Old 05-13-2003, 07:53 AM   #1
jupiterl
jupiterl's Avatar
jupiterl is an unknown quantity at this point
Send a message via ICQ to jupiterl
Lightbulb 04 SE-R Brembo on S-chassis
Does anybody know if the Brembo Brake system that comes with the 2004 Sentra SE-R V-spec can be fitted into a S-chassis car ?
SR20det redtop, 205hp Stock
jupiterl is offline   Reply With Quote
Old 05-13-2003, 08:19 AM   #2
jupiterl
jupiterl's Avatar
O ... sorry I think only Canadian V-spec have the option with Brembo Brakes , right ?
www.nissan.ca
Old 05-13-2003, 09:03 AM   #3
adey
adey's Avatar
adey is an unknown quantity at this point
I think it'd be super cool if they did... BUT if you were going to do that, it'd probably be cheaper (or maybe more readily available?) to slap some R34 Brembos on your car. ... actually... I'm not sure if R34 GTRs ever came with Brembos. I faintly remember them, though.
In any case, I don't know if the R34 brembos'd even fit! I assume it would, since the R32 and Z32 and S14 4 pot calipers all bolt straight up (supposedly) to our cars...
As for the Sentra Spec-R brembos... you may as well try to put some V35 (G35) or Z33 brembos on our cars... they're probably significantly larger than the SE-R's.
Instagram: @SX180HKG
adey is offline   Reply With Quote
Old 05-14-2003, 11:22 AM   #4
sspikey
sspikey is an unknown quantity at this point
Send a message via ICQ to sspikey
Z33, g35 coupe and R34 all use the same badass brembo calipers. (12,8 inch if i remember right not 100% sure though)
keeping it sideways cuz im too fast to drive straight.
sspikey is offline   Reply With Quote
Old 05-14-2003, 11:31 PM   #5
jupiterl
jupiterl's Avatar
I know they all use the same looking calipers, but my main concern is how the two holes on the calipers and the spindles line up. Cuz I think only the RWD nissan has the same calipers mounting bolt pattern but the FWD.
Old 05-15-2003, 12:18 AM   #6
AceInHole
Autox Technician
AceInHole's Avatar
AceInHole is close to perfectionAceInHole is close to perfectionAceInHole is close to perfectionAceInHole is close to perfectionAceInHole is close to perfectionAceInHole is close to perfectionAceInHole is close to perfectionAceInHole is close to perfectionAceInHole is close to perfectionAceInHole is close to perfectionAceInHole is close to perfection
My guess: they'll fit (if the wheels clear).
Pretty sure we'll have to guess for now, since no one here has an 04 Spec V (or do they???).
I've heard of Maximas using z32 brakes, so you can't say FWD and RWD caliper brackets are different.
The interesting thing, though.... is that large diameter 4 lug rotors will be "more" available.
AceInHole is offline   Reply With Quote
