Old 05-05-2003, 03:40 PM   #1
assmunke
assmunke is an unknown quantity at this point
Fuel cutoff switch?
do any of you guys have any knowledge of how to install a fuel cutoff switch ( or something to that nature) or know of any websites that have tutorials? i want to protect my 91 240sx and cant afford a sweet car alarm so any info would be appreciated.
assmunke is offline   Reply With Quote
Old 05-05-2003, 04:15 PM   #2
AceInHole
Autox Technician
AceInHole's Avatar
AceInHole is close to perfectionAceInHole is close to perfectionAceInHole is close to perfectionAceInHole is close to perfectionAceInHole is close to perfectionAceInHole is close to perfectionAceInHole is close to perfectionAceInHole is close to perfectionAceInHole is close to perfectionAceInHole is close to perfectionAceInHole is close to perfection
could pull the fuel pump fuse, or place a switch in line with the accessory power and/ or ignition wire (or for that matter, trace the fuel pump power line and place a switch on that).
AceInHole is offline   Reply With Quote
Old 05-05-2003, 09:04 PM   #3
nismofeind
nismofeind is an unknown quantity at this point
Yea find the line that connects to the fuel pump. I know there has to be a way to run a switch with only runing one wire from the pump wire.
-----------I I----------fuel pump
I I not this
IswitchI
--------------------I-------------fuel pump
I
I This
switch
this would really save on the wiring.
is there away to have it so nothing turns on when you turn the key just opens a batter lock type thing then one has to manual hit the switchs to turn everything on.
is there a benefit to this?? power saving?? weight reduction??
nismofeind is offline   Reply With Quote
Old 05-05-2003, 09:43 PM   #4
AceInHole
Autox Technician
AceInHole's Avatar
Could tap the ground wire and run a new ground from wherever you mount the switch.
could hide a starter button that connects the starter signal wire from the key and have to press the button and turn the key....
