a letter missing, as in you're in place of you are. As for the rest, well, you can't spell so there's no need pointing that out.
Now on to the rest of your spill, why do we have to 'stick together'? Do I know you? Why would I give a flying fuck about a total stranger I don't know and will never meet? And when did we 'have each other'? If that's some sort of ghey thing, count me out, must have been another dude that night, I wasn't involved. If having each other is the important thing here, I think I'll go eat a gun, I sure as hell don't want people like you related or involved with the likes of myself.
Then you assume I've had it all handed to me on a silver platter, why? Because I'm more intelligent? No, that just means I'm more intelligent, period, it's usually the spoiled people who are morons, I too have worked for what I have, and I certainly didn't cry about it on a car forum. If you're in the same boat you only have yourself to blame for your ignorance.
Moving on, you lost it all? All what? Again, why do we care? So if you've lost 'it all', why are you 'continuing the race' by fooling with a car? Shouldn't you be out buying a house, dishes, clothes, important shit? I mean, you lost 'it all', I assume that means everything.
And finally, you're welcome. I always enjoy people's rants but yours was quite the fun one.
FORMERLY R240NA
