Go Back   Zilvia.net Forums | Nissan 240SX (Silvia) and Z (Fairlady) Car Forum > Marketplace > Advertiser Specials and Sales > Electronics
Old 09-23-2009, 11:11 PM   #1
S13FREEAAK
Drifterella
S13FREEAAK's Avatar
S13FREEAAK is close to perfectionS13FREEAAK is close to perfectionS13FREEAAK is close to perfectionS13FREEAAK is close to perfectionS13FREEAAK is close to perfectionS13FREEAAK is close to perfectionS13FREEAAK is close to perfectionS13FREEAAK is close to perfectionS13FREEAAK is close to perfectionS13FREEAAK is close to perfectionS13FREEAAK is close to perfection
Propsort Gauges! The Sale is Back! New Gauges/New Prices/80mm/Widebands/Boost/More!!
I decided to do another sale on Prosport's products. They have added a few products since the last special I had.
This is just some of their products, Here is the Full Lineup on their WebsiteProsport Gauges - Boost gauges, Oil pressure gauges, peak warning Gauges I have all of their products on sale, just contact me for a quote.
You can purchase the gauges here: DPIstore.net: Gauges
Contact me through PM or Email for multiple gauge discounts, any purchase of 2 or more gauges gets a discount!
Free shipping on any order over $75!
Gauges
The 270° dial sweep provides quick, one glance accuracy. Track tested and race proven, these gauges use precision electric senders to keep hazardous fluids out of the passenger compartment.
All Electric Gauges perform a dramatic opening ceremony with a full pointer sweep and self check each time the vehicle is started.
No controller needed!
Performance 52mm Gauges:
Blue/White
Boost Gauge (mechanical) - Super Blue 52mm $35.10
Oil Pressure Gauge (Electric) w/sender - Super Blue 52mm $39.59
Exhaust Gas Temperature - Super Blue 52mm $85.49
Oil Temperature Gauge (Electric) w/sender - Super Blue 52mm $35.55
Water Temp. Gauge (Electric) w/sender - Super Blue 52mm $35.55
Amber/White
Boost Gauge (mechanical) - Amber/White 52mm $35.10
Oil Pressure Gauge (Electric) w/sender - Amber/White 52mm $39.59
Exhaust Gas Temperature - Amber/White 52mm $85.49
Oil Temperature Gauge (Elec.) w/sender - Amber/White 52mm $35.55
Water Temp. Gauge (Elec.) w/sender - Amber/White 52mm $35.55
Green/White
Boost Gauge (Mechanical) - Green/ White 52mm $35.10
Water Temp. Gauge (Electric)-Green/White-52mm $35.55
Oil Pressure Gauge (Electric)-Green/White 52mm $39.59
Exhaust Gas Temperature - Green/White 52mm $85.49
Oil Temperature Gauge (Elec.) w/sender - Green/White 52mm $35.55
"Prosport Gauges is proud to roll out our newest line of PREMIUM Series Gauges featuring fully programmable Warning & Peak Recall functions. These new Gauges use Precision Stepper Motor Driven pointers for exceptional accuracy. Coupled with 2nd generation Electric Senders for unprecedented precision. This newest series of gauges features a daisy chain wiring system to make installation easier. For multiple gauge installations only the first in the series needs to wired for power, ground & Color choice. Each additional gauge can be powered using the supplied daisy chain wire."
Peak Hold Gauges come with mounting cups.
Peak/Hold 52mm Gauges:
Amber/White
Boost (Electric) Warning & Peak Hold $73.79
Oil Pressure (Electric) Warning & Peak Hold $94.49
Water Temp. (Electric) Warning & Peak Hold $63.89
Oil Temp. (Electric) Warning & Peak Hold $63.89
EGT (Electric) Warning & Peak Hold $105.29
Green/White
Blue/White
Peak/Warning Components
Gauge Accessories
52mm Mounting cups $9
Water Temp Sender Radiator Hose Adaptor 32mm-Gold $23.40
Water Temp Sender Radiator Hose Adapter 34mm-Red
Oil Filter Adapter Plate (4 1/8 NPT holes for senders) Blue $35.09
Heat Wrap
Available in White or Black
Durable, tight woven, 100% Fiberglass- easy to install white thermo heat wrap. One roll will wrap one medium header. We hand picked this material for it's heat charateristics and most importantly the flexibility of this material makes wrapping headers much easier.
Reduces under hood temperatures
increases horsepower
protects other engine components
protects against burns
2" Wide x 1/16" thick
50 Feet long
Each roll comes with 5 FREE, 14" long stainless steel zip ties!
Black: $27.00 ea
White: $23.00 ea
Here are a few HOT NEW prdoucts from Prosport.
80mm Gauges
Both of these light in White, Blue or Amber!
Peak/Hold with external Warning/Shift Lights
80mm Tachometer MSRP: $139 Sale Price: $116.10
The 80mm (3.15") size is extremely popular in Japan.
Stand alone
Featuring a 0-10,000 RPM range with a 270° scale.
Swiss made stepper motor electronic movement ensures pinpoint accuracy
3 color display (White, Blue & Amber)
3 color external LED control box
Opening & Closing ceremony when the gauge is turned on/off.
Peak recall
Dimmable
Fully programmable warning feature
Adjustable outer Bezel and be set the warning mark manually
Metal stand and metal mounting ring included
Extrenal warning light included
Daisy chain system
Self diagnosis of sensors or short circuits
Illuminated Red pointer
Gauge face is smoked out when off
80mm Boost Gauge MSRP: $149 Sale Price: $134.10
Stand alone-No controller needed
Featuring -30~30 PSI range with a 270° scale.
Peak recall
Dimmable
External warning light included
Daisy chain system
Includes T-fitting & Tubing
With its pinpoint accuracy and lots of features this gauge is a sweet deal!
(Includes Mounting Hardware, external shift/warning light, control box, wiring and Instructions)
45mm Gauges
Amber with Clear Lens
45 mm (1 3/4") Stepper Motor Driven 270° LED Display.
Perfect for tight spaces. Easily fit three across in a DIN panel.
Only 1" Deep.
270° dial sweep provides quick one glance accuracy. Track tested and race proven these gauges use precision electric senders to keep hazardous fluids out of the passenger compartment.
All of our 45mm Series gauges perform a dramatic opening ceremony with a full pointer sweep each time the vehicle is turned on AND off.
Wire up the first gauge for power and daisy chain the power to each gauge as needed! As only Prosport would do, the Daisy chain power leads come with them! Nothing more to buy.
Each gauge comes with their respective sender.
Electric Boost Gauge MSRP: $80 Sale Price: $72
Electric Oil Pressure Gauge MSRP: $80 Sale Price: $72
Exhaust Gas Temp Gauge MSRP: $130 Sale Price: $117
Oil Temp Gauge MSRP: $75 Sale Price: $67.50
Water Temp Gauge MSRP: $75 Sale Price: $67.50
Volt Gauge MSRP: $75 Sale Price: $63
WideBands
Blue Digital Wideband MSRP: $229 Sale Price: $206.10
Wideband Air Fuel Ratio Gauge
52mm (2 1/16")
0-5 volt
Utilizing the latest Bosch wideband O2 sensor -5 wire heated LSU 4.9 (Prosport Inc. is the only one in the USA to use them) our gauge now has the widest range 10.0:1 to 20.0:1 AFR readings on the planet.
Featuring Blue LCD readout in the center of the gauge and a bar-graph syle LED's around the outside of the gauge that change from green(Rich) to Yellow(Optimal) to Red(Lean) for immediate reference to AFR.
This is a complete kit that includes everything you need:
AFR digital Gauge
Bosch 4.9 5 wire heated O2 sensor
Weld in Bung
Instructions
Wiring harness(Gauge to O2 sensor) Plug and play
Decals
Visor/hood
Amber Digital Wideband MSRP: $229 Sale Price: $206.10
Amber LCD Display
52mm (2 1/16")
0-5 volt
Featuring Amber LCD readout in the center of the gauge and a bar-graph syle LED's around the outside of the gauge that change from green(Rich) to Yellow(Optimal) to Red(Lean) for immediate reference to AFR.
AFR digital Gauge
Weld in Bung
Instructions
Wiring harness(Gauge to O2 sensor) 10 feet long
Plug and play
Decals
Visor/hood
Premium 52mm Wideband Air Fuel Ratio kit-Amber/White MSRP: $245 Sale Price: $220.05
52mm (2 1/16")
Amber/White display-Blacked out when off.
0-5 volt
Utilizing the latest Bosch wideband O2 sensor -5 wire heated LSU 4.9 our gauge now has the widest range 10.0:1 to 20.0:1 AFR readings on the planet.
AFR Premium Series Gauge
Weld in Bung
Instructions
Plug and play
Decals
Visor/hood
Mounting Cup
Premium 60mm Wideband Air Fuel Ratio kit-Amber/White MSRP: $249 Sale Price: $220.05
60mm (2 3/8")
0-5 volt
Weld in Bung
Instructions
Plug and play
Decals
Visor/hood
Mounting Cup
PM or email me at [email protected]
PM me with zip code for shipping quote. All orders of atleast $75 include free shipping.
PAYMENT
All Iowa residents are subject to 7% sales tax.
Paypal is [email protected]
Postal Money Orders also accepted
Cash in person
S13FREEAAK is offline   Reply With Quote
Old 09-24-2009, 09:30 AM   #2
datsunnazi
datsunnazi's Avatar
datsunnazi is an unknown quantity at this point
Send a message via MSN to datsunnazi
price on the 52mm blue gauges... oil pressure, boost, and water temp shipped to 97230?
datsunnazi is offline   Reply With Quote
Old 09-24-2009, 10:24 AM   #3
silverdemon16
silverdemon16's Avatar
silverdemon16 is an unknown quantity at this point
how do I order the heat wrap thx
90 240sx SE project, 05 Highlander w/duece dueces
silverdemon16 is offline   Reply With Quote
Old 09-24-2009, 12:21 PM   #4
S13FREEAAK
Drifterella
S13FREEAAK's Avatar
I just added them to my site. www.DPIstore.net they are under the Exhaust section in Heat Protection.
(I'd give you the direct link but, I'm posting from my phone. Sorry)
datsunnazi: PM sent.
Old 09-24-2009, 12:21 PM   #5
Ceepo
Ceepo's Avatar
Ceepo will become famous soon enoughCeepo will become famous soon enoughCeepo will become famous soon enoughCeepo will become famous soon enough
Price for the blue/white gauges 52mm boost, oilpressure, water temp. shipped to 84720... thanks...
Ceepo is offline   Reply With Quote
Old 09-28-2009, 05:36 PM   #6
rican_nick
rican_nick's Avatar
rican_nick is close to perfectionrican_nick is close to perfectionrican_nick is close to perfectionrican_nick is close to perfectionrican_nick is close to perfectionrican_nick is close to perfectionrican_nick is close to perfectionrican_nick is close to perfectionrican_nick is close to perfectionrican_nick is close to perfectionrican_nick is close to perfection
Send a message via AIM to rican_nick
any reviews on the widebands????
Nick O.
97 240sx
My Seller's Review Thread
rican_nick is offline   Reply With Quote
Old 09-28-2009, 06:14 PM   #7
S13FREEAAK
Drifterella
S13FREEAAK's Avatar
I can try and get some reviews put together from people on here.
I personally use one in our S14, we used the wideband to street tune our GT2540r SR and haven't had any issues. We haven't had any issues with it so far. It is very easy to watch/read at a quick glance. Another plus is if you do ever need a replacement sensor they are only $79.99 which is very resonable for a real Bosch wideband sensor.
Old 09-28-2009, 06:26 PM   #8
R@ddy
Trader Rating: (32)
R@ddy is not welcome here anymoreR@ddy is not welcome here anymoreR@ddy is not welcome here anymoreR@ddy is not welcome here anymoreR@ddy is not welcome here anymoreR@ddy is not welcome here anymoreR@ddy is not welcome here anymoreR@ddy is not welcome here anymoreR@ddy is not welcome here anymoreR@ddy is not welcome here anymore
Feedback Score: 32 reviews
Blue/White
all above to 90723
thanks
R@ddy is offline   Reply With Quote
Old 10-01-2009, 06:42 AM   #9
AE_Racer
AE_Racer is an unknown quantity at this point
Can't wait to get mine. Ill give you guys a review
http://tougestars.net
AE_Racer is offline   Reply With Quote
Old 10-01-2009, 07:47 AM   #10
hotlavaflow
hotlavaflow's Avatar
hotlavaflow is a splendid one to beholdhotlavaflow is a splendid one to beholdhotlavaflow is a splendid one to beholdhotlavaflow is a splendid one to beholdhotlavaflow is a splendid one to beholdhotlavaflow is a splendid one to beholdhotlavaflow is a splendid one to beholdhotlavaflow is a splendid one to beholdhotlavaflow is a splendid one to beholdhotlavaflow is a splendid one to beholdhotlavaflow is a splendid one to behold
Send a message via Yahoo to hotlavaflow
I have the 80mm boost gauge, love it.
Need quote on white/blue gauges
oil temp/water temp/exh temp/oil press/elec boost
shipped to 11226
hotlavaflow is offline   Reply With Quote
Old 10-02-2009, 10:19 AM   #11
DrftKingIII
DrftKingIII's Avatar
DrftKingIII has a spectacular aura aboutDrftKingIII has a spectacular aura aboutDrftKingIII has a spectacular aura aboutDrftKingIII has a spectacular aura aboutDrftKingIII has a spectacular aura aboutDrftKingIII has a spectacular aura about
Blue/White
These 3 shipped to 63132? And they all come with the "hood" right?
Mike
- このノイズをファック -
DrftKingIII is offline   Reply With Quote
Old 10-02-2009, 11:42 AM   #12
S13FREEAAK
Drifterella
S13FREEAAK's Avatar
Originally Posted by DrftKingIII View Post
Blue/White
Mike
PM sent, and yes they do come with the hood.
Old 10-05-2009, 02:01 AM   #13
upsdude
upsdude's Avatar
Trader Rating: (46)
upsdude is an unknown quantity at this point
Feedback Score: 46 reviews
Blue/White
quote for 92345...actually need a quote for the 4 gauges listed and how much for just boost,oil press, and h20 temp...in 52mm and 60mm sizes.
noob question: when you say 52mm...that's the measurement of the face of the gauge, or the back? i ask because i have a kognition cf radio panel delete and i'd like to be able to fit 3 across the widest section of it...and if i can do 60mm that would be even better cuz i'm old and blind :P
upsdude is offline   Reply With Quote
Old 10-05-2009, 02:08 PM   #14
S13FREEAAK
Drifterella
S13FREEAAK's Avatar
Originally Posted by filiperuvian View Post
Blue/White
PM sent.
52mm is the measurement of the back of the gauge. So you would need roughly a 52mm hole to fit the gauge.
Old 10-13-2009, 12:48 AM   #15
juve_240sx
juve_240sx's Avatar
juve_240sx is an unknown quantity at this point
do you get any discounts if you buy a widaban,boost gauge and heat wrap
juve_240sx is offline   Reply With Quote
Old 10-14-2009, 06:12 PM   #16
S13FREEAAK
Drifterella
S13FREEAAK's Avatar
Yes! Just let me know which ones you are interested in.
Old 10-16-2009, 03:00 PM   #17
hotlavaflow
Got my gauges today they look good. Thanks, good seller.
Old 11-06-2009, 10:18 PM   #18
SuicidnS13
SuicidnS13's Avatar
SuicidnS13 is on the path to ruinSuicidnS13 is on the path to ruinSuicidnS13 is on the path to ruin
Your PM box is full.
I need a price on the prosport wideband gauge with blue LED's and a 34mm water temperature sensor adapter shipped to 89031 please! Free shipping over $75.00 right???
thanks
SuicidnS13 is offline   Reply With Quote
Old 11-07-2009, 12:45 AM   #19
Zacho
Zacho is an unknown quantity at this point
Just bought another one off your site, had great experience last time through you.
Thanks!
Zacho is offline   Reply With Quote
Old 11-07-2009, 09:02 AM   #20
AznXstazy
AznXstazy has a little shameless behavior in the past
inbox is full
AznXstazy is offline   Reply With Quote
Old 11-13-2009, 02:13 AM   #21
hotlavaflow
Still doing the Prosport sale? My green/white electric oil temp and water gauges died on me and I need to replace them. I called Prosport and they said that they're a month over the 1 year warranty so basically I have two paper weights in my car.
BTW
The blue/white gauges you sold me work great.
Old 11-13-2009, 03:15 AM   #22
1quk240
Banned from the Marketplace
1quk240 will become famous soon enough1quk240 will become famous soon enough1quk240 will become famous soon enough1quk240 will become famous soon enough
can i get a price shipped on these two options to 85303?
Amber/White
Water temp. adapter
Amber/White
1quk240 is offline   Reply With Quote
Old 11-13-2009, 03:18 AM   #23
sidedrifts13
sidedrifts13's Avatar
Trader Rating: (29)
Feedback Score: 29 reviews
good deal on these
sidedrifts13 is offline   Reply With Quote
Old 12-23-2009, 03:30 AM   #24
5t341tH
5t341tH's Avatar
5t341tH has a reputation beyond repute5t341tH has a reputation beyond repute5t341tH has a reputation beyond repute5t341tH has a reputation beyond repute5t341tH has a reputation beyond repute5t341tH has a reputation beyond repute5t341tH has a reputation beyond repute5t341tH has a reputation beyond repute5t341tH has a reputation beyond repute5t341tH has a reputation beyond repute5t341tH has a reputation beyond repute
Send a message via AIM to 5t341tH
how much shipped for 52mm amber/white water temp gauge to 92647
lexus baby
5t341tH is offline   Reply With Quote
Old 01-14-2010, 12:37 PM   #25
nieko
nieko is close to perfectionnieko is close to perfectionnieko is close to perfectionnieko is close to perfectionnieko is close to perfectionnieko is close to perfectionnieko is close to perfectionnieko is close to perfectionnieko is close to perfectionnieko is close to perfectionnieko is close to perfection
Amber/White
shipped to 92843
YOUR PM BOX IS FULL.
nieko is offline   Reply With Quote
Old 01-18-2010, 03:22 AM   #26
nieko
soo website doesnt work.
dont answer your thread.
wtf?
Old 03-24-2010, 01:16 AM   #27
supra33202
supra33202 has made poor choicessupra33202 has made poor choicessupra33202 has made poor choicessupra33202 has made poor choicessupra33202 has made poor choicessupra33202 has made poor choices
Prosport Clear Lens Oil Temperature Gauge-52mm
Prosport Clear Lens Oil Pressure Gauge-52mm
shipped to CA 94545
supra33202 is offline   Reply With Quote
