Old 11-10-2009, 05:59 PM   #1
YoungGun
YoungGun's Avatar
Headgasket 1mm over bore
Hey bros I got a quick question for yall.
I picked up a 1.1mm thick apexi headgasket 86mm stock bore, but when I picked it up the guy that was helping me said that apexi actually makes the gaskets 1mm over the bore size which would essentially make it 87mm.
This is not my question, long story short i'm going to trade in this gasket for a thicker one because the machine shop had to take off a lot from the block.
Would it be okay to buy a 87mm gasket from cosworth? I am using stock pistons and stock bore, if anyone has any insight please let me know thanks!
YoungGun is offline   Reply With Quote
Old 11-10-2009, 06:23 PM   #2
GSXRJJordan
GSXRJJordan's Avatar
You always want a head gasket that's 0.5mm or 1mm over what your bore is.
Old 11-10-2009, 07:25 PM   #3
YoungGun
YoungGun's Avatar
^^Thanks.
Anyone know if Cosworth makes their gaskets to size, not like Apexi?
Old 11-10-2009, 07:40 PM   #4
GSXRJJordan
Cosworth, like most head gasket makers, lists the actual size. So you'd want a 86.5mm or 87mm for your stock-bore SR. Since they only make 87mm and 90mm I believe, your choice is easy lol.
Old 11-10-2009, 08:07 PM   #5
YoungGun
YoungGun's Avatar
Thanks dude!
I'll have to buy you a boba or something at the 626 meet for all the help you've been giving me hahaha.
Old 11-10-2009, 08:48 PM   #6
s13silvia123
s13silvia123's Avatar
s13silvia123 is close to perfections13silvia123 is close to perfections13silvia123 is close to perfections13silvia123 is close to perfections13silvia123 is close to perfections13silvia123 is close to perfections13silvia123 is close to perfections13silvia123 is close to perfections13silvia123 is close to perfections13silvia123 is close to perfections13silvia123 is close to perfection
Originally Posted by YoungGun View Post
Thanks dude!
i might just pick up some boba during lunch tomorrow thanks making me crave
18g and 20g turbo users click on me
http://zilvia.net/f/tech-talk/261219-18g-20g-turbo-users.html
s13silvia123 is offline   Reply With Quote
Old 11-10-2009, 09:03 PM   #7
Dousan_PG
Dousan_PG's Avatar
yeah that's normal
dont worry
Aaron
Pink GodziRa
Old 11-11-2009, 02:07 AM   #8
S13 curtis
S13 curtis's Avatar
S13 curtis is an unknown quantity at this point
my apex HG is 87mm its 1mm over and my car runs fine.
S13 curtis is offline   Reply With Quote
Old 11-11-2009, 06:14 AM   #9
gsracer
gsracer has a reputation beyond reputegsracer has a reputation beyond reputegsracer has a reputation beyond reputegsracer has a reputation beyond reputegsracer has a reputation beyond reputegsracer has a reputation beyond reputegsracer has a reputation beyond reputegsracer has a reputation beyond reputegsracer has a reputation beyond reputegsracer has a reputation beyond reputegsracer has a reputation beyond repute
back when i had an sr it was the same
ANTI-STRETCH NAZI
Vortech Supercharged Vh45de S14 V8nissans.com
gsracer is offline   Reply With Quote
Old 11-11-2009, 06:51 PM   #10
brian3676
brian3676 is an unknown quantity at this point
i build lots of SR's and always use cosworth there my favorite, i use 87mm every time works perfect
brian3676 is offline   Reply With Quote
