Old 05-14-2003, 11:33 AM   #1
syco3d
syco3d's Avatar
syco3d is an unknown quantity at this point
Send a message via AIM to syco3d Send a message via Yahoo to syco3d
Do I have to bleed the clutch???
Ok so i'm in the middle of changing my clutch (tranny is on the the ground waiting for some extra muscle to get it back up) ..anyways I was just wondering if I NEED to bleed my fluid or not. Basically I'd prefere to be lazy and not bleed the system unless it's absolutly nessicary (sp?). I just want to get my car back on the road...i'm tired of driving my 8mpg beater truck.
Gimme a "A"!
Gimme a "P"!
Gimme a "C"!
What does that spell?
CRAP!
syco3d is offline   Reply With Quote
Old 05-14-2003, 11:37 AM   #2
Dousan_PG
Dousan_PG's Avatar
doesnt hurt not to
get those pesky air bubbles out
its like bleeding your brakes after changing the pads, you dont HAVE to but you might as well while the wheel is off
Aaron
Pink GodziRa
Old 05-14-2003, 11:44 AM   #3
syco3d
syco3d's Avatar
Yeah I hear ya. It's just that I really need my car tommorrow...and I don't think the person helping me tonight will be able to stick around long enough to bleed the system. Thanks for the reply though...It's nice to know that it's not an absolute need.
Gimme a "A"!
Gimme a "P"!
Gimme a "C"!
CRAP!
Old 05-14-2003, 11:45 AM   #4
Dousan_PG
Dousan_PG's Avatar
you didnt need to disconnect the slave cylidner at all when dropping tranny to change clutch?
i've never changed mine (yet) so i dont know....
if you had to disconnect it. you'll have to bleed it. takes 5 mins when you dont have the dampening box in there (search mode if you dont understand that comment)
Aaron
Pink GodziRa
Old 05-14-2003, 11:58 AM   #5
S14Speed997
S14Speed997's Avatar
S14Speed997 is an unknown quantity at this point
Hey Dousan36....
I was researching a post, and someone on there said they were going to add pics and details on changing their Master and Slave cylinders to the "Installs Section"....( I would like to have these for reference on *Project S&M*)
where does one find this?? I looked for it, but no luck
......sorry that I am using you as my "Zilvia Guru".....
S14Speed997 is offline   Reply With Quote
Old 05-14-2003, 12:03 PM   #6
Dousan_PG
Dousan_PG's Avatar
oh no install on it
its really easy
mc is like 4 or 5 bolts, you need to take it off clutch pedal inside car first and also unbolt in engine bay and remove hardline
follow hardline down, goes to dampner box, disconnect there, remove box, bend hardline (with proper tool--can get at auto shop-same tool to bend brake hardlines) and bend that to reach the hose that goes to clutch slave cylinder
clutch slave cylinder is 2 bolts on side of tranny (Passenger side). remove/replace (easy takes 10 minutes)
reinstall, bleed off the clutch slave cylinder.
since no more dampener box, takes about 5-10 minutes with 2 people
ive never seen pics or much beyond that
above is just a quicky.. its really really easy to do
parts for slave is like ~$15 and master is ~$60
Aaron
Pink GodziRa
Old 05-14-2003, 12:31 PM   #7
andrave
andrave's Avatar
andrave is an unknown quantity at this point
Send a message via AIM to andrave
if you left the slave cylinder connected to the line, you don't have to bleed the clutch.
BUT its been my experience that if it was your stock slave cyl it probably wasn't in the best shape, and the extra strain of a new clutch and pressure plate (I bumped to stage I clutch, too) will ruin the slave cylinder.
advance auto sells replacements for like 15 bucks, or you can get a 2 or 3 dollar rebuild kit.
so, no biggie. however, if you disconnect it you will need to bleed it. and you will need two people.
andrave is offline   Reply With Quote
Old 05-14-2003, 07:55 PM   #8
syco3d
syco3d's Avatar
yeah I was able to leave the cylinder attached the line. ..and the clutch I put in was pretty much just OEM ...so i'm not really too worried about crapping the slave...if I do I'll just replace it.
Gimme a "A"!
Gimme a "P"!
Gimme a "C"!
CRAP!
Old 05-15-2003, 12:04 AM   #9
FRpilot
FRpilot's Avatar
advance autos? do they have a website? are those new replacements for $15? also, while we're on the subject.. does anyone know the advantages of the nismo clutch slave cylinder and streghten bolt on jspec vs the oem spec slave cylinder? i was comtemplating getting the nismo as a replacement for my 10+ year old stock slave cylinder while im in the process of changin my cluthc.. any insights?
FRpilot is offline   Reply With Quote
Old 05-15-2003, 12:13 AM   #10
MorganS13
MorganS13 is an unknown quantity at this point
www.advanceautoparts.com , its where i usually get my parts if not Napa or the dealer
MorganS13 is offline   Reply With Quote
Old 05-15-2003, 12:31 AM   #11
andrave
andrave's Avatar
advance auto makes you order through parts america...
their website sucks total ***, they carry tons of **** that aren't in the web catalog. they are a national chain brand, with like 10 stores within an hour of my house, so I usually go there insteald of autozone...
anyway call and ask, website sucks.. I ordered brakepads throught the website and they took like 2 weeks to get here, I consider that slow.
Old 05-15-2003, 10:26 AM   #12
MorganS13
should've mentioned that i just go in person since there are a number of locations around here. i use the website to price parts and see what my options are however
Old 05-16-2003, 01:03 AM   #13
FRpilot
FRpilot's Avatar
so no one knows the disadvantages or advantages of the nismo clutch slave cylinder and streghten bolt on jspec vs the oem spec slave cylinder?
Old 05-16-2003, 10:54 AM   #14
andrave
andrave's Avatar
well, offhand I can tell you that the nismo one is somewhere around six times the price. I seriously doubt that it is so good that you would blow out six regular slave cylinders in its lifetime.
hydraulic clutches are simple. if you want to understand how they work, take a large syringe (no needle) and a slightly smaller syringe, and connect them with a length of silicone tubing. fill the system full of water, with the small syringe pushed in the big one holding water.
push the syringe. it pushes the small one.
now, unless nismo found some awesome way to improve (marginally, likely) the stock one, I doubt its worth whatever jspec is charging.
I got my oem replacement for, if memory serves correct, 13 dollars and change.
