Old 10-07-2009, 04:06 PM   #1
MELLO*SOS
LAID OUT
MELLO*SOS's Avatar
MELLO*SOS is close to perfectionMELLO*SOS is close to perfectionMELLO*SOS is close to perfectionMELLO*SOS is close to perfectionMELLO*SOS is close to perfectionMELLO*SOS is close to perfectionMELLO*SOS is close to perfectionMELLO*SOS is close to perfectionMELLO*SOS is close to perfectionMELLO*SOS is close to perfectionMELLO*SOS is close to perfection
where to buy? Snap ring for RB shifter
I need the snap ring that holds the shifter into the trans. This is for a RB20 shifter and trans. The KA one is about 50mm outside diameter whereas the RB one is about 54mm outside diameter. My stock one was broken, the ears with the holes were snapped off.
Does anyone have a part number or interchange with US car?
Thanks
MELLO*SOS is offline   Reply With Quote
Old 10-07-2009, 04:10 PM   #2
Flaco S14
Flaco S14 is on a distinguished road
i found some that worked at Ace hardware
Flaco S14 is offline   Reply With Quote
Old 10-07-2009, 04:17 PM   #3
MELLO*SOS
LAID OUT
MELLO*SOS's Avatar
Thank you, I wasn't sure if the thickness mattered. Ace has an awesome selection of bolts (compared to HD/Lowes), I thought they might have it but haven't had a chance to stop by there yet.
Did you have the same problem?
Old 10-07-2009, 04:26 PM   #4
sleep
sleep's Avatar
sleep is an unknown quantity at this point
Send a message via AIM to sleep
Don't know why the thickness would matter. All it does is hold the shifter in the trans.........
Did you need 2 seperate threads?
sleep is offline   Reply With Quote
