Old 10-23-2009, 11:27 PM   #1
drftkng951
drftkng951's Avatar
drftkng951 has a reputation beyond reputedrftkng951 has a reputation beyond reputedrftkng951 has a reputation beyond reputedrftkng951 has a reputation beyond reputedrftkng951 has a reputation beyond reputedrftkng951 has a reputation beyond reputedrftkng951 has a reputation beyond reputedrftkng951 has a reputation beyond reputedrftkng951 has a reputation beyond reputedrftkng951 has a reputation beyond reputedrftkng951 has a reputation beyond repute
engine noise
so lately i have been hearing a noise coming from my engine bay. i have 91 fastback with a 95 ka in it.
this noise is deffinately only under load when i'm driving with half or more than half throttle. i have revved the motor at idle and the noise isn't there. sounds like a rock or something really loose rattling in the engine compartment.
any help would be appreciated
J.SUN
drftkng951 is offline   Reply With Quote
Old 10-23-2009, 11:42 PM   #2
evolvedgs3
evolvedgs3 is an unknown quantity at this point
pull the head and inspect your jacked up piston (or skirt).
evolvedgs3 is offline   Reply With Quote
Old 10-23-2009, 11:44 PM   #3
holybushoffire
holybushoffire's Avatar
holybushoffire has a brilliant futureholybushoffire has a brilliant futureholybushoffire has a brilliant futureholybushoffire has a brilliant futureholybushoffire has a brilliant futureholybushoffire has a brilliant futureholybushoffire has a brilliant futureholybushoffire has a brilliant futureholybushoffire has a brilliant futureholybushoffire has a brilliant futureholybushoffire has a brilliant future
Send a message via AIM to holybushoffire
Before hand you could do a compression test and see what your numbers are. You should have severely low numbers in one cylinder.
"I am not good English, I like the drift"
CHINA DRIFT
"some guys have a better relationship with their car than their wife haha. sad but true."
SECRET SOCIETY
holybushoffire is offline   Reply With Quote
Old 10-24-2009, 12:06 AM   #4
drftkng951
drftkng951's Avatar
well i pulled the wire on each piston but it passed, i know that doesn't count for much.
is there a way to narrow if it is even piston?
J.SUN
Old 10-31-2009, 01:40 AM   #5
evolvedgs3
Dear god,,,,,,
Pull the damn spark plug and run a compression check on each cyl. to see if there is an issue with the piston or rings.
Google home compression check to see what to do.
Old 10-31-2009, 04:18 AM   #6
sidewaysonmy180
sidewaysonmy180 is an unknown quantity at this point
or it could just be the chain guide. if you dont here it while idling. just pull the cover off. new gasket in hand. and youll see a piece of metal right over your chain unscrew it and throw it away dont put the screws back in throw those away too. happens to most kade. mine did it. only on freeway on ramps that had an upwared slope though.
sidewaysonmy180 is offline   Reply With Quote
Old 10-31-2009, 05:26 AM   #7
mxexux
mxexux's Avatar
mxexux is an unknown quantity at this point
Sounds like it might be detonation if its only under load. Does it sound like a ping pong ball is bouncing around in your engine bay?
mxexux is offline   Reply With Quote
Old 11-12-2009, 08:46 PM   #8
drftkng951
drftkng951's Avatar
still waiting to get a compression tester
