Old 11-09-2009, 12:00 PM   #1
Destructodc74
Destructodc74 is an unknown quantity at this point
s13 blacktop sr wont boost? please help
okay so i have an s13 blacktop sr, i was running 11lbs on the stock t25 for at least a month until one day i was ripping it on the highway threw it into fifth and lost all power if i stepped on it, the car sputters and you can hear the turbo trying to spool but nothing, my gauge reads probably ~2lbs max. so i figured i blew my turbo beating on it, so i ordered a rebuild kit and then pulled the turbo, it didnt feel like it had much shaft play to begin with but i brought it to a shop and they tested it and it was still perfect. so no idea what it could be, i changed the plugs because my car has fouled them before. any input is greatly appreciated. thanks.
Destructodc74 is offline   Reply With Quote
Old 11-09-2009, 12:08 PM   #2
s14unimog
s14unimog's Avatar
Trader Rating: (22)
s14unimog has a reputation beyond reputes14unimog has a reputation beyond reputes14unimog has a reputation beyond reputes14unimog has a reputation beyond reputes14unimog has a reputation beyond reputes14unimog has a reputation beyond reputes14unimog has a reputation beyond reputes14unimog has a reputation beyond reputes14unimog has a reputation beyond reputes14unimog has a reputation beyond reputes14unimog has a reputation beyond repute
Feedback Score: 22 reviews
Send a message via AIM to s14unimog
^ for one, never start with " I think I blew the turbo" It would never stop blowing air if its blown, unless it has locked up. Second, I would have looked for a popped off inter-cooler coupler. You may have ripped one too. check the charge system for leaks.
Fu*king ginger bread man stole my wallet...
SHIFTlock_slide to side
d3m3rs0n: if i have a baby im naming it Brandons Fault Emerson
s14unimog is offline   Reply With Quote
Old 11-09-2009, 12:13 PM   #3
clark
clark's Avatar
clark is close to perfectionclark is close to perfectionclark is close to perfectionclark is close to perfectionclark is close to perfectionclark is close to perfectionclark is close to perfectionclark is close to perfectionclark is close to perfectionclark is close to perfectionclark is close to perfection
alright, check and replace cheap stuff....check vac lines, and like s14unimog said, really sounds like you blew a pipe or something. I've done that...it's like your engine got punched in the stomach.
problem sorta seems like fueling, but how about a better interpretation of the current problem, we know what happened, when it happened, but what's it like now...does it idle normal? does it sputter through the RPM band?
video?
clark is offline   Reply With Quote
Old 11-09-2009, 12:22 PM   #4
Destructodc74
it starts up and idles fine, revs perfect all the way to redline sitting in neutral but as soon as you put a load on it it sputters hard exactly when boost should be kicking in, i havent checked for leaks yet although i know its the obvious thing do to, and that could be it, when i step on it i usually get a small cloud of black smoke.
Old 11-09-2009, 12:30 PM   #5
Destructodc74
ill try to get a video up but whats an easy way to test for boost leaks?
Old 11-09-2009, 12:52 PM   #6
clark
clark's Avatar
there are only so many places the boost leak could be. hotpipe from turbo to ic, cold pipe from ic to tb.
check clamps and your boost couplers.
Old 11-09-2009, 01:05 PM   #7
Destructodc74
thanks. tommorrow i think im going to make a diy boost leak tester and get a good idea. i really hope thats the problem
Old 11-10-2009, 09:33 AM   #8
conrad_s13.5
conrad_s13.5's Avatar
conrad_s13.5 is making a name for him/her selfconrad_s13.5 is making a name for him/her self
does it sound like you have an exhaust leak!? check the manifold too man,... could have came loose or got a leak there.
cONtRol FReAkS
conrad_s13.5 is offline   Reply With Quote
Old 11-10-2009, 02:04 PM   #9
Destructodc74
no exhaust leak im positive of that, i just pulled apart the whole setup yesterday and put everything back together with copper gasket sealant. im gonna attempt to check for boost leaks soon.
Old 11-11-2009, 02:18 AM   #10
S13 curtis
S13 curtis's Avatar
S13 curtis is an unknown quantity at this point
what is the vacume at idle?
S13 curtis is offline   Reply With Quote
Old 11-11-2009, 06:58 AM   #11
Destructodc74
wow, it was a boost leak, somehow one of the clamps slipped under the coupler at the intake manifold.... i feel like a dumbass for tearing my setup apart to find it when it was so simple. thanks everyone.
Old 11-11-2009, 07:36 AM   #12
S13 curtis
S13 curtis's Avatar
sweet!!!!!
