Old 11-16-2009, 11:07 AM   #1
clovers525e
clovers525e is an unknown quantity at this point
emanage=launch control?
i guess i should introduce my self first, my name is Ted, and i'm 23 years old, from murfreesboro tn, and my car is a s13 coupe, white, with a s14 sr20. i'v always been a huge fan of the old emanage blue piggy backs. i like the third party support and the modifications that can be done to them to add aditional features.
mine currently has the emanage gold mod done, ignition harness, injector harness, and a boost sensor, with a innovate lc-1 hooked up and data logging properly. i also have simon's emm software, emanage toolz and innovates logworks.
just so everyone knows, be leary about the lc1 and logworks because it will not track rpm. data logging a/f without rpm is like masturbation with an open hand.
so, i was looking around the other day at a couple of different topics at the same time. the emanage injector harness has six wires coming from it, for an sr20det only four are needed leaving two extra. at first i looked into using the two extra wires to drive two additional injectors with the additional injector map and purchasing r34 injectors to use on my sr. additional injectors are sexy, but unnecessary and not safe.
then i also considered the possibility of using them to drive the current four injectors after the factory rev limiter or even the speed cut. (or sending a speed signal to override the speed cut)
lastly i considered using the additional injector map, setting the duty cycle to 100%, wireing it to a relay from the ignition signal wire, and using it as an ignition cut rev limiter. at first i considered wireing the relay into the ground wire for the coil packs, but then i figured charge/drain on the coils would damage something. i would like the coils to keep there charge, but not fire.
since the additional injector map can be set to 100% at any rpm, you could set it to cut on at super low rpms and put out a steady signal.
lastly, i made a sketch of the relay system you would need to use to make a one time clutch switch.
with my system the process would work something like: start car, turn on launch control, press clutch in (1 of 2 led lights), press a push button (2 of 2 led lights), press gas, rpm is limited to what ever its set at in the emanage map, let off clutch (led's cut off), every time you shift the first light will show, but it will not limit the rpms until the push button is pressed while the clutch is pressed.
if someone could suggest a good way to cut the ignition signal let me know.
clovers525e is offline   Reply With Quote
