Old 10-21-2009, 11:38 AM   #1
sevenstar
sevenstar is an unknown quantity at this point
stock blowoff valve leaks?
I am wondering if the stock blowoff valve is prone to leak at 12psi? has anyone noticed their car hissing under boost over stock psi? i have not pressure tested the stock bov yet, but after reading your responses might have to
sevenstar is offline   Reply With Quote
Old 10-21-2009, 12:03 PM   #2
g6civcx
g6civcx's Avatar
For a 10-15 year old engine, I wouldn't pull it pass the stock piping to have a leak somewhere.
Old 10-21-2009, 09:05 PM   #3
dongoesby
dongoesby's Avatar
dongoesby is a glorious beacon of lightdongoesby is a glorious beacon of lightdongoesby is a glorious beacon of lightdongoesby is a glorious beacon of lightdongoesby is a glorious beacon of lightdongoesby is a glorious beacon of lightdongoesby is a glorious beacon of lightdongoesby is a glorious beacon of lightdongoesby is a glorious beacon of lightdongoesby is a glorious beacon of lightdongoesby is a glorious beacon of light
i just got my swap done with stock piping and stock recirculating valve. And it does not make any sound (pssh) under boost. I'm not sure if it suppose to make a sound when you let go of the pedal, but mine does not make any sound so matter what or when.
dongoesby is offline   Reply With Quote
Old 10-25-2009, 01:03 PM   #4
sevenstar
You might have a problem if yours makes no sound at all.l I have after market piping
Old 10-25-2009, 01:06 PM   #5
guitaraholic
guitaraholic is a glorious beacon of lightguitaraholic is a glorious beacon of lightguitaraholic is a glorious beacon of lightguitaraholic is a glorious beacon of lightguitaraholic is a glorious beacon of lightguitaraholic is a glorious beacon of lightguitaraholic is a glorious beacon of lightguitaraholic is a glorious beacon of lightguitaraholic is a glorious beacon of lightguitaraholic is a glorious beacon of lightguitaraholic is a glorious beacon of light
There is a bleed hole in the stock BOV, So its actually made to leak a little bit, why I have no idea. I tapped mine and fit in a set screw, boost builds faster now. I'm going to reverse it here shortly and turn it into a pull style when I get the hose thing figured out.
guitaraholic is offline   Reply With Quote
Old 10-25-2009, 01:26 PM   #6
sevenstar
Old 10-25-2009, 05:32 PM   #7
dongoesby
dongoesby's Avatar
so you are saying it supposes to make a sound?
well, i just got the swap done with everything stock. Recently, I hear a tiny sound when I let go the throttle. I'm really not sure how should it sound. Do you or anyone got a sound clip for stock bov?
Old 10-25-2009, 06:27 PM   #8
sevenstar
can you post a pic of this bleedhole thing?
Old 10-25-2009, 06:53 PM   #9
Def
Stock bypass/blow off valve sucks. Mine would build boost about 300-400 RPM later than with one that would hold shut.
I adapted an aluminum "Bosch style" bpv to the stock location and love it. No surging under partial throttle boosting(like modulating throttle in the middle of a corner), and has adjustable springs so you can fine tune how much seat pressure it has. Has o-rings all over so it doesn't leak. I just had to epoxy on a slightly larger tube for the stock sized bov/bpv inlet hose to be secure(it's a 1" inlet/outlet, stock has a bigger inlet - ~38mm IIRC).
S13 Hatch - Goes around tracks quickly
DEFSPORT
Old 10-25-2009, 08:23 PM   #10
dongoesby
dongoesby's Avatar
could you give more in-depth info on the "Bosch style" bpv? Where can we get it, and how does it work comparing to stock bov? Is it a complete replacement?
I'm continously searching for a recirculate valve that can replace my stock recirculate valve, because I constantly thinking mine does not work.
Old 10-25-2009, 08:29 PM   #11
lazysk8er2
lazysk8er2's Avatar
lazysk8er2 has much to be proud oflazysk8er2 has much to be proud oflazysk8er2 has much to be proud oflazysk8er2 has much to be proud oflazysk8er2 has much to be proud oflazysk8er2 has much to be proud oflazysk8er2 has much to be proud oflazysk8er2 has much to be proud oflazysk8er2 has much to be proud oflazysk8er2 has much to be proud oflazysk8er2 has much to be proud of
possibly get a new pipe and put a greddy on or an hks or even a synchronic bov
Well i have a 95 240 and i like my cars low... But my parents don't like my wheels tilted
________________________________
lazysk8er2 is offline   Reply With Quote
Old 10-25-2009, 08:50 PM   #12
guitaraholic
It's inside the BOV itself. It is a small hole about 3-4 mm in diameter. Why its there I don't know. But connects the High and Low pressure side. You can physically blow from one side to the next by mouth. I blocked it off, and now my turbo is spooling at like 2.5k hell, it almost spools when I don't want it to. Its not that hard to take apart the BOV, its 3 screws, then just tap it with a 10mmx24 tap, and put in a set screw (put some paint on the screw so it doesn't come out) and you're done. No more leaks. Flip the hoses (will need to adapt the sizes) and now its a pull instead of a push style (will be doing that in the near future)
Old 10-25-2009, 09:34 PM   #13
RbPowered240z
RbPowered240z is an unknown quantity at this point
I dont mean to thread jack, but i just put on my blitz bov and supposedly the bov release's on high rpms, but i notice everytime that theirs a hissing sound before it goes off, i cheacked my boost gague and its right??
anyone know what this might be?
RbPowered240z is offline   Reply With Quote
Old 10-26-2009, 04:03 AM   #14
RbPowered240z
bump!!!!!!
Old 10-26-2009, 02:54 PM   #15
sevenstar
yeah i got the hissing sound too, on high boost.
Old 10-26-2009, 07:59 PM   #16
RbPowered240z
anyone????????
Old 10-26-2009, 08:31 PM   #17
Tom25666
Tom25666's Avatar
Tom25666 has made poor choicesTom25666 has made poor choicesTom25666 has made poor choicesTom25666 has made poor choicesTom25666 has made poor choicesTom25666 has made poor choices
the stock smic bov recirc'ed is basically silent
I have 1000 hp. This thread is dumb.
Tom25666 is offline   Reply With Quote
Old 10-27-2009, 10:08 AM   #18
Def
Bosch Turbo Bypass Valve for Audi Porsche VW Diverter:eBay Motors (item 360102436125 end time Nov-22-09 18:15:32 PST)
Like I said, it's not a drop in replacement. I epoxied on a 1.375" tube I beaded for the inlet, or you could get a reducing coupler - something. The inlet/outlet of the stock BPV is ~1.3"/~1"(I think, been a while since I messed with a stock one), the Bosch style one is 1"/1" so you have to make the inlet bigger. The packaging is similar. I've got mine in the stock location on my GReddy VSPL IC kit recirculating to an aluminum intake pipe I fabbed up.
Like I said, it works great, and you can adust the spring inside for whatever boost you're running and vacuum you draw at idle. I have the middle one in and it works just fine. No more compressor surge like the HKS SSQV was giving me on partial throttle lifts, and much faster response.
DEFSPORT
Old 10-28-2009, 10:58 PM   #19
dongoesby
dongoesby's Avatar
Well I'm comparing it to my stock sr20 recirculate valve. Do you think it will work?
After reading the link, I noticed that it is an upgrade for stock rubber bov and those that are using diagrams. I know our factory SR ones are metal, but I'm not sure if it is a diagram type. Could you confirm on that?
As for a mulfunction bov, besides leak, what other symptoms would it gives? My vacuum looks fine at idle (-8psi), and the car drives fine, no lost power between shift. It just makes no sound. Is it operating fine?
Old 10-29-2009, 09:03 AM   #20
Def
YES IT WILL WORK IN PLACE OF THE STOCK RECIRC VALVE WITH SOME MINOR MODIFICATION!!!!!
I don't know if anything is wrong with your stock BOV, I'm not a psychic. Take it out and inspect it.
DEFSPORT
