Old 11-25-2009, 10:52 AM   #1
VNG704
VNG704's Avatar
VNG704 has a reputation beyond reputeVNG704 has a reputation beyond reputeVNG704 has a reputation beyond reputeVNG704 has a reputation beyond reputeVNG704 has a reputation beyond reputeVNG704 has a reputation beyond reputeVNG704 has a reputation beyond reputeVNG704 has a reputation beyond reputeVNG704 has a reputation beyond reputeVNG704 has a reputation beyond reputeVNG704 has a reputation beyond repute
reverse lamps don't work. S14
1997 with s13 sr. My reverse lamps don't work. I don't see a fuse for "reverse lamps" if there is any. The bulbs look perfectly fine. The bulb connectors look fine and connected securely. Not sure where to look next. T.I.A.
update: Yea, it was the wire to the reverse lamp switch, thanks.
VNG704 is offline   Reply With Quote
Old 11-25-2009, 11:01 AM   #2
mekaw
mekaw is an unknown quantity at this point
when that happened to me, it was my reverse gear sensor or w/e, its located on your tranny with a plug. wire snapped off due to rubbing
mekaw is offline   Reply With Quote
Old 11-25-2009, 11:07 AM   #3
VNG704
VNG704's Avatar
Cool, thanks for the quick reply. Will check for a reverse sensor on the trans and update.
Old 11-25-2009, 11:11 AM   #4
projectRDM
projectRDM's Avatar
2pin plug, wire colors are green/white and green on the chassis side. It's the same fuse as the gauge cluster, so as long as the cluster is good the switch is either bad or unplugged.
FORMERLY R240NA
Old 11-25-2009, 12:11 PM   #5
g6civcx
g6civcx's Avatar
S14 with S13 SR. Has the reverse lamps ever worked?
