Old 12-01-2009, 02:57 PM   #1
732sr20det
732sr20det's Avatar
732sr20det is an unknown quantity at this point
Need help with starion wheels on s14
I picked up a set of starion rims fronts are 16x7 +18 and the rears are 16x8-10.. the backs line up good the fronts hit the caliper bracket can anyone tell me the size spacer i need should i just use a slide on or a bolt on? also i have q45 brakes all around!
732sr20det is offline   Reply With Quote
Old 12-08-2009, 09:11 AM   #2
Daviticus
Daviticus is an unknown quantity at this point
I'm not sure with Q45 brakes, but with stock S13 hardware, you could either run 3-5mm worth of spacer, or grind the caliper down until it no longer rubs.
Daviticus is offline   Reply With Quote
