Old 11-28-2009, 08:34 PM   #1
DrIvEsldEwAyS
DrIvEsldEwAyS is an unknown quantity at this point
squeeling noise.
just put a new clutch and trans in my 240. (pulled motor to do so)
i just got it wrapped up tonight and started it up. i have a few problems.
1. It turns over slowly. doesnt get worse or any better just turns slow then fires up. ideas?
2. With the clutch pedal pushed in and with it let out, the car makes a LOUD squeeling noise. (just as loud if not louder than open DP.) i reused the throwout bearing that was already on the trans, (has less than 5k miles on it, didnt even remove it) and we tightened the pressure plate. never removed the flywheel. now the car did sit for a few months, also the motor sat for a month without the trans on it so there might be surface rust on flywheel. but other than that, what could be causing this sound. i am not 100% sure where it is coming from due to open DP but it sounds like the area of the starter.
thanks!
-1990 240sx hatch sr20det- gt35r, blah blah blah
DrIvEsldEwAyS is offline   Reply With Quote
