Old 05-06-2003, 09:04 PM   #1
KRISGAMM
KRISGAMM is an unknown quantity at this point
Question KA smokes
I just bought a 95 240 with KA motor 130k miles. It runs fine, but it starts to smoke a idle could this be the valve seals. Any help is greatly appreciated.
KRISGAMM is offline   Reply With Quote
Old 05-06-2003, 09:07 PM   #2
AceInHole
Autox Technician
AceInHole's Avatar
AceInHole is close to perfectionAceInHole is close to perfectionAceInHole is close to perfectionAceInHole is close to perfectionAceInHole is close to perfectionAceInHole is close to perfectionAceInHole is close to perfectionAceInHole is close to perfectionAceInHole is close to perfectionAceInHole is close to perfectionAceInHole is close to perfection
Re: KA smokes
Only smokes at idle?? Could be valve seals or a piston oil ring or even a headgasket leak. Is it white smoke? Blue smoke? Black smoke??
AceInHole is offline   Reply With Quote
Old 05-06-2003, 09:09 PM   #3
KRISGAMM
White smoke.
Old 05-06-2003, 09:10 PM   #4
AceInHole
Autox Technician
AceInHole's Avatar
my guess is you're burning off coolant. Check your coolant levels lately?? If it is the coolant, it's most likely a leaky headgasket.
Old 05-06-2003, 09:16 PM   #5
KRISGAMM
Coolant level looks fine, clean and green.
Old 05-08-2003, 01:03 AM   #6
twitchy
twitchy's Avatar
twitchy is an unknown quantity at this point
white smoke is usually coolant, make sure its not thick steam. If it is coolant the smoke will be very very thick and likely your engine wont run well at all. If its only at idle thats bizarre. Keep an eye on it and get a pressure test on the coolant system if need be
Who the hell needs a sig anyhow
twitchy is offline   Reply With Quote
