Old 09-06-2009, 05:07 PM   #1
gotboost2jz
gotboost2jz's Avatar
gotboost2jz is an unknown quantity at this point
How to pull codes off an E5 ECU
I have an E5 ecu on my SR swapped S14 and when I go to check codes, the dash/check engine light does not flash to give me the code. I was told that there is a way to wire an LED light to the ecu so that I can get codes. Anyone know how or have the link that shows you?
p.s. I found one but it was in technobabble lingo above my simpleton wiring mind.
How to pull codes from an E5 blacktop ecu...anyone know?: SR20DET Forum (rear-drive): Nissan Forums / Infiniti Forums - NICOclub
If you can translate into english, I'd be very appreciative. Thanks
Also, can I do a straight swap from my E5 ecu to a red top ecu that does have an LED light? Or would it just be easier in the long run to wire one in?
1995 240sx SE - 1JZ
gotboost2jz is offline   Reply With Quote
Old 09-06-2009, 07:45 PM   #2
Homer_Simpson
Homer_Simpson's Avatar
Homer_Simpson is on the path to ruinHomer_Simpson is on the path to ruinHomer_Simpson is on the path to ruin
Connect your check engine light wire pin #30 (95 Zenki) from the S14 F3 to pin #24 on your S13 SR harness.
Homer_Simpson is offline   Reply With Quote
