Old 11-12-2009, 06:58 PM   #1
idamaster
idamaster's Avatar
idamaster is an unknown quantity at this point
Sr headgasket Q's
Im about to pull my head right now and I wanted to get a thicker headgasket. Ive been told to go with a 1.5 but what are the pros/cons of a 1.5 and a 1.1 or does it not matter at all? Q #2: Is there any major benifit from ARP head studs for higher boost?
idamaster is offline   Reply With Quote
Old 11-12-2009, 07:15 PM   #2
okisrniju
okisrniju's Avatar
okisrniju is an unknown quantity at this point
I was wondering the same thing. I don't plan on boosting past 1.2 but I do have a 1.2 mm headgasket. Someone told me that I'll have to shave the head if I get a thicker headgasket for compression. Is that true?
okisrniju is offline   Reply With Quote
Old 11-12-2009, 08:07 PM   #3
idamaster
idamaster's Avatar
If you get your head machine you need a thicker head gasket to compensate for the loss of metal. Just my guess.
Old 11-14-2009, 05:27 AM   #4
HYPNOTIK
HYPNOTIK's Avatar
HYPNOTIK is an unknown quantity at this point
Send a message via Yahoo to HYPNOTIK
Unless you have a reason to lower your compression there is no reason to get a thicker headgasket. Especially if your running stock bottom end I would not lower the compression, stock pistons are 8.3:1, if anything I'd go with a smaller headgasket to raise compression. If you have the head shaved and it's still within spec there is still no reason for a thicker headgasket. If your head is shaved enough that you need to compensate with a thicker headgasket then it's time for a new head.
Def get some ARP studs or at the very minimium some new stock head bolts. Don't reuse your stock bolts, they stretch.
It's a good idea to get the head shaved when you replace the head gasket with a metal one to ensure a perfectly flat mating surface so that you get a good seal.
You should be fine with the 1.1mm.
HYPNOTIK is offline   Reply With Quote
Old 11-14-2009, 08:34 AM   #5
idamaster
idamaster's Avatar
The reason I want to get a thicker head gasket is because I want to turn my boost up to about 16 psi. With supporting mods of course.
Old 11-14-2009, 09:01 AM   #6
HYPNOTIK
HYPNOTIK's Avatar
You still don't need a thicker headgasket. I plan on running 1.5bar w/ 9:1 compression.
Old 11-14-2009, 09:31 AM   #7
idamaster
idamaster's Avatar
Well is there a loss of power with a thicker headgasket at stock boost? Just a random question.
Old 11-14-2009, 02:02 PM   #8
ericb382
ericb382 is an unknown quantity at this point
Yes. IMHO get a .8 and crank the boost.
ericb382 is offline   Reply With Quote
Old 11-25-2009, 10:07 AM   #9
idamaster
idamaster's Avatar
Do the headstuds go on first or do you put the head on THEN put the headstuds on?
Old 11-25-2009, 10:21 AM   #10
VNG704
VNG704's Avatar
VNG704 has a reputation beyond reputeVNG704 has a reputation beyond reputeVNG704 has a reputation beyond reputeVNG704 has a reputation beyond reputeVNG704 has a reputation beyond reputeVNG704 has a reputation beyond reputeVNG704 has a reputation beyond reputeVNG704 has a reputation beyond reputeVNG704 has a reputation beyond reputeVNG704 has a reputation beyond reputeVNG704 has a reputation beyond repute
Follow the FSM. Acronym for Factory Service manual. If you don't have one, the .pdf file is free for downloading online. Answers most your DIY questions you'll have.
I put the head on first.
VNG704 is offline   Reply With Quote
Old 11-25-2009, 10:22 AM   #11
HaSo240sx
HaSo240sx is an unknown quantity at this point
I would do the head studs and on the s14 sr motor the headgaskets f up on higher boost, but sence your pulling the head might as well doit i would suggest the apexi...
HaSo240sx is offline   Reply With Quote
Old 11-25-2009, 12:29 PM   #12
idamaster
idamaster's Avatar
I already have arp studs. I was asking if they go on before I put the head or after.
Old 11-25-2009, 02:33 PM   #13
Sileighty_85
Sileighty_85's Avatar
Originally Posted by HYPNOTIK View Post
, stock pistons are 8.3:1, .
Stock Compression Ratio is 8.5:1, just wanna clear that up
Running a thicker head gasket is not a bad thing, it lowers the chances of detionation at high boost compared to a Higher compression boosted engine, But really its all in the tune, if you can get a good tune your safe.
Im running a 1.5 mil PE head gasket boosting 21psi with no issues.
後輪駆動車1番
1989 Built SR GT2871R -363whp
1986 SR86 - 200ish
1990 R32 GTR - 320hp
Old 11-26-2009, 10:03 PM   #14
slamn240
slamn240 is a jewel in the roughslamn240 is a jewel in the roughslamn240 is a jewel in the roughslamn240 is a jewel in the roughslamn240 is a jewel in the roughslamn240 is a jewel in the roughslamn240 is a jewel in the roughslamn240 is a jewel in the rough
i put them on after you put the head on. that is what ii did when i use to builted sr's for sr motorcars
slamn240 is offline   Reply With Quote
Old 11-26-2009, 10:16 PM   #15
xdumbxguyx
xdumbxguyx is a splendid one to beholdxdumbxguyx is a splendid one to beholdxdumbxguyx is a splendid one to beholdxdumbxguyx is a splendid one to beholdxdumbxguyx is a splendid one to beholdxdumbxguyx is a splendid one to beholdxdumbxguyx is a splendid one to beholdxdumbxguyx is a splendid one to beholdxdumbxguyx is a splendid one to beholdxdumbxguyx is a splendid one to beholdxdumbxguyx is a splendid one to behold
put the head on first then the arp studs
make sure to put a light layer of silicone over the oil pump area where the head gasket seats on
1.1mm headgasket should be fine for ur appication
infinitwheels.com
pitgarage.net
xdumbxguyx is offline   Reply With Quote
