Old 05-21-2003, 11:31 PM   #1
syrupninja
syrupninja's Avatar
syrupninja is an unknown quantity at this point
Send a message via AIM to syrupninja Send a message via Yahoo to syrupninja
Oil Leak?
So I went to change the oil on my new S13 and there was oil all over the bottom of the pan, same color as the rest of the oil, and seemed fairly fresh, it's not leaking profusely, ie there's no puddles when I park, and I haven't had it long enough to notice if it's consuming oil. I'm wondering if this is just a problem with the gasket, or the oil pan itself, and how bad it really is. Thanks.
syrupninja is offline   Reply With Quote
Old 05-22-2003, 01:43 AM   #2
s13silady
s13silady's Avatar
s13silady is close to perfections13silady is close to perfections13silady is close to perfections13silady is close to perfections13silady is close to perfections13silady is close to perfections13silady is close to perfections13silady is close to perfections13silady is close to perfections13silady is close to perfections13silady is close to perfection
might need a new drain plug... or at least put some thread seal on that sucker.
s13silady is offline   Reply With Quote
Old 05-22-2003, 02:16 AM   #3
driftingpanda
driftingpanda's Avatar
Trader Rating: (24)
driftingpanda has a reputation beyond reputedriftingpanda has a reputation beyond reputedriftingpanda has a reputation beyond reputedriftingpanda has a reputation beyond reputedriftingpanda has a reputation beyond reputedriftingpanda has a reputation beyond reputedriftingpanda has a reputation beyond reputedriftingpanda has a reputation beyond reputedriftingpanda has a reputation beyond reputedriftingpanda has a reputation beyond reputedriftingpanda has a reputation beyond repute
Feedback Score: 24 reviews
Send a message via AIM to driftingpanda
also, you might want to replace the drain plug washer. s13's have that crush-type washer that you're supposed to replace every time you change oil. avaliable at your local nissan dealer. if the pan is just oily, it's probably not a leak. if it's actually dripping, you might have a minor problem. hope that helps!
danny
PM me about limited edition Pink GodziRa Sticker packages!
driftingpanda is offline   Reply With Quote
