Old 11-23-2009, 06:03 PM   #1
babillaracing
babillaracing is an unknown quantity at this point
my s14 2jzgte build
I don't know if it is the right section ,if is not I apologized and moderator please move ..........Thanks....Omar
Here are some pictures of the lenght of the shifter. I am posting them cause I look everywhere and could'nt find them anywhere and I might help somebody and I know for a fact that tech 2 won't share that info
extension of 3.250" according to a person who bought the shifter from tech 2
1jz bellhousing
r154 tranny reinforced with first gear trusth washer and bearing carrier both parts from marlin crawler also extended shifter everything made by me
yonaka racing intercooler
misc parts
tranny closed and ready with shifter extension
here the custom made clutch
here is mines done by me also
here is mines closed with marling crawling forged first gear thrust washer and bearring carrier installed also everything done by me
if you want to buy the 1jz bellhousing buy it from champion toyota in texas they sell it for $300 plus shipping is way cheaper than driftmotion and tech 2 . here is the phone # 1-713-943-7010 ask for Jeff , he will hook you up
hope this help......................Omar
babillaracing is offline   Reply With Quote
Old 11-23-2009, 06:08 PM   #2
babillaracing
here are some more pictures of my modified oil pump
and here is my work bench at home figure out the wiring
motor ready to be droped in
motor in
This image has been resized. Click this bar to view the full image. The original image is sized 800x600 and weights 133KB.
I fabricated the mounts here are the clearance
tranny mount
Old 11-23-2009, 06:13 PM   #3
babillaracing
here is what I did today
tb welded and polished in the inside
custom made power steering hose
coolant fan switch to make fans runs with car temperature not all the time
tonight after the kids goes to sleep I will try to finish the harness
and tomorrow rear battery box installed and finish the mounts they are 1/8" off and I don't like it I am picky after that make a jig to probably mass production..Omar
Old 11-23-2009, 06:14 PM   #4
babillaracing
I did'nt do much today but here you go
battery relocator box
and finished to cut the holes for the cam gears
Old 11-23-2009, 06:15 PM   #5
babillaracing
today I redid the mounts cause I did'nt like the other ones (I am waiting for the supra ones to do the motor mounts again )
old one
new one in the making
almost done
done and painted
installed (you can see a glimse of the exhaust I am making the magnaflow pipe be here monday )
where the sifter sits
Old 11-23-2009, 06:17 PM   #6
babillaracing
flex pipe installed and bung for the wideband( it can't be seen in this angle)
exhaust the way I want it as closed to the chassis as possible with out touching it
Old 11-23-2009, 06:19 PM   #7
babillaracing
I re did the cross memberr mounts this time I used the supra mounts instead of the 240
the first one I did
the second version
first version of tranny mount
second version
fan clearance with new set up
crossmember clearance
finish the exhaust also
installing the cooler
Old 11-23-2009, 06:20 PM   #8
babillaracing
today I had some time to finish the intercooler piping amd started working on the fuel supply
here is the first time I let it go to the floor since I put the 2j on it it sits so low that I think I got to put stock spring for now while I gather some more money for the coilovers
also I am installing a supra (denso) fuel pump but when I pulled out the one on the car Is as big as the denso , does anybody got a picture of the stock s14 fuel pump? cause the one on the car the only marking I saw it said jecs made in japan .I want to see is that is the stock one or an aftermarket
Old 11-23-2009, 06:21 PM   #9
babillaracing
today I finished the coolant system
fuel pump denso supra fuel pump
fuel lines transfer from passenger side to driver side (this is temporal cause I am planning to upgrade the fuel system,turbo and intake on couple of months)
Old 11-23-2009, 06:22 PM   #10
babillaracing
today I had sometime to work on the car
modified 2j acelerator cable to work with s14 cable and cruise control
cruise control server installed in the opossite side of engine bay
fuel line system done (it will be temporary till I convert to single turbo and update fuel lines
fuel filter relocated
I did'nt take pictures of it but I by passed the heater core till I conver to single no room for the hoses
tomorrow I gonna work on the fuel pump relay and hopefully order the drive shaft
Old 11-23-2009, 06:23 PM   #11
babillaracing
yesterday I wnt I pick up some prosport gauges and today I made the console for the gauges
hopefully this weekend if I have time I will be starting the car and by mid next week the driveshaft will be done (waiting on the tranny yoke coming from california)
Old 11-23-2009, 06:24 PM   #12
babillaracing
today I finished the engine harness and make a board for the ecu ,power distribution,relays and dakota box (still waiting on the dakota box and drive shaft)
spagetti
board
Old 11-23-2009, 06:25 PM   #13
babillaracing
before
after
nittos nt555r extreme drag hopefully they hook
Old 11-23-2009, 06:26 PM   #14
babillaracing
installed the rims after some tlc
now waiting on 350z rotors adapters
and rear suspension adjustable arms to do the aligment and fender pull
Old 11-23-2009, 06:27 PM   #15
babillaracing
new brake set up
old vs new comparisson
Old 11-23-2009, 06:33 PM   #16
MTalon
MTalon's Avatar
MTalon has a brilliant futureMTalon has a brilliant futureMTalon has a brilliant futureMTalon has a brilliant futureMTalon has a brilliant futureMTalon has a brilliant futureMTalon has a brilliant futureMTalon has a brilliant futureMTalon has a brilliant futureMTalon has a brilliant futureMTalon has a brilliant future
nice work keep it up
MTalon is offline   Reply With Quote
Old 11-23-2009, 06:33 PM   #17
babillaracing
as of today 11-23 . I installed energy suspension bushings and replaced front and rear lower control arm ball joints .Now I am shopping for rear adjustable arms (rucas,toe,traction arms) I have'nt decide on the brand (spl or powered by max) and after that buying fortune auto drag coilovers...........................
Old 11-23-2009, 06:37 PM   #18
babillaracing
Thanks..................
Old 12-04-2009, 12:22 AM   #19
s142jzkillav10
s142jzkillav10's Avatar
s142jzkillav10 is an unknown quantity at this point
Send a message via MSN to s142jzkillav10
Great Build any Dyno time yet ??????????
s142jzkillav10 is offline   Reply With Quote
Old 12-04-2009, 10:25 AM   #20
Flicktitty
Flicktitty's Avatar
Flicktitty is a splendid one to beholdFlicktitty is a splendid one to beholdFlicktitty is a splendid one to beholdFlicktitty is a splendid one to beholdFlicktitty is a splendid one to beholdFlicktitty is a splendid one to beholdFlicktitty is a splendid one to beholdFlicktitty is a splendid one to beholdFlicktitty is a splendid one to beholdFlicktitty is a splendid one to beholdFlicktitty is a splendid one to behold
Send a message via AIM to Flicktitty
good stuff!
how do you plan on keeping the cruise control? can't say i've seen that done on many JZ swpped cars.
2JZ-GTE Swapped S13 Coupe - 1994 Supra Turbo
Flicktitty is offline   Reply With Quote
Old 12-04-2009, 11:12 AM   #21
babillaracing
Thanks man ,no dyno time yet . I am waiting for next year . when I will be upgrading to a single turbo bw s370 . But I think I am around 400whp at 18 psi cause I was cruising with my friend (built sr 450whp) and he decide to give it a try and I pulled on him bad
618 whp tuned by alpha
Old 12-04-2009, 11:14 AM   #22
babillaracing
Originally Posted by Flicktitty View Post
good stuff!
Nah I just put it there and Sean (Tech2) started making fun of me and i took it out.On another note that is mees up what happened to him , he was a cool dude
Old 02-28-2010, 05:17 PM   #23
coloRODan_240JZ
coloRODan_240JZ's Avatar
coloRODan_240JZ is an unknown quantity at this point
Nice project bro! What wheels are those and size?
coloRODan_240JZ is offline   Reply With Quote
Old 03-06-2010, 11:41 AM   #24
K_style
K_style's Avatar
Trader Rating: (63)
Feedback Score: 63 reviews
what kind of "sock" did you use with denso fuel pump ?
Old 03-06-2010, 11:55 AM   #25
robunicu
robunicu has made poor choicesrobunicu has made poor choicesrobunicu has made poor choicesrobunicu has made poor choicesrobunicu has made poor choicesrobunicu has made poor choicesrobunicu has made poor choices
Looks good buddy... must be quick as hell.. looks just like my old s14.. gl w the build
robunicu is offline   Reply With Quote
Old 03-08-2010, 03:30 PM   #26
S14Serge
S14Serge's Avatar
S14Serge is an unknown quantity at this point
This a very nice build you got going here bro! Keep up the good work, and btw dam those WORK VS look sexy as fawk
S14Serge is offline   Reply With Quote
Old 03-10-2010, 05:24 PM   #27
babillaracing
Sorry guys I haven been on the site latelly
Thanks man they works vs-xx front 17 x 9 16 offset rear 17 x 10 20 offset
Old 03-10-2010, 05:25 PM   #28
babillaracing
man that was a year ago ,iirc it was the stock s14 sock but I will be upgrading to twin densos next month I let you know for sure .........
Old 03-10-2010, 05:26 PM   #29
babillaracing
Thanks man , i rember your car with an s15 front end . I love it
and is all right. Next month I gonna make it a little quick
Old 03-10-2010, 05:27 PM   #30
babillaracing
thanks you sir
