![]() Join Date: Feb 2003
![]() I was surprised when I pulled the valve cover off my spare KA last night that the valve cover gaskets were rubber! Are they reusable?
When I put it back on, what torque should I put on the bolts? |
![]() Join Date: Apr 2002
yes, it's reusable. just inspect it for cracks first, wipe it down, and put it back.
bolts are not beefy...torque is like 12-20 ft-lbs or something. IIRC. somebody check the FSM on that. i say just make 'em tight enough. if you tighten them with a 1/4" ratchet, it'll be hard to overtighten them. Eric
2002 Mazda Protege5 1989 S13 w/SR20DET (sold) |
#3 | |
#4 | |
but, if it's sealing well now, go for it. i would do the same. Eric
#5 | |
Consequently, how much is a valve cover gasket set from Nissan? |
#6 |
and to add.. BE CAREFUL WITH THE BOLTS!! i could only get around 10lbs for my bolts and even then i started to strip 2 of them in the head. i'd say try around 5-7lbs and tighten them later if its leaking. as long as you have even pressure on all of the bolts and a decent gasket you should not have problems
#7 | |
I was debating back and forth about whether to polich or paint the valve cover. Polishing would look cool, but I have already sanded and painted my Injen air intake a gloss grey, so I think just to keep the colors matching I will paint the valve cover the same. Plus, saves a lot of work. Maybe when I swap on this painted cover I will play around with polishing the other cover in my spare time. |
#8 |
never ever assume muskrat. u know why right? cuz it makes an ass out of.....u know the rest. anyway, dont assume that your 91 KA with 80k miles is fine. cuz my car almost has the exact same mileage (it actually hit 80,000 last wednesday
![]() i hope i didnt overtighten though. i dont have a torque wrench. ![]() |
#9 | |
#10 | |
![]() Join Date: May 2002
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Feedback Score: 23 reviews
cheap torque wrenches if you are on a serious budget. i got one for 20 bucks (torques up to 100 some ft-lbs) i use it for the wheels only though, something that if it gets stolen or lost i wont crya bout it. for engine stuff use my friend's fancy dancy 100 buck torque wrenches (2 of them one for low spec torque, one for high) |
