Old 05-18-2003, 11:39 PM   #1
misnomer
misnomer's Avatar
misnomer has a little shameless behavior in the past
Send a message via AIM to misnomer
Can't unlock the key from ignition!
Car is an '89 fastback with automagic transmission, motor is stock.
If anybody is still up, I could use some help. I had just removed and reinstalled my sister's head unit on the stereo (was going to put in a different one, but didn't). Put everything back together just as I have a dozen times in the past, try to pull the key out and the release button doesn't go.
Rowsdower saves us and saves all the world!
misnomer is offline   Reply With Quote
Old 05-18-2003, 11:58 PM   #2
misnomer
misnomer's Avatar
ahh, fixed it :P
Took the cover off of the key lock, fiddled with the lever below the switch, and got things rollin' again.
Thanks for the help guys! We kick ***
Old 05-19-2003, 12:34 AM   #3
Chew Slice
Chew Slice is an unknown quantity at this point
hey I do what I can
Chew Slice is offline   Reply With Quote
Old 05-19-2003, 01:33 AM   #4
mrmephistopheles
mrmephistopheles's Avatar
sorry i couldn't get to a computer, i was at work, so i just did a Jedi mind-fax to you.
