Old 05-09-2003, 02:26 PM   #1
kickertu
kickertu is a well-known jackass
sr isnt smoking blue anymore.. now its white...
I had already written a post about what was going on with teh car, but now there is a whole new problem...
http://www.zilvia.net/f/showthread.p...8&goto=newpost
as some of you may know, the car woulnt idle, and it was smoking blue.., and it wouldnt stop smokin either..
so i checked the oil, and it was over full, so i pushed it into the shop, and i drained the oil... well it was half oil and half gas...
I dont know how it happend but there was gas in the oil...
so i drained all of that, and i went down and got new oil and a new filter, and i put them on..
well it was the wrong filter, and when i tried to start the car, the filter shot off, and oil went everywhere. so after alot of cussing, i went back to the store with the old filter in hand and said i need another one of these. well they had discontinued them, so i asked for something that replaced it,
so with new filter in hand a 4 more quarts of synthetic, i went back to the car, and put all of it on, and checked everything 3 times over..
i turned the key, and vroom.. it started without me giving it any gas, and it idles.. but now it smokes white...
I havent been able to check the timing on it yet.. but the oil pressure guage, and the temp guage seemed to be working fine, and they seemed to stay pretty normal...
what would cause white smoke?
kickertu is offline   Reply With Quote
Old 05-09-2003, 06:07 PM   #2
memphiss13
memphiss13 is an unknown quantity at this point
Send a message via AIM to memphiss13
white smoke means your headgasket is bad i think
memphiss13 is offline   Reply With Quote
Old 05-09-2003, 06:12 PM   #3
240SxTYLE
240SxTYLE's Avatar
240SxTYLE is an unknown quantity at this point
Send a message via AIM to 240SxTYLE
my friend with an ls turbo had the same problem (or what seemed to be the same problem). it happend when he blew his head gasket. that night he had also scraped one of his cylinders. From what i know (which is based off hondas) it might be the head gasket.
one way to check if its the head gaske is you let your car run long enough and check the tip of the exhuast to see if condensation has built up. or you can put/hold a paper towel over the exhaust and see if the towel becomes damp. those are the ways his mechanics figured it out what was wrong before pulling his **** apart
Second love
First Love (my girl, not the honda)
240SxTYLE is offline   Reply With Quote
Old 05-09-2003, 08:12 PM   #4
kalieaire
kalieaire's Avatar
kalieaire is an unknown quantity at this point
Send a message via ICQ to kalieaire
gasoline in your oil pan could be a symptom of a bad HG and badly sealing rings.
is your coolant covered in oil?
you should've just bought an oem oil filter from nissan. a lot less headaches.
-when you were putting out blue smoke, that was motor oil leaking past the rings or valves or hg into the combustion chamber.
when you changed the oil, the easy flowing gas/oil mixture was turned into a harder flowing pure oil. so your rings are probably sealing better, but it shows that you have another problem since your car is smoking pure white now. you most likely have a blown headgasket.
take off the had and check that it's level, if not, you'll need to have it shaved. also, replace the headgasket.
next check to see if the water pump is working a-ok too.
check your radiator to see if it's clogged, and get a new thermostat and a radiator cap while you're at it. these are all good items to get for maintenance.
'93 240sx coupe
'93 taurus wagon
-kalieaire (maybe grinder too on special occasions)
kalieaire is offline   Reply With Quote
Old 05-09-2003, 10:00 PM   #5
240Driver39
240Driver39 is making a name for him/her self240Driver39 is making a name for him/her self
Send a message via AIM to 240Driver39
Since everyone is sayin headgasket and such, id just do a compression test, its easy and will help eliminate what possible issues u have.
1990 240sx 5spd fastback
240Driver39 is offline   Reply With Quote
Old 05-16-2003, 11:29 PM   #6
AJs14
AJs14 is an unknown quantity at this point
Send a message via AIM to AJs14
blue is oil. white is coolant.
1991 MKIII Turbo (272rwhp/330ft/lbs) SOLD!
1995 MKIV 6spd (314 rwhp) SOLD!
1996 S14 SE w/ SR SOLD!
1996 SC300
Dubs can't drift.
AJs14 is offline   Reply With Quote
Old 05-17-2003, 02:44 AM   #7
kalieaire
kalieaire's Avatar
hey guy, this is an old post, read through it before you respond to it.
'93 240sx coupe
'93 taurus wagon
Old 05-17-2003, 10:12 AM   #8
AJs14
thanks for the tip guy. i used my previous experiences from an old mk3 supra with a blown head gasket. no need to read.
1996 SC300
Dubs can't drift.
